| bunglehaze |
 bunglehaze Brolly Dolly
 Posted: 13:19 - 07 Jul 2012 Post subject: Adjustable handlebar position and effects |
JUst a quick question really.
I fitted a set of convertibars to my ZX10R as part of a review and although the range of adjustment for my particular bike is reduced because of fairing clearance it has allowed a more forward position rather than tight and angled.
The other day I was out and having fun, I cranked it over on a right hander and felt oddly unstable, almost as if the front dropped in too quickly or was ready to tuck, it didn't but it made me think.
My personal circumstance is that I am a big bloke in terms of width and weight, but only 5' 11". I tend to feel slightly disconnected from my bike at high speeds sometimes, I can't explain the feeling other than that, but almost as though I need to be MORE tucked up.
To my mind a set of adjustable handlebars along with rearsets would allow a much more 'custom' fit for my shape so I assumed that straightening out the bar horizontally a touch, as well as reducing the down angle (I cant tuck as much as a 10-13 stone rider thanks to my gut) would put more further forward, only a little though.
On my ride i found this was about right, having to adjust my mirrors for the change clearly puts more of my weight over the front, it actually feels no better than the previous position in terms of the slightly disconnected feeling I had but this could just be because I am not used to the dynamic of the bike with this minor change. I would say that the bars are forward by about 2cm's and the downward angle reduced by perhaps 10 degrees.
So, those of you who know about steering, suspension and the technical setup, if I am looking to feel more connected, more tucked if you will, should I be looking to put the bars back to their original position and get rearsets adjusted instead.
The feeling of a fast 'drop' when I took the right hander, could this be an actual instability caused by my minor adjustment or more likely I am just not used to that particular setting and feedback?
I don't hang off, I just struggle to do it actually, I want to push this bike a bit more and teach myself to but want to get my own positioning feeling 'right' before I start pushing to the next level.
thanks ____________________ https://bikechatter.net
Motorcycle Products Reviews and News
06 - ZZR600 > 07 - ZX6R J1 > 08 - ZX6R J2 > 09 - ZX636 A1P > 11 - ZX10R C1H |
| Barnaby |
 Barnaby Banned
| Walloper |
 Walloper Super Spammer
| bunglehaze |
| bunglehaze |
| Barnaby |
 Barnaby Banned
| bunglehaze |
| WannaBeDude |
 WannaBeDude World Chat Champion
| Barnaby |
 Barnaby Banned
| lihp |
 lihp World Chat Champion
| anthony_r6 |
 anthony_r6 World Chat Champion
| Walloper |
| jetski |
 jetski Scooby Slapper
| jetski |
| U_W v2.0 |
 U_W v2.0 World Chat Champion
| bunglehaze |
 Posted: 11:37 - 09 Jul 2012 Post subject: |
| Barnaby wrote: | | covdude wrote: |
Cunt .. Your doing the cunt bit wrong. |
I don't think that I am.
Some TWAT is asking us how he should 'sit' on his rocketship. I am merely pointing out the obvious, that maybe a Zx10R is a little bit above & beyond the OP's current capabilities.
These, experiments, should have been sorted already, on the path that gets you to a place where you can handle a rocketship, don't you think? |
Oh please stop, some anonymous, faceless, oddly aggressive and it would seem either illiterate or dense forum troll is calling me names - how this hurts.
First of all, read the post, then comment or you run the risk of coming across like a bit of a twat yourself really.
Nowhere did I ask for advice on where to sit on my 'rocketship', I do that well enough thanks on my own. Like every bike before I have tweaked it to suit my preference - why should my ZX10R be any different and why would my feeling disconnected from this bike be down to me not being 'ready' for it?
Can you tell me if the back or front ends have been adjusted on this bike by the last owner - erm, no. Therefore the way each bike feels is going to be different from the last and each rider should take the time to try and figure out what needs changing to suit.
@phildawson - thanks. The convertibars in my case have not really been raised, merely the angles reduced. My thinking there was that if I have a 30" shoulder width I should be looking to have my bars setup slightly differently to the rider it was designed around perhaps only having 22" width.
My arms are no longer than standard, nor are my legs so I tried setting the convertibars at the same height to give the same reach but due to the steering damper on this bike could only fit them in the forward position - thus extending my reach, and with it my body position.
Dilligaf_no - again, thanks I will look it up and see.
Interestingly I got someone on my bike who has the same model, he felt the original bars were slightly higher up than his. I do run my suspension a lot harder than most to deal with 18+stone of me bouncing along so perhaps that has something to do with it.
In any case, I think I am going to try getting my rearsets about an inch back and have the bars as they are now, a touch more forward than stock and see what difference that would make.
If adding a couple of centimeters reach towards the front of the bike has made it feel a little more unsettled but no more tucked up, adding a little more rearwards reach in the rearsets should (in theory) put me back in a similar, more neutral position and perhaps get my centre of gravity back where it should be?
Or would it?
cheers folks. ____________________ https://bikechatter.net
| lihp |
| bunglehaze |
 Posted: 15:37 - 12 Jul 2012 Post subject: |
I had a decent ride yesterday and oddly it felt fantastic, no hint of the front tucking. I think it may have just been a difference in the feedback was being processed by my brain as negative, no massive surprise after I had done 250 miles on it a few days before and then 150 after fitting the convertibars
cheers guys. ____________________ https://bikechatter.net
The last post was made 13 years, 233 days ago. Instead of replying here, would creating a new thread be more useful? |
