Noise Test...FAIL! :P
MarkCMSV
PostPosted: 15:27 - 08 Aug 2012    Post subject: Noise Test...FAIL! :P Reply with quote
Just had a friend's Yamaha R6 noise tested at Brands Hatch.
It has a custom (pretty much non existent) exhaust and came out at 121.7db, around 5 times the noise limit at a lot of circuits and quoted by the tester as being "about as loud as an F1 Car"...oops! :p
PostPosted: 15:49 - 08 Aug 2012    Post subject: Reply with quote
Doesn't beat the Supra at Brands... 123dB and then got flagged off the track. What a shame Laughing
UnspeedySam
PostPosted: 16:06 - 08 Aug 2012    Post subject: Re: Noise Test...FAIL! Reply with quote
hahadumball wrote:
What circuit has a 24db noise limit...
I fart louder than that.
From Wikipedia:
The decibel (dB) is a logarithmic unit that indicates the ratio of a physical quantity (usually power or intensity) relative to a specified or implied reference level. A ratio in decibels is ten times the logarithm to base 10 of the ratio of two power quantities.
The limit will be about 115dB.
edit: Illustration of what a logarithmic unit is:
https://www.animations.physics.unsw.edu.au/jw/images/dB_files/LI.gif
supZ
PostPosted: 16:19 - 08 Aug 2012    Post subject: Reply with quote
its getting a bit silly.. just found out mallory next week is a 95db day.. my CBR blows 94 on a good day with just a slip on can and standard system. if im nearly on the limit i can only guess the trouble everyone else is going to have on higher tuned machinery..
you know its bad when bikes come out of the factory failing the noise tests
CBR954RR - Daily toy
CBR600RR - Trackbike
PostPosted: 16:22 - 08 Aug 2012    Post subject: Re: Noise Test...FAIL! Reply with quote
It has a custom (pretty much non existent) exhaust and came out at 121.7db, 5 times the noise limit at a lot of circuits and quoted by the tester as being "about as loud as an F1 Car"...oops!
How come you're telling us this and you have MSV in your username? Is this some sort of subtle social conditioning?
Slacker24seve...
PostPosted: 16:25 - 08 Aug 2012    Post subject: Reply with quote
My GPR twin cans, with the baffles in, was tested at 110 at Mallory. Gutted.
Banger rallies are ace
UnspeedySam
PostPosted: 16:27 - 08 Aug 2012    Post subject: Reply with quote
I dread to think what the ART cans on my TRX would test at. I currently have the standard ones back on which are insanely quiet. Need to find something in the middle I think...
MarkCMSV
PostPosted: 16:49 - 08 Aug 2012    Post subject: Re: Noise Test...FAIL! Reply with quote
_Iain_ wrote:
Lolwut?
Slightly easier to understand from the graph,
MarkCMSV
PostPosted: 16:50 - 08 Aug 2012    Post subject: Re: Noise Test...FAIL! Reply with quote
Work for Club MSV but no social conditioning intended.
Simply sharing part of my lunch break,
Snorty
PostPosted: 16:52 - 08 Aug 2012    Post subject: Reply with quote
Basically decibels are not additive units, they are on a logarithmic scale as described.
Much like the richter scale, a scale 9 earthquake is an order of magnitude stronger (10 times stronger) than a scale 8.
Decibels work in the same way, so 23dB would be a lot quieter than 115dB (way way quieter than 5x).
MarkCMSV
PostPosted: 16:56 - 08 Aug 2012    Post subject: Reply with quote
What would the ratio be between 105db and 121.7db then?
Not sure if 5 x is correct,
Bendy
Mrs Sensible
PostPosted: 16:58 - 08 Aug 2012    Post subject: Reply with quote
'pretty much non existant' exhausts are soo stupid. Never understood why people think being offensively noisy and annoying everyone else is somehow 'cool'.
Oooh, your bike is well noisy and has no mirrors. You must be that Francis Rossi bloke, please sign my t-shirt.
MarkCMSV
PostPosted: 16:59 - 08 Aug 2012    Post subject: Reply with quote
Tenko
PostPosted: 17:00 - 08 Aug 2012    Post subject: Reply with quote
My Gixxer failed the 105db test at Cadwell last year. Those nice men in scrutineering still let me out though as the bike is 20 years old and I am ancient - their rational was that an old codger like me wasn't likely to rev the thing very much....
MarkCMSV
PostPosted: 17:03 - 08 Aug 2012    Post subject: Reply with quote
BTW...My friend wasn't booked onto the trackday, he just wanted to see what the reading would be...knew it would be too loud.
map
Mr Calendar
PostPosted: 17:18 - 08 Aug 2012    Post subject: Re: Noise Test...FAIL! Reply with quote
beechbone wrote:
From Wikipedia:
The decibel (dB) is a logarithmic unit that indicates the ratio of a physical quantity (usually power or intensity) relative to a specified or implied reference level. A ratio in decibels is ten times the logarithm to base 10 of the ratio of two power quantities....
Long time since I've done this but do you not also have to factor in how far from the source the measurement takes place.
I know this because I looked into a louder horn (not the same as exhaust but same principle). Now to get the maximum db reading these are measured inches away from the device.
Stobel wrote:
... High decibel power and pleasant pitch that only an air horn can offer (115 dB(A) at 2 meters – 139 dB(A) at 4 inches, 530 + 680 Hz). ...
. The reality is a bit different...
https://www.webbikeworld.com/motorcycle-horns/images/horn-sound-comparisons.jpg
PostPosted: 17:25 - 08 Aug 2012    Post subject: Reply with quote
Loud Pipes Save Lives.
The specific merit of that might be open to debate. Shifty
Aff
PostPosted: 17:40 - 08 Aug 2012    Post subject: Reply with quote
About 32 times louder.
Electric Bike Project
Hetzer
PostPosted: 17:56 - 08 Aug 2012    Post subject: Reply with quote
I've seen cars nosing out and suddenly stopping before they could see me. Thumbs Up Very Happy
Bendy
Mrs Sensible
PostPosted: 18:43 - 08 Aug 2012    Post subject: Reply with quote
And very loud pipes make people want to kill you.
PostPosted: 18:46 - 08 Aug 2012    Post subject: Reply with quote
3db is double the noise. So 108db is double, 111 is 4 times, 114 is 8 times, 117 is 16 times and 120 is 32 times. So 121.7 is probably around 50 times louder than 105db
DrDonnyBrago
PostPosted: 18:48 - 08 Aug 2012    Post subject: Reply with quote
I'm not convinced by the loud pipes save lives thing, I've never noticed a difference filtering with or without a baffle in.
Also, if I am sat in traffic in my car and a bike comes past, can't think of an occasion where I have heard it prior to it being practically next to my door*. Most of the exhaust noise is directed at those who aren't in a position to not see you anyway.
* I NEVER listen to the radio, but I do drive a noisy old diesel.
Ayrton
PostPosted: 18:54 - 08 Aug 2012    Post subject: Reply with quote
Everyone thinks that having a loud exhaust stops accidents and makes people see you, but it doesnt. im quite often sat in a car and even with a loud bike i cant hear the bike until its alongside the car.
Loud exhaust are unneeded. They just piss people off.
The last post was made 13 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 7.98 - MySQL Queries: 13 - Page Size: 133.5 Kb
