Swivel stand?
EazyDuz
PostPosted: 09:46 - 08 Aug 2012    Post subject: Swivel stand? Reply with quote
Do such things exist?
Im looking for some kind of stand which rotates, basically to make it a lot easier to get the bike out the garage. I have a pebble drive with 4 cars on it so there is no space, i have to wheel the bike back and forward until i can roll it onto the neighbours tarmac drive (asked her permission to use it)
So i was looking for something which will swing the bike round in the garage so i can ride it straight out.
Thanks
DrDonnyBrago
PostPosted: 09:56 - 08 Aug 2012    Post subject: Re: Swivel stand? Reply with quote
If you have a centre stand - google "lazy susan bearing".
It is basically a big round bearing, mount both surfaces to a piece of ply wood, put bike on centre stand on the bearing/ply wood and you can spin the whole thing using the bearings. If you are less creative:
https://www.turnabike.com/wp-content/uploads/tabsequence02.gif
https://www.ebay.co.uk/itm/motorcycle-turntable-/230834595497?pt=UK_Motorcycle_Parts&hash=item35bed066a9#ht_312wt_76
https://www.driveawaymat.co.uk/7.html
If you don't have a centre stand, there are things you can do with castors, wheeled dollies etc. IIRC Marki rigged up something to spin a big cruiser around with.
https://www.bikechatforums.com/viewtopic.php?t=221669
PostPosted: 09:59 - 08 Aug 2012    Post subject: Reply with quote
Cant you park backwards and ride out forwards onto tarmac?
Zen Dog
PostPosted: 10:03 - 08 Aug 2012    Post subject: Reply with quote
I believe you can get them. But have you tried this -
Rotating a bike on the sidestand.
Its a little bit tricky to do it the first couple of times, but one you've got it, its easy. I use it all the time.
Zen Dog
DrDonnyBrago
PostPosted: 10:06 - 08 Aug 2012    Post subject: Reply with quote
Zen Dog
My side stand bracket is looking a little fragile after doing that a few times.
Not to mention I've drilled a few holes in the driveway Wink .
Teflon-Mike
tl;dr
PostPosted: 10:11 - 08 Aug 2012    Post subject: Reply with quote
Easy, your garage isn't wide enough to swing a bike through 360 degrees inside!
What you need to do is roll it out onto the gravel, then do a 'half' Donut. Wink
map
Mr Calendar
PostPosted: 10:18 - 08 Aug 2012    Post subject: Reply with quote
Google search for motorcyclke turntable brings upo some interesting results...
There is the turn a bike as shown above.
The MAT looks like a variation of the turn a bike.
Motor Works, mainly BMW bits aslo have a couple listed at £54 for small and the large (MAT?) at £96.
However Motorbike Turntable looks like the instructions for a DIY version as also mentioned above (sadly USA parts, same may require searching for UK source).
map
Mr Calendar
PostPosted: 10:20 - 08 Aug 2012    Post subject: Reply with quote
Sorry to be off topic but I have to nominate this as shortest post by Teflon-Mike ever! Shocked
I'd have at least expected a four page essay on how to perform the best donut Wink
Zen Dog
PostPosted: 10:21 - 08 Aug 2012    Post subject: Reply with quote
Really? Its never been a problem on any of the bikes I've tried. Also, people I know in the trade use it to move bikes all the time, even big cruisers etc., and i've never heard of anyone having a problem. Sure you're not just paranoid? Wink
You are right about drilling holes though, done that a few times myself. But then if you're on tarmac, a sidestand puck is what, a couple of quid?
Zen Dog
soforene This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
EazyDuz
PostPosted: 10:43 - 08 Aug 2012    Post subject: Reply with quote
True, i just thought it would help turn the bike mostly the right way, so im not fannying about rocking it forwards and backwards on the stones.
