| chunk1189 |
 chunk1189 L Plate Warrior
| bikenut |
 bikenut World Chat Champion
 Posted: 10:21 - 06 Jul 2012 Post subject: |
hi dude,
find your bike on cmnsl and see the exploded views, print them off if you can.
see the gear selection page, the gear lever ( foot operated ) should sit in the mid position, which is sprung loaded for up and down.
is your gear lever linkage adjustable for hieght?? if so then this may be the cause of gear selection problems, hope fully nothing wrong inside the engine?
poor performance is something else i would imagine. when was she serviced last? oil change, plug, air filter, valve clearance and cam chain.
how many miles has she done and some pics for the site would be good.  |
| P. |
 P. Red Rocket
 Posted: 11:32 - 06 Jul 2012 Post subject: |
If you are anywhere near Maidstone in Kent, I'll happy have a look, I have had so many of these buggers
The sluggish performance, check the choke cable for sticking, check the chain for correct tension and perhaps clean the carb/air filter.
The gear change, adjust the clutch so there is a little bit of play in the lever. You should be able to go 1st>2nd with no clutch used at all at 5k+ but its normally a case of not snapping it in hard enough.  |
| J.M. |
 J.M. World Chat Champion
| chunk1189 |
| bikenut |
| P. |
 P. Red Rocket
The last post was made 13 years, 172 days ago. Instead of replying here, would creating a new thread be more useful? |
