| Matt- |
 Matt- World Chat Champion
| Amreet |
 Amreet Trackday Trickster
| Matt- |
| Amreet |
| RSnoobie |
 RSnoobie L Plate Warrior
 Posted: 18:34 - 19 Jul 2012 Post subject: |
TZR is a good choice, they are fast bikes and in my opinion the most reliable single cylinder two strokes. It shouldn't take long to find information on rebuilding on the web, you might even be able to find a manual for engine rebuilds i don't know.
As for year i would try maybe 97 98 models, they have power valve i know that.
Goodluck anyway  ____________________ Current Ride: Aprilia RS 125 fp '00 |
| Drake |
 Drake World Chat Champion
 Posted: 18:42 - 19 Jul 2012 Post subject: |
why not get a 250? ____________________ was: derbi senda, aprilia sx125, nsr250 mc16, cagiva mito, cb600 hornet now: mk1 bandit, KR1S, landrover series 3 light weight 2.5 petrol, 5speed box |
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 18:43 - 19 Jul 2012 Post subject: |
I've got a tank you can have, just pay the postage, PM me if you're interested. ____________________ "Everybody needs money, that's why they call it money!"  |
| Matt- |
| T0MMY |
 T0MMY World Chat Champion
 Posted: 19:19 - 19 Jul 2012 Post subject: |
I used to have one of the older ones (late 80s one). Good bike I thought but then I had nothing to compare it to but my TS50X.
Just to clarify they all have powervalves but not all have the servo to open it on the fly. Without it you can still open the powervalve but you'll have bugger all low down torque as it'll be open all the time. You will get the full top end though...maybe 90mph or so?
I did rebuild mine but I really can't remember much about it plus I was utterly clueless back then. I pretty much took it apart for the hell of it as I recall...it was still running  ____________________ ZX6R + CBR600RR |
| Barnaby |
 Barnaby Banned
| Matt- |
| symonh2000 |
 symonh2000 Crazy Courier
| Matt- |
| WannaBeDude |
 WannaBeDude World Chat Champion
 Posted: 21:45 - 19 Jul 2012 Post subject: |
Do a mito mk 1 7 speed 35 mm carb ...  ____________________ Jogging on, destination living. |
| Matt- |
| cloric_tzr |
 cloric_tzr Brolly Dolly
 Posted: 21:52 - 19 Jul 2012 Post subject: |
i got a tzr rebuilt it 2wice, im taking it into work next saterday to finish her off, (project has ended up spanning a year and a half due to me son being born) ill get some pics uploaded, there is a thread somwhere,
really simple bikes to work on i picked my up for £300. powervalve open fully did a ton, ive bore'd her out now so be intresting to see how fast she goes, biggest issue was the crank seal was leaking gearbox oil into my bottom end causing a lot of smoke and fouling on the plug, im going to be selling mine i think when shes done, i want a suzuki rg or a mito, ill have a spare haynes book of lie's for a 88' tzr if you do end getting one i dont mind passing it on, it was pricless for specs and tollerance for the re-bore things like that. ____________________ i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection. |
| Matt- |
 Posted: 21:57 - 19 Jul 2012 Post subject: |
| cloric_tzr wrote: | i got a tzr rebuilt it 2wice, im taking it into work next saterday to finish her off, (project has ended up spanning a year and a half due to me son being born) ill get some pics uploaded, there is a thread somwhere,
really simple bikes to work on i picked my up for £300. powervalve open fully did a ton, ive bore'd her out now so be intresting to see how fast she goes, biggest issue was the crank seal was leaking gearbox oil into my bottom end causing a lot of smoke and fouling on the plug, im going to be selling mine i think when shes done, i want a suzuki rg or a mito, ill have a spare haynes book of lie's for a 88' tzr if you do end getting one i dont mind passing it on, it was pricless for specs and tollerance for the re-bore things like that. |
At last someone who owns a TZR...
Yeah im looking to spend around £400 For a TZR if it runs i'l ride it for a while then rebuild it...
Sounds great when i get one, i will also have it fully open, got any rebuild knowledge you can pass on to me? i really don't know where to start with the bottom end :/ |
| Old Git Racing |
 Old Git Racing World Chat Champion
 Posted: 23:19 - 19 Jul 2012 Post subject: |
Get aTZR 125 as a project, then build it exactly as it was when it left the factory, cos they were good bikes to start with.
1st step, get everything as it should be, i.e. blue print it. match barrels to cases, get rid of the big stepand blunt edges in the inlet and gas flow it like it's supposed to be, check powervalve opening and closing times, piston to bore clearance, end gap etc.
Then get the crank out, dynamicaly balance it after checking end float, bearing condition etc.
Assemble the engine dry on a bench and stick some solder down the plug hole and check squish clearance (with head gasket and head torqued down correctly), machine the head to get the spec clearance.
Check port heights and matching of ports to cylinder liner, adjust to suit.
Check ignition timing and carburation.
Do all this and get an engine that should be as originally designed and to spec but totally standard and see the benefits.
