Yamaha RXS 100 Rebuild/ Restoration.
Stevey
PostPosted: 21:27 - 09 Jul 2012    Post subject: Yamaha RXS 100 Rebuild/ Restoration. Reply with quote
Hello all. First proper post and my first proper bike. Shall be my project over this summer.
This thread will be me documenting the repairs and hopefully having my questions answered. Thumbs Up
Right, bought the bike on Sunday from a nice local trader for only a few quid. He was honest and said it was in need of repair as it has been abused and unloved.
So enough tell, time for some show:
https://i1258.photobucket.com/albums/ii537/Stevey94/DSCF2738.jpg
https://i1258.photobucket.com/albums/ii537/Stevey94/DSCF2707.jpg
https://i1258.photobucket.com/albums/ii537/Stevey94/DSCF2718.jpg
How it looked when I got it home.
Plans are to strip down and clean, replace and rebuild into a working bike. Atm the engine is seized, forks are bent, bodywork is tatty, tank dented etc.
Firstly washed the bike then took seat and tank off.
https://i1258.photobucket.com/albums/ii537/Stevey94/DSCF2739.jpg
That is pretty much all I got done today. My mechanical skills are basic and my knowledge more so.
A couple of questions, under the right hand panel there is this black box...
https://i1258.photobucket.com/albums/ii537/Stevey94/DSCF2751.jpg
Feel like there is something missing?
https://i1258.photobucket.com/albums/ii537/Stevey94/DSCF2755.jpg
Also here what does this black tube do? It runs into the carb so maybe an air intake/ box/ filter?
One last thing for now:
https://i1258.photobucket.com/albums/ii537/Stevey94/DSCF2732.jpg
https://i1258.photobucket.com/albums/ii537/Stevey94/DSCF2735.jpg
Many bolts are like this, what tool would you recommend please.
Thank you for reading, I am very excited with this bike but do feel a bit apprehensive about most things. Any tips and advice are appreciated. Haynes manual is in the post. Will update as and when progress is made.
Steve.
Ham Toucher
PostPosted: 21:37 - 09 Jul 2012    Post subject: Re: Yamaha RXS 100 Rebuild/ Restoration. Reply with quote
https://www.ebay.co.uk/itm/5-PIECE-PCE-DAMGED-SCREW-EXTRACTOR-CASE-BOLT-SCREW-STUD-REMOVER-EASY-OUT-/160832214896?pt=UK_Hand_Tools_Equipment&hash=item257258d770
nfo
PostPosted: 09:12 - 10 Jul 2012    Post subject: Reply with quote
Looks like a good project, not too far gone but plenty to get your teeth into. Not dissimilar condition to the Honda I'm fixing up, with a similar intent (not strictly 'restoration').
I think the black box is to keep your sandwiches in Wink
Mar's Law: Everything is linear if plotted log-log with a fat magic marker.
1975 CB125S 'repair and tidy up' project thread here...
PostPosted: 09:37 - 10 Jul 2012    Post subject: Re: Yamaha RXS 100 Rebuild/ Restoration. Reply with quote
Ham Toucher wrote:
These will cause you more trouble than they are worth, Buy an impact driver then if that fails chisel the head off and when you take the casing off use some mole grips.
Yambits is a great website and you will spend a fortune there.
symonh2000
PostPosted: 12:28 - 10 Jul 2012    Post subject: Reply with quote
Looks like a good project. I like RXS's.
My one needs a bit of tidying when time allows.
I am going to replace the casing screws with stainless steel socket head items.
Four strokes is two strokes too many.
Stevey
PostPosted: 14:10 - 10 Jul 2012    Post subject: Reply with quote
Thank you for the replies. Bought an impact driver this morning and have undone a couple of the screw bolts.
Now I am having problems getting the hex bolts off. Tried using a variety of spanners and also sockets in my drill... They won't budge.
Any suggestions please, should I be using the impact driver for these as well?
Current: 50cc Suzuki scooter.
Project: Yamaha RXS 100
symonh2000
PostPosted: 14:41 - 10 Jul 2012    Post subject: Reply with quote
6 sided sockets, and plus gas should get most of the bolts undone.
I also have a set of Metrinch spanners or nuts that have rounded corners.
nfo
PostPosted: 15:05 - 10 Jul 2012    Post subject: Reply with quote
Plus Gas and perseverance, if in doubt swear at it a bit Thumbs Up
symonh2000
PostPosted: 15:08 - 10 Jul 2012    Post subject: Reply with quote
Another way of getting out rounded screws it to tap the screw around with a center punch or similar. Just be careful not to slip and damage the casings.
daverwheeler
PostPosted: 17:00 - 10 Jul 2012    Post subject: Reply with quote
Use an impact driver first, if that fails, the best way to deal with the rounded cross head screws is to carefully drill the head off, then use mole grips when the casing is off.
Much safer than trying to chisel or knock them round, too easy to clobber and damage the alloy casings.
Invest in some good quality sharp drills, and set the drill to the right speed.
Be wary of those easi-out extractors, they are usually made of very hard, but very brittle crap, so snap one off and you cant drill it out.
Stevey
PostPosted: 17:20 - 10 Jul 2012    Post subject: Reply with quote
Thank you, all comments are appreciated. Done a couple more hours today but not made a lot of progress. Still getting to grips with the impact driver.
Really want to get the engine and carb out and apart a.s.a.p.
