KLE500 as a restricted commuter - bad idea? Alternatives?
cdlxxvi
PostPosted: 12:22 - 01 Jul 2012    Post subject: KLE500 as a restricted commuter - bad idea? Alternatives? Reply with quote
sidewinder
PostPosted: 13:27 - 01 Jul 2012    Post subject: Reply with quote
The bike is a bit underpowerd to be honest.But saying that should work quite well restricted Very Happy
blurredman
PostPosted: 15:13 - 01 Jul 2012    Post subject: Reply with quote
Same engine as GPZ5 and ER5 Thumbs Up
Reliable mechanically as far as stories say. (other than the first generation gpz5).
All tuned differently, and I guess because this is more for the offroad tourer type, geared differently aswel..
I can't tell you anything specific about the KLE though mate sorry.
PostPosted: 15:15 - 01 Jul 2012    Post subject: Reply with quote
Yeah its as good as any bike to restrict. You won't be lopping off loads of power compared to a 1000cc bike etc so it should go all right with the restriction in place.
robocog
PostPosted: 17:47 - 01 Jul 2012    Post subject: Reply with quote
Almost identical engine to the GPZ500 as stated
(think the cams and ignition module are different from what I have read)
Just had my 2 years of restriction on my GPZ500 and it took the restriction very well indeed (eBay washers)
20 min job to fit / remove
Didn't have to do anything else like twiddle the mixture screw
When the washers came out last month there was no discernable difference in power below 5 / 6k I'd say
bear in mind I generally just commute to and from work a short distance that is short enough that I never get it up to full working temp and get condensate in the oil over winter periods - I do tend to short shift till its showing halfway on the temp gauge as I'm my own mechanic and have no intention of selling it and don't get myself together in enough time to leave the bike warming up (and certainly dont have time to fanny around rebuilding engines prematurely)
The transition from restricted to de restricted was pretty much un noticable by my seat of the pants dyno for my daily commute...but then its all 30 MPH limits anyway for me
7k RPM to redline its definately noticable that is no longer restricted
Fuel ecconomy wise - can't say I've noticed any difference and still get 170/180 miles to reserve from being brimmed - same as when restricted
Engine sounds like it belongs on a lawnmower - but just dandy at doing its job
(not going to jinx mine by saying how reliable and low maintenance its been ...DOH!)
Parts wise - I know that was a major factor in me getting the GPZ
I reckon I could rebuild several complete GPZ's by picking up parts from eBay - even if I restricted the searches to sub 20 miles and buy it now's only (but then they did build them for a L O N G time)
I guess the KLE has its power delivery lower down the rev range because of the cams and ignition (and the type of bike it is) so not sure if the restriction would be more evident
Again this is just a wild stab in the dark worst case scenario guess based on nothing
Regardless I'm sure it will be perfectly fine for what you want
Fit a scottoiler - do the services on time and you should have a low maintenence comfy mile muncher
Regards
Rob
Needs a bigger garage...
Irn-Bru
PostPosted: 17:53 - 01 Jul 2012    Post subject: Reply with quote
Should be a good bike for it, comfortable and predictable, go on forever. My dad has a P-reg one, which I think was before all the CAT and emissions rubbish toned it down a bit more. Not quick at all, but still gets to triple figures which is all you need for a commuter.
cdlxxvi
PostPosted: 20:00 - 07 Jul 2012    Post subject: Reply with quote
PostPosted: 10:28 - 08 Jul 2012    Post subject: Reply with quote
A good bike for what you want.
I rode one for a few years. It's not as rev-happy as the GPZ anyway so you tend not to ride it in the peak power with a wide open throttle. As such it should resrtrict well
An eminently practical bike and usually at a good price. The rear brake is rubbish but they all are on Kawasakis of that era. The front brake is much improved by fitting a braided steel brake line.
Check the exhaust is in good nick. OE ones are like rocking horse poo to get hold of but laser do make an aftermarket one.