Then start changing things that really matter (stage 3 cylinder heads aint included here) and with a lot of work and knowledge you might just get it to run better than standard.
Alternatively just give the engine to someone like Mick Abbey or another bloke who understands strokers, who will do it for you for a few quid and do a really good job.
Seemples init?
OGR ____________________ 2022 Tiger Sport 660 2019 Street Twin 2003 K3 gixxer 1000 1998 Srad 600 track hack |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 23:42 - 19 Jul 2012 Post subject: |
| Drake wrote: | why not get a 250? |
You never answered Drakes question..... why not a 250?
Talk of RS's and Mitos, suggests you are only interested in 125's.... which hints you dont have a full licence.......
Must presume you are aware of the implications of riding a 125 that makes more than 14.5bhp on a learner licence......
Might also presume you have some notion of the enormity of taking on a 'project-bike', both costs and time... it ent quick, it ent cheap...
Done three in the last two years; detail renovation of Girlfreinds 125 Super-Dream, took almost exactly a year of concerted effort and over £2K in hard cash.
Did an old air-cooled drum brake DT, for giggles, took nine months and £1500......
Its no small task..... and given costs of renovating a two-smoke vs the prices they fetch...... talking £500 engine rebuilds, you are not talking 'cheap' tart-up, and a bike likely to realise what it cost you when done, very easily.
Food for thought..... But to chuck into the pondering..... ARE you aware that the licence system changes from January?
3rd Directive Licence Laws / Impending Licence Changes
From then, you wont be able to test on a 125 for anything BUT an A1 125 'only' licence, while age for DAS goes up to 24.....
If you have ideas of doing up a tiddler for shit&giggles and getting a licence...... by time bikes 'done' might not be much use to you.
Personally, having 'done it' and spent shit loads of cash to rebuild a few tiddlers..... I would stongly suggest some thinking outside the box.
To get on the road and get a licence, I would, right now be looking at a 'ready to go' rider of a 125, rather than a project.... anything with tax and test and able to do 62mph will do..... and work towards the licence, either 33bhp restrict or full A via DAS.
For a project bike? I'd be looking long term to something I would be more likely to get more use from post test.... a bike that I would be less likely to get bored or frustrated by, when full licence would allow so much more, because a 90mph may be 'fast' and quite exiting on L-Plates.... but is rather pedestrian when you could have an SV650 or CBR600 or any number of other 'big-bikes' that are genuinely 'fast' and would beat the TZR to its top speed without getting out of third gear!
Even more frustrating if you have a bike that's cost you a couple of grand to build, but worth barely half, if you sold, but even that would buy you bikes almost twice as quick.....
Given your circumstances; I'd ponder an older 'classic' smoker as a project, something more likely to command more of your build cost when done..... something like the TZR250, or an RD-LC or 'valve'.... OR something completely different......
What I wouldn't do, is invest TOO much into a fairly quixotic 125; financially, physically; emotionally or aspirationally, that is likely to be unable to fullfill them, or only fullfil them fleetingly. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Matt- |
 Posted: 13:27 - 20 Jul 2012 Post subject: |
| Old Git Racing wrote: | Get aTZR 125 as a project, then build it exactly as it was when it left the factory, cos they were good bikes to start with.
Seemples init?
OGR |
Thanks for That im prob's going to pay for someone else to do the job to be honest, don't want to invest lots of pound's in something i could fuck up, if anyone knows anyone if they could tell em that would be great ! |
| Korn |
 Korn Admin
| Drake |
 Posted: 16:13 - 20 Jul 2012 Post subject: |
| SomeGuyy wrote: |
engine build arent that hard tbh, take lots of pictures and you will be fine, get a manual for torque settings and you will be fine. be methodical and save money.
and also if you have any problems ring or send mick abbey a message, hes always willing to help ____________________ was: derbi senda, aprilia sx125, nsr250 mc16, cagiva mito, cb600 hornet now: mk1 bandit, KR1S, landrover series 3 light weight 2.5 petrol, 5speed box |
| symonh2000 |
| Kickstart |
 Kickstart The Oracle
| Barnaby |
 Barnaby Banned
 Posted: 18:11 - 20 Jul 2012 Post subject: |
| Drake wrote: |
and also if you have any problems ring or send mick abbey a message, hes always willing to help |
Not true.
Engine rebuilds aren't 'that hard' for anyone who's never done one & therefore never needed to rely on a good result.
To the uninitiated, something as basically simple as stripping out the crank is unbelievably easy. Only the initiated would think to mark & tag the shell bearings.
You did mark & tag those shell bearings didn't you? Never mind, I suppose it will all fit back together, & at least, work long enuff for you to sell it.
Not knowing is far, far more dangerous than knowing, yet not giving a toss. ____________________ "I don't hate the Welsh, I pity them. Even the Scots & the Irish look down on them." Anon. |
The last post was made 13 years, 181 days ago. Instead of replying here, would creating a new thread be more useful? |
