Car help
shereen
PostPosted: 17:13 - 31 Jul 2012    Post subject: Car help Reply with quote
My mum (no pictures!!) just got home and said the blower inside her car wont turn off when the key is removed.
I have checked and she is correct. Its a Mercedes E200 02 reg. Anyone know how to turn it off as we dont want the battery to die and what the problem could be?
Thanks!
Ariel Badger
PostPosted: 17:19 - 31 Jul 2012    Post subject: Reply with quote
Have a look at the fuse diagram on the fuse box and pull the fuse for it.
shereen
PostPosted: 17:45 - 31 Jul 2012    Post subject: Reply with quote
Uh huh....... So that would be under the bonnet I would imagine Thinking
Clanger
Stirrer
PostPosted: 17:49 - 31 Jul 2012    Post subject: Reply with quote
https://wiki.answers.com/Q/Where_is_fuse_box_Mercedes_e200
Skudd
Or behind the glove box, you will need to take it out. As a quick fix disconnect the battery until you find the fuse.
shereen
PostPosted: 17:54 - 31 Jul 2012    Post subject: Reply with quote
Wiki fail - does not have answer Laughing
Ok, Mr Shereen has just got home and is dealing with it Mr. Green
shereen
PostPosted: 18:41 - 31 Jul 2012    Post subject: Reply with quote
Still need help peoples, Mr Shereen pulled all the relevant fuses out and the blower is still blowing Thumbs Down
Breakdown wont come out until the battery has run flat because it is not classed as a breakdown. But when the battery runs flat the alarm will shit itself and go off.
Short of disconnecting the battery, is there anything else we should be doing?
Clanger
Stirrer
PostPosted: 18:46 - 31 Jul 2012    Post subject: Reply with quote
How about disconnecting the battery, counting to 10 then reconnecting it...and seeing if that does the trick??
Sorry about the duff wiki-leak...I didn't go through it to check. Wink
Skudd
PostPosted: 19:22 - 31 Jul 2012    Post subject: Reply with quote
Had a quick look at the Merc web site and it looks like your regulator/resister for the blower has gone defunked.
shereen
PostPosted: 07:29 - 01 Aug 2012    Post subject: Reply with quote
Well the mother goes to start car this morning, and battery is dead. At least we can call the breakdown people out now Laughing
Nexus Icon
PostPosted: 12:25 - 01 Aug 2012    Post subject: Reply with quote
Neutral
Greetings from Shitsville!
scorps
PostPosted: 14:08 - 01 Aug 2012    Post subject: grrr Reply with quote
I fecking hate the newer cars. I remember when you didnt have to have a degree in mechanical engineering and be a contortionist just to do simple things like changing bulbs. The older cars were so much more owner friendly. I reckon its all down to the EU sneaking in the having to take it to a garage milarky but by stealth.
Do not presume that I am male.
Boxing
PostPosted: 14:54 - 01 Aug 2012    Post subject: Reply with quote
Hmm... disconnecting the battery will also set the alarm off. Do it in the daylight, then it can go off for an hour or two, without it being illegal. The little watch battery it runs on will go out in an hour or two. Thumbs Up
The last post was made 13 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 78.09 Kb
