Controlling music on motorway?
Tomzo47
PostPosted: 12:26 - 16 Jul 2012    Post subject: Controlling music on motorway? Reply with quote
Hi guys, when I'm on the motorway I like to have my Ipod on otherwise the boredom will make me insane. Only problem is I can't concentrate very well when I have to (filtering through traffic or when leaving the motorway and going onto normal roads etc) so have to pull into a service station to turn it off. Is there anything I can get to control it while riding, cable with controls or handlebar mounted or something? cheers Smile
Ybr 125 > Bandit 650SA > GSXR 600 > Triumph Sprint St1050 > CB1300 > Z1000SX + FJ1200 (written off) > VFR750 >FJ1200
skylineonfire
PostPosted: 12:34 - 16 Jul 2012    Post subject: Re: Controlling music on motorway? Reply with quote
Controls on your cable would work. Mine have a button, press once to pause, twice in quick succession to skip track, three times in quick succession to go back a track. Simples. Sits out above my jacket, easily reachable with gloves etc...
hellbound
PostPosted: 12:43 - 16 Jul 2012    Post subject: Reply with quote
if you have money to burn.....
https://www.burton.com/mens-gloves-mitts-mix-master-glove/254382,default,pd.html
May you always see the road rising up to meet you and your enemies defeated in the mirror behind.
map
Mr Calendar
PostPosted: 12:45 - 16 Jul 2012    Post subject: Reply with quote
I can think of two techie options but they're more generic rather than specific iPod.
(1)
Get a waterproof case and mount on handlebars. Some available with their own locking system (see eBay) or you could try for one with a RAM mount (more flexible for mounting other stuff). Case will have hole for 'phones and you should be able to press the controls through the case cover (stop/pause at least). Example from amazon click here.
(2)
Get a bluetooth headset for your helmet and a bluetooth transmitter for the iPod (fits in 3.5mm socket, again see eBay then see if cheaper elsewhere). The Chinese kit is affordable rather than spending lots on Scala, Interphone, etc. kit. Then can just adjust volume etc. on side of helmet. You can also transfer it to different helmet if needed. Get one with A2DP protocol for music. Early/cheaper versions don't have this and so only talk to mobile phones.
I am currently searching through and about to order headset so I can use Sony Walkman MP3 (it has build in bluetooth, not sure about iPods).
Controls on the cable sounds fiddly and a bit hard with bike gloves but I'm prepared to be proved wrong on that.
HTH Thumbs Up
Walloper This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
Snorty
PostPosted: 13:14 - 16 Jul 2012    Post subject: Reply with quote
I just pull my glove off, put my hand in my pocket and skip through tracks/pause/etc as required.
map
Mr Calendar
PostPosted: 13:18 - 16 Jul 2012    Post subject: Reply with quote
Walloper wrote:
My Schuberth C3 (cnut of a thing) has the bluetooth collar fitted...to do this from scratch would set you back 400 for the hat and 300 for the collar....
Which is why for a similar solution (maybe not auto volume, manual though) I suggest looking on the likes of eBay or even amazon.co.uk for the Chinese sourced kit. Apparently this gets good reviews and even if it does go wrong you could buy 4 or 5 sets compared to the likes of Scala. Although that Scala from the amazon link does look value at £65 provided you can control volume, tracks, etc.
..err...
Hairy Tom wrote:
Hi guys, when I'm on the motorway...when leaving the motorwa...
Try doing that glove trick on the motorway then Rolling Eyes Sounds like a really good idea Folded arms
Walloper
PostPosted: 13:24 - 16 Jul 2012    Post subject: Reply with quote
map wrote:
..err...
Fhip... That's the sound made by a glove when it is whipped out from under one's arm by the wind at 70MPH. Very Happy
Tomzo47
PostPosted: 13:40 - 16 Jul 2012    Post subject: Reply with quote
Thanks guys, some good suggestions Smile should have said my budget is about £20 so a new lid is a bit unlikely Sad will have a look into one of those handlebar mounts Thumbs Up
Walloper
PostPosted: 13:53 - 16 Jul 2012    Post subject: Reply with quote
£20 is not a budget man. That's an allowance. Smile
Can you not save up for a few weeks? You'll regret it if you can't wait and then buy kak
Snorty
PostPosted: 13:56 - 16 Jul 2012    Post subject: Reply with quote
I do it on the motorway all the time.