They handle pretty well, very good in town and because they are a twin, much more comfortable on the open road than any of the big single offroad style bikes.
I always did an oil change at 3k and an oil and filter at 6k miles.
A wee note of caution. Mine broke three split link chains so use the rivett link. I think it might be something to do with the nylon chain-stays it's fitted with.
The only real ball-ache is the recessed fuel tap that you can't work with gloved hands. My tank eventually rusted then holed round this area so I'd suggest you spray it with corrosion inhibitor.
Check it's the right size for you though. Some people reported cramp in their legs after riding some distance.
De-restricted it'll sit all day long on the motorway at 100mph. the small fairing keeps the worst of the weather off too.
Amreet
PostPosted: 13:03 - 08 Jul 2012    Post subject: Reply with quote
but, 2.2k is an awful lot for that bike!
Have a look at what 2,000 can get you when buying privately, you could probably get an africa twin or transalp if you look carefully, and they restrict well, do everything a that kwak 500 will do, just better, so shop around a bit.
The transalp engine is the same V twin as goes into the Deauville, and NTV (Which is another bike I would recommend you look into, for a 'normal bike for a normal bloke' type thing. They're cheap unpretentious workhorses which will still be fun for weekend jaunts but can carry you across continents) and even when restricting from 60bhp to 33 they are fine, don't worry about it.
PostPosted: 13:48 - 08 Jul 2012    Post subject: Reply with quote
I agree.
I just bought a VFR750, admittedly a lot older but with a lower mileage for £1200.
cdlxxvi
PostPosted: 14:28 - 08 Jul 2012    Post subject: Reply with quote
PostPosted: 14:57 - 08 Jul 2012    Post subject: Reply with quote
I wouldn't be so worried about age as mileage and condition.
Expand the search a little and you find THIS
Half the mileage, £600 cheaper and it's a honda.
Wingrack and baglux cover fitted.
Just check under the tank cover, they're sometime fitted to cover scratches/dents.
cdlxxvi
PostPosted: 16:50 - 08 Jul 2012    Post subject: Reply with quote
Irn-Bru
PostPosted: 16:57 - 08 Jul 2012    Post subject: Reply with quote
I think they were less than £4,000 brand new Confused
blurredman
PostPosted: 17:01 - 08 Jul 2012    Post subject: Reply with quote
cdlxxvi wrote:
I do mind the age; vehicles are made of steel and rubber, both don't age well. I suppose I have a good chance of spending additional £600 in maintenance of a 10 years old bike compared to maintaining a 5 years old one over 2-3 years.
The one linked seems too good to be true - a commuter workhorse ridden for 13 miles a week, at a bargain price? Fishy...
I think your view on age is quite outdated, and I think naive. You can get some great bargains just because 'it's older'. Just like any car, any bike have their areas of common rust places. But most of the time, nothing that a bit of hard work and hammerite cannot fix, and it'll last for another 10 years if washed and looked after Thumbs Up
PostPosted: 17:40 - 08 Jul 2012    Post subject: Reply with quote
It's not all that fishy. A born-again biker has bought that bike with the intention of re-living his youth. He went straight out and dropped a load more money on touring accessories and crashbars (probably dealer fitted) did a couple of tours, got bored then stuck it in his shed and took it out once a year for the MOT.
I bet it comes with a wallet of sequential MOTs and old tax-discs detailing 4k miles in the first year then 150 miles every year thereafter and I bet it's clean as a whistle.
Bikes like that come up ALL the time, I'm good at spotting them, it'll have been sat under a dust sheet in a heated garage and barely turned a wheel after its second service.
I got a CB500s for the missus. The last owner did 400 miles in the 5 years prior to me buying it. I know he did, it was a local bike.
Worth going for a look anyway. If it's rusty, you'll see. Tyres have a date code on the side, if they are old, you negotiate a new set as part of the deal "I like the bike mate but those tyres are 6 years old. Bung a new set on and we have a deal.".
All that said, it's your money. Given the choice of the first KLE you posted and that CB500, I'd take the CB every time.