Very early post from you Mike, what woke you up? Very Happy
mfactor
PostPosted: 10:52 - 08 Aug 2012    Post subject: Reply with quote
Yep learned the sidestand turn in the trade years ago , never had a problem Smile
DrDonnyBrago
PostPosted: 10:57 - 08 Aug 2012    Post subject: Reply with quote
It's very possible, but it is slightly wobbly and I don't recall it being wobbly before.
It could just be wobbly through wear and tear, but I'd rather not exacerbate it.
Richtea
PostPosted: 11:03 - 08 Aug 2012    Post subject: Reply with quote
Following on from the DIY themes above, what about something like this?
https://www.marinemegastore.com/product.asp?pf_id=UNI_086643&src=GBASE
Its a TV swivel stand but says supports up to 160KG, and I'm sure it could be modded in someway, but again will probably depend on you having a center stand.
Rich
2005 Honda Varadero 125xl > 2005 GS500F > 2007 DRZ400 SM > 600 Bandit & Yamaha YP250
pendulum
PostPosted: 11:17 - 08 Aug 2012    Post subject: Reply with quote
That's brilliant, I had no idea that could be done Shocked Just tried it on the CB500 and spun it round no problem. Useful thing to know.
1998 CG125 (Sold) CB500 [+ Clio 172]
Usually_Wrong: I tend to fail more than pass. [Speaking about Theory Practice]
Usually_Wrong: im on unemployment at the moment
Zen Dog
PostPosted: 11:20 - 08 Aug 2012    Post subject: Reply with quote
Good innit! I couldnt believe it the first time someone showed me. I think they should be teaching people that on their CBT to be honest. They show you how to get on and off the centrestand, why not this?
Zen Dog
map
Mr Calendar
PostPosted: 11:26 - 08 Aug 2012    Post subject: Reply with quote
Now go and try it on a Goldwing Wink
Zen Dog
PostPosted: 11:39 - 08 Aug 2012    Post subject: Reply with quote
I've seen it done on massive cruisers. Not tried it myself mind... Very Happy
Zen Dog
Teflon-Mike
tl;dr
PostPosted: 11:45 - 08 Aug 2012    Post subject: Reply with quote
No you would get 2/3 of the way round and get stuck between the wall and the freezer, and be left without wiggle room!
How do you know I haven't been to bed yet?
Actually, what woke me up was something nibbling on my rump!
I now have a bump on my rump.
And whatever it was.... probably due to the amount of coffee I drink, went 'Hyper' after its feed, and was 'buzzing' round the bedroom... like an ADHD Twocker with an air cooled DT125!
LordShaftesbu...
PostPosted: 11:49 - 09 Aug 2012    Post subject: Reply with quote
Zen Dog
Oh my fucking god this is AMAZING!!! Shocked Very Happy
My life is changed forever. Praying
Zen Dog
PostPosted: 16:00 - 09 Aug 2012    Post subject: Reply with quote
I accept all major forms of karma. Please feel free to donate each time you use it. Very Happy
Zen Dog
Dan79
PostPosted: 23:27 - 17 Aug 2012    Post subject: Reply with quote
My VF500 cruiser can be turned on its centre stand within the limits of a car parking space at my local Morrisons. (wouldn't do it on the side stand though it might snap !) Always turns heads from the other shoppers in their cars.
Previous bikes - 1984 Honda VF500 (FII) Interceptor and 1990 Yamaha RXS100
Current bikes - 1984 Honda VF500 (V30) Magna
colin1
Captain Safety
PostPosted: 12:13 - 18 Aug 2012    Post subject: Reply with quote
Fit a renntech luggage rack and you can just pick up back of the bike and manoeuvre it the way you would a wheel barrow.
You push up with your legs. Not as hard as it sounds.
Skudd
PostPosted: 12:20 - 18 Aug 2012    Post subject: Reply with quote
Zen Dog
I use that method all the time too with a heavy Varadero 1000cc with luggage. Easy as chips.
The last post was made 13 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 133.15 Kb