Will go out tomorrow and buy some Plus gas and some decent drill bits, as have managed to snap most of mine now.
Thanks again.
daverwheeler
PostPosted: 17:34 - 10 Jul 2012    Post subject: Reply with quote
2 big mistakes people make when using drills:
1, Too much speed- the bigger the drill, the slower the speed, too fast and it won't cut and will overheat and become blunt very quickly, you can always use a drop of oil to help it cool.
2, Too much pressure -You need to keep a constant pressure on the drill, but don't force it, again it will overheat and blunt very quickly.
You'll soon learn how to get a feel for it, when you get a nice long strand of swarf ,it's cutting well.
Hope I'm not teaching you to suck eggs, just trying to save you buying bundles of drills like I did before I learned!!!
Stevey
PostPosted: 21:26 - 11 Jul 2012    Post subject: Reply with quote
The Plus Gas worked very well and I was able to get the exhaust off.
https://i1258.photobucket.com/albums/ii537/Stevey94/DSCF2780.jpg
Original? or go faster hole?
Then not able to do anything significant, just fiddled around with the levers and rear pegs.
This main engine to frame bolt is being troublesome, any hints? Would it be worth buying a set of box spanners as I can not get it too shift at all.
The other end is shagged.
https://i1258.photobucket.com/albums/ii537/Stevey94/DSCF2781.jpg
https://i1258.photobucket.com/albums/ii537/Stevey94/DSCF2785.jpg
Lack of progress is a bit demoralizing, but then this is all new to me.
Thank you.
MaybeGuy
PostPosted: 21:35 - 11 Jul 2012    Post subject: Reply with quote
Hole in the exhaust is standard and normal. It's so you can take the baffle out for repacking. You should do this, as well as decoke it.
Looks like you're failing pretty hard so far though. Make sure you're using the right tools, and replace the screws with cap headed bolts.
27cows
PostPosted: 20:22 - 17 Jul 2012    Post subject: Reply with quote
Reminds me of my RXS when I first got it. Similar condition, with the mutilated screws and bent forks. I thought it might do me till the following summer...that was in 1990 and I've still go the old relic and ride it virtually daily.
First thing to do is make absolutely sure the frame isn't bent. Those forks look like it was a minor front ender, so it should be OK. But there's no point spending money, only to find the frame's buggered.
The exhaust baffle - there's about six inches at the end of it which serve no purpose at all except to cause it to seize in the pipe. I always recommend cutting that bit off (the entirely hollow bit, before you get to the silencer disc bits).
The engine bolt needs a decent quality socket and ideally a breaker bar to get maximum leverage. If the nut has started to round off, will probably need to be broken using a nut splitter.
Without wishing to sound negative, you really need to look around and see the kind of prices you'll have to pay to get the parts you need. It's extremely easy to have costs escalate and end up spending out more than you would if you'd gone out and bought a whole bike in tidy condition. A few years ago RXS bits could be had for next to nothing. I bought a whole bike in running condition for £50 and a crashed one for 20 notes, which I used for spares. Such bargains are much less common now.
paddlesat16
PostPosted: 16:00 - 19 Jul 2012    Post subject: Reply with quote
Buy a Haynes Manual at the very least and the best tools you can afford, also get a decent socket set from somewhere like machine mart or Halfords.
Take lots of photo's and label your bits so you don't forget where your bits go.
Regards
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
mintex
PostPosted: 19:23 - 19 Jul 2012    Post subject: Reply with quote
I bought some of these to remove seized nuts/bolts, they work well too and have not failed me yet Smile
https://www.machinemart.co.uk/shop/product/details/5-piece-bolt-grip-set?da=1&TC=SRC-irwin
and this is the extension kit
https://www.machinemart.co.uk/shop/product/details/5-piece-bolt-grip-set-expansion-set
Stevey
PostPosted: 19:17 - 27 Jul 2012    Post subject: Reply with quote
Quick update, was able to put quite a few hours in this week, and had success this afternoon in removing the engine. The bike is now completely stripped and all parts are bagged and labeled.
Looking forward to cleaning and repainting the frame tomorrow.
Cheers.
symonh2000
PostPosted: 12:45 - 28 Jul 2012    Post subject: Reply with quote
One thing I will suggest is that you convert the electrics to 12v if you haven't already.
For about £35 and a couple of hours soldering and heatshrinking you will have much improved lights and indicators.
I am very pleased with my conversion.
When I got the bike the lights were very dim, and the battery was goosed. This I found out to be caused by the 6V regulator being shagged.
By the time I had bought a new regulator and 6v battery it would have been about half the cost of going all the way and changing to 12V
piazza
PostPosted: 14:39 - 28 Jul 2012    Post subject: Reply with quote
Just picked up one of these last week. Those bloody screws seem to be made of cheese mine are buggered too Evil or Very Mad Good luck with it Thumbs Up
Any info regarding a 12 volt system would be useful, I only picked this one up to fix up and sell but it's pretty good tbh and only needs a tidy and fork seals.
symonh2000
PostPosted: 17:55 - 28 Jul 2012    Post subject: Reply with quote
12v conversion video.
https://www.youtube.com/watch?v=ljDFwVgvELI&feature=youtu.be
I am sure a 12v electrical system on an RXS would be a good selling point, as that and the brakes are the bikes main weakness's
The last post was made 13 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 133.84 Kb