Either: stick the glove in the grip of your throttle hand and just hold tight. Or stick it on top of the clocks behind the screen. Even better, get rid of the iPod get a cheapy cheap USB player with very defined buttons you can press through the pockets.
PostPosted: 14:22 - 16 Jul 2012    Post subject: Reply with quote
Attach something like this to your bike.
https://www.amazon.com/Satechi-MediaRemote-Bluetooth-Multi-Media-Control/dp/B00824948U
MightyZoltar
PostPosted: 14:52 - 16 Jul 2012    Post subject: Reply with quote
I decided to get an MP3 player specifically for on the bike recently. Was using an iPod nano, which died.
I've got a Sony player now, in the USB stick style. Clips to the outside of my jacket, down somewhat low so the bike screen protects it. Has a wheel to change tracks, and the play/pause button is a good size.
Charges up pretty quickly, with 90 minutes playback from a couple of minutes charge, which is excellent.
Dean-J
PostPosted: 15:28 - 16 Jul 2012    Post subject: Reply with quote
Am i the only one who thinks if you cant concentrate on riding with music on then you should stop listening to fucking music full stop???
I mean seriously, do you have to turn your stereo off in the car when you leave the motorway?
MTFU
Rolling Eyes
Tomzo47
PostPosted: 16:11 - 16 Jul 2012    Post subject: Reply with quote
MTFU
Rolling Eyes
No but you can turn it down, to listen to music on the motorway with my helmet/shit screen you have to have it on full blast to hear it, which isn't the best thing to do while filtering
fatjames
PostPosted: 16:28 - 16 Jul 2012    Post subject: Reply with quote
MTFU
Rolling Eyes
Nah, I don't agree. I find I need more concentration off the motorway due to more people and traffic lights etc, and there is less wind noise so music sounds louder.
Dean-J
PostPosted: 17:56 - 16 Jul 2012    Post subject: Reply with quote
You need one of the following: a) better helmets b) louder bikes c) better earplugs
i can listen to dubstep at full whack wherever im riding and it never causes me any issues. I can also have it on relatively quietly at any speed and its perfectly listenable.
My point was serious by the way, if you cant concentrate fully with loud music on, then chances are your not giving 100% attention at lower volumes either.
Tomzo47
PostPosted: 18:16 - 16 Jul 2012    Post subject: Reply with quote
its not the concentration thats the problem, its not being able to hear what goes on around you, when filtering all sorts can happen and I like being able to hear it, and when I'm going 70+ then the shite Bandit screen is ridiculously loud so music has to be on full
skylineonfire
PostPosted: 18:24 - 16 Jul 2012    Post subject: Reply with quote
HTH Thumbs Up
Well it's a big button, and it's easy enough with my summer gloves, which are pretty nice leather/kevlar knuckle things, as they aren't too thick. In big thick winter gloves, not a chance like you said.
iooi
PostPosted: 20:08 - 16 Jul 2012    Post subject: Reply with quote
The answer is simple my friend..
Get a bluetooth set up. You then have gloved sized buttons to be able to adjust the volume as you go along. Karma
Louise
PostPosted: 22:38 - 16 Jul 2012    Post subject: Reply with quote
Most of my tracks are trance/dance music which i listen to all the time.
I find, if a certian music track makes me ride faster / unable to concentrate then I move it to a different playlist.
I also have a button to pause the music if I wish...
_matt
PostPosted: 00:22 - 17 Jul 2012    Post subject: Reply with quote
you can hear an ipod when riding above 20mph? how in the hell...
1990 Yamaha XV 535 (Alive Again!) / 2007 Jinlun Texan 125-11 (formerly 2k3, wrong details, now going rusty in the back garden )
Redoko
PostPosted: 00:26 - 17 Jul 2012    Post subject: Reply with quote
In ear headphones.
Noise cancelation.
iooi
PostPosted: 08:51 - 17 Jul 2012    Post subject: Reply with quote
I can hold a phone conversation @ trackday speeds with no issue. Thumbs Up As well as listen to music/audio books etc Laughing
Its all in having a white helmet Wink
map
Mr Calendar
PostPosted: 09:19 - 17 Jul 2012    Post subject: Reply with quote
That sounds a bit cheesy Wink
The last post was made 13 years, 353 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 3.62 - MySQL Queries: 13 - Page Size: 136.91 Kb