Amreet
PostPosted: 17:58 - 08 Jul 2012    Post subject: Reply with quote
Im with stinkwheel.
Im also willing to bet that a CB500 with twice the mileage and age of the KLE500 will outlast that KLE most likely. a new bike doesn't guarantee it will last, and an older bike doesn't guarantee that it'll dissolve after one winter.
your choice, spend way over the odds on a not so great bike or do your research, save money, and get a bike which will probably last better. While you're at it, look into doing servicing yourself, won't take long to learn, will save you more money and you will know exactly what is inside your bike, you know that the oil you put in is brand new and good quality etc. etc.
the lazy dealer buying approach for second hand bikes doesn't make sense any more, there are better bikes out there to be had like that CB500 that are a bit older but no worse.
cdlxxvi
PostPosted: 18:08 - 08 Jul 2012    Post subject: Reply with quote
cdlxxvi
PostPosted: 18:17 - 08 Jul 2012    Post subject: Reply with quote
Amreet
PostPosted: 18:57 - 08 Jul 2012    Post subject: Reply with quote
no it's not actually about statistics mate! They are broad brush strokes which are not whatsoever representative of the effect of age alone. a 10 year old CAR is VERY unlikely to have a sympathetic owner! Most cars of over 10 years are bought as cheap hacks, run into the ground and scrapped when they fail an mot. Most car owners run their cars as pure appliances, whereas bikers on the whole tend to be more 'enthusiast' type owners who actually make an effort to take care of their bikes.
I doubt very much that those stats are the same for bikes. Also some 10 year old bikes are far more likely to fail an mot than others given the same amount of time and the same standard of ownership and care. a 3 year old CBR that's been ragged and abused is more likely to fail an MOT than a 1959 Velocette that has been cherished by it's owner.
What happens when your five year old bike becomes a ten year old one? will it suddenly start failing MOTs? will you chop it in and waste 2k on another bland commuter? just based on stats?
The cost of self servicing is low and the 'profit' over dealer servicing is vast. Go call up a dealer and ask for the cost of new chain/sprockets, oil and filter change, air filter change and new spark plugs.
You could do those jobs with the original toolkit supplied with the bike or with a single socket/spanner set, find out what mechanics charge per hour. then take into consideration your lack of mechanical understanding or sympathy when you don't understand what the servicing means. You could do all those jobs in an afternoon, maybe take a whole day if you've never held a spanner before. but could save you 2/300 quid, which you can then reinvest in upgrades and repairs, leading to savings, more mechanical sympathy, and a higher quality machine.
but, it's your money, do as you wish. I don't see any argument whatsoever other than laziness for not servicing your own bike, especially something simple like a CB500, and a whole heap of disadvantages.
The thing is, it will take a lot of stuff to break before the price difference between the CB500 and the KLE is spent, many years (more years than it would take for the KLE to reach your 10 year cut off point) and honestly, there is a healthy chance that the KLE could well cost more money to run than the CB500 because the CB has a far better rep for build quality, parts availability (new and second hand) far more of them about in this country etc. etc.
basically, your view seems very black and white/narrow minded. See the bigger picture for a minute, do the sums and work out what your options are. well, that is what i would do, but i don't particularly give a toss seeing as it's your money Laughing
cdlxxvi
PostPosted: 21:38 - 08 Jul 2012    Post subject: Reply with quote
PostPosted: 11:45 - 09 Jul 2012    Post subject: Reply with quote
Parts do not wear out if they are not being used.
Wear on parts is proportional to mileage, not age.
I will not be commenting further and all my previous comments still stand. By insisting on a bike of less than five years old, you are denying yourself the chance of a bargain.
I would also say you are slightly silly restricting yourself to local bikes. Widen your search area, be prepared to travel some distance to get the right bike
cdlxxvi
PostPosted: 16:22 - 09 Jul 2012    Post subject: Reply with quote
The last post was made 13 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 124.14 Kb
