Bicycle track pumps and motorcycle tires?
Derivative
PostPosted: 22:13 - 12 Jul 2012    Post subject: Bicycle track pumps and motorcycle tires? Reply with quote
I have a reasonably decent track pump used for my road bike.
Has Schrader and Presta valve, plus a pressure gauge.
Probably a monstrously obvious question I'm asking, but will it be fine for use on motorcycle tyres?
I can't see any reason why it wouldn't be, but it would be rather annoying if I ended up letting a tyre down leaving the bike stranded at my house for a bit.
Logically if a 120psi tyre can be inflated by the pump, a 30psi one should be fine, it'll just require a bit more handwork given the volume of the tyre, no?
Teflon-Mike
tl;dr
PostPosted: 22:42 - 12 Jul 2012    Post subject: Reply with quote
We used to pump motorbike tyres up with the old fasioned push-bike pumps!
https://t0.gstatic.com/images?q=tbn:ANd9GcQwKw6d_Fzhys5phfF7iZWAARfymqAohRvnxlKvrq9qQ8H5_GBR6g
Some bikes as late as the 1980's, CZ I think used to include them in the OE tool kit! Not that they were much good, as ISTR, but still!
So yeah, principle is good....
Pumping up tyres on my old pedal & pop with one kept me out of trouble for many MANY hours though! But heaven help me if I left mi grandad's foot-pump in the grass to go 'rusty' again!
D O G
PostPosted: 01:27 - 13 Jul 2012    Post subject: Reply with quote
It's absolutely no problem at all, well, apart from getting to the valve.
I use my track pump to do all tyres, even on the cars.
Im-a-Ridah
PostPosted: 06:09 - 13 Jul 2012    Post subject: Reply with quote
Yes, it will just take a bit longer if it's a smaller pump Thumbs Up
PostPosted: 14:11 - 13 Jul 2012    Post subject: Reply with quote
It'll do anything but seat a new tubeless tyre on the bead.
In fact, if it's a halfway decent trackpump, you need to watch you don't overinflate them.
Dazbo666
PostPosted: 16:08 - 13 Jul 2012    Post subject: Reply with quote
As mentioned, the only drawback might be the length of time it could take, depending on the size/capacity of the pump...
I've certainly used a track pump with a gauge in the past to keep car tyres topped up
Word of the day : DILLIGAF
Kawksam
PostPosted: 16:20 - 13 Jul 2012    Post subject: Reply with quote
I use a simple aluminium push bike pump because I got a slow puncture and not so worried of going out now.
neil.
PostPosted: 17:43 - 13 Jul 2012    Post subject: Reply with quote
I do mine with a track pump too. Thumbs Up
Derivative
PostPosted: 19:13 - 13 Jul 2012    Post subject: Reply with quote
Seemed to work fine. Bit of a struggle getting it attached to the valve on the rear tyre as the spokes get in the way. Found that my front tyre was 10psi under, so a good job I sorted that out.
PostPosted: 19:16 - 13 Jul 2012    Post subject: Reply with quote
Trackpump...but don't believe the gauge.
The last post was made 13 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 70.34 Kb
