So I got this ramp...
pooley_99
PostPosted: 20:57 - 14 Jul 2012    Post subject: So I got this ramp... Reply with quote
Just moved house, its all great apart from the location of the mancave!
Have to bring my CBR 600 up and down these steep bastards to get access !! Confused https://i1176.photobucket.com/albums/x323/pooley_99/steps.jpg
So i got this ramp which kind of does the job (easy into the shed) but its a bit sketchy up the steep steps..
https://i1176.photobucket.com/albums/x323/pooley_99/ramp.jpg
Especially when the ground is wet.
So the really dodgy bit is in the middle you can see the smooth metal - i bolted the two ramps together - and the smooth aluminium is really hard to get any grip on the back wheel going up the steep steps.
Sooo was thinking i could wrap the ramps in some kind of chicken wire or rubber type material so the wheel can stick better...
anyone have any ideas for a good material Im a bit stumped thought chicken wire at first but then thought wouldnt really help and something rubber based might be better. Question Idea
CBR 900RR Fireblade
binge
Emo Kiddy
PostPosted: 20:59 - 14 Jul 2012    Post subject: Reply with quote
Can you not brick a proper ramp in there? Like up one side of the steps.
Handsome
PostPosted: 21:00 - 14 Jul 2012    Post subject: Reply with quote
Scaff' board with thin strips of wood screwed to it width ways to aid traction, two holes drilled through the bottom to allow two tent pegs to be staked through to stop it moving... Thumbs Up
jimspeed
PostPosted: 21:08 - 14 Jul 2012    Post subject: Reply with quote
skateboard tape or grip tape on the smooth bits but I would be tempted to fill in the one side of the steps (or both sides) with a concrete slope
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
pendulum
PostPosted: 21:24 - 14 Jul 2012    Post subject: Reply with quote
Bunny hop.
1998 CG125 (Sold) CB500 [+ Clio 172]
Usually_Wrong: I tend to fail more than pass. [Speaking about Theory Practice]
Usually_Wrong: im on unemployment at the moment
Walloper
PostPosted: 21:28 - 14 Jul 2012    Post subject: Reply with quote
Simply get the hoowur up on it's back wheel to go in there.
What was the question caller?
pooley_99
PostPosted: 21:32 - 14 Jul 2012    Post subject: Reply with quote
bunny hop Very Happy
Some great ideas there, I would defo brick it up and prob move the shed too but its a rental property.. cant really do anything too permanent.
Grip tape could be the way!
CBR 900RR Fireblade
hellkat
PostPosted: 21:41 - 14 Jul 2012    Post subject: Reply with quote
Oo, the BCF Bodgett and Scarper Hour.
Cool
Cunnington
PostPosted: 22:02 - 14 Jul 2012    Post subject: Reply with quote
If you intend using anything to improve the grip, the key bit is the bond between the ramp and the grippy bit.
From experience, just wrapping mesh around the ramp will not be enough. I made a timber ramp, using decking boards as the surface, which was a bitch in the wet. After several different attempts to make it non-slip, I ended up taking the planks up and wrapping them with the light weldmesh that you use in rabbit hutches etc.. The back tyre just ripped anything else off.
Since you are onto a decent surface, try something like https://www.screwfix.com/p/no-nonsense-anti-slip-tape-50mm-x-18m-black/57217#
'82 C50, '81 CB100, '84 GS125, '95 NTV650, '00 Bandit 600, '06 SV650, '56 Z1000, '89 NTV600
The Shaggy D.A. wrote: "You are invisible. Those who can see you are trying to kill you."
KLR600
PostPosted: 22:09 - 14 Jul 2012    Post subject: Reply with quote
I'd use that stuff that is usually put on the shed roofs. Seen a lot of wooden mountain bike ramps use that stuff and it seems to do a good job.
<Take Cool Photos!>
stemc
PostPosted: 22:10 - 14 Jul 2012    Post subject: Reply with quote
I had a similar problem, and ended up using some roofing felt left over from the shed, its worked fine so far
stemc
PostPosted: 22:11 - 14 Jul 2012    Post subject: Reply with quote
Ariel Badger
Just use one ramp, I have loaded loads of bikes up a single scaffold plank.
Walloper
PostPosted: 22:12 - 14 Jul 2012    Post subject: Reply with quote
That's twice it's worked.
The last post was made 13 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 80.21 Kb
