| P.addy |
 P.addy Red Rocket
 Posted: 06:39 - 09 Aug 2012 Post subject: Yammy TT600...useless for motorways/offroad? |
Looking at one of these locally...it looks realy nice, has a supermoto setup too.
Obviously I like the DRZ, I like most supermotos How does this compare? Is it essentially an XT660 with a fatter body?
States around 130kg and 42hp. Thought that may be a little low as a DRZ SM states 146kg and 38hp but 200cc less
Are the TT600Rs good as any form of off road/road riding?  |
| Suntan Sid |
 Posted: 08:20 - 09 Aug 2012 Post subject: |
Look here for opinions:-
https://www.advrider.com/forums/showthread.php?t=159990
Supposedly heavy, but unless you can afford an up to the minute trailie, you're always going to be stuck with excess weight.
The DRZ is a barge as well, you tend not to notice once you get going.
I only get to off road on dry rocks and gravel, so no idea how weight affects mudplugging, other than it being a bastard to pick up.
I used to have a DR600, I liked it! ____________________ "Everybody needs money, that's why they call it money!"  |
| P.addy |
 P.addy Red Rocket
 Posted: 08:31 - 09 Aug 2012 Post subject: |
I looked on ebay at a DR600, its been squished in an RM frame and Q plated Seems legit  |
| Suntan Sid |
| P.addy |
 P.addy Red Rocket
 Posted: 22:43 - 09 Aug 2012 Post subject: |
Say a kickstart only model appeared in my garage
Would there be a simple way to start this? I've heard its a royal arse to do...  |
| Faldo |
 Faldo World Chat Champion
 Posted: 22:50 - 09 Aug 2012 Post subject: |
| ##Paddy## wrote: | Say a kickstart only model appeared in my garage
I had a DR650, kick start only. It was indeed a royal PITA to start, I think it had other issues to be honest, so I sold it soon after buying it. Mine had twin cans (original) and it did sound rather awesome . ____________________ Current: ZZR1400
Previous: ZXR 400 L9, ZX-7R P5, ZZR 400, ZX-7R P6, Bandit 600, GSXR 750 Slingshot, DRZ400, DR650, ZX10R C1H, ZXR 750 L1, ZXR 750 L3, '99 ZX7R P4, KTM 300 EXC, ZX-9R E1, TDM850 |
| P.addy |
 P.addy Red Rocket
 Posted: 22:51 - 09 Aug 2012 Post subject: |
Any tricks to kicking big singles over? Debating  |
| colicabcadam |
 colicabcadam Trackday Trickster
| Suntan Sid |
 Posted: 23:07 - 09 Aug 2012 Post subject: |
Depends whether it's a 600 or 650, assuming you're talking about a DR.
If it's a DR600 motor it has a manual de-compressor lever on the handle bars. Turn the motor over until it's just passed TDC, pull de-compressor lever in, then jump up and down on the kick start.
You should also bear in mind that during the kicking part of this procedure do not give it any throttle, you may find yourself, involuntarily, doing a standing jump over the bike. Can easily break your ankle if it kicks back. I got away with a limp for a few days the first time it kicked back on me. The only time I ever had problems starting mine was when the engine was hot. ____________________ "Everybody needs money, that's why they call it money!"  |
| Ariel Badger |
 Ariel Badger Super Spammer
| P.addy |
 P.addy Red Rocket
 Posted: 23:12 - 09 Aug 2012 Post subject: |
Right hand kick start, when cold half choke on and they appear to start.
Never done a kickstart bar a 125 single 2 stroke  |
| Suntan Sid |
 Posted: 23:15 - 09 Aug 2012 Post subject: |
My problem was, I went straight from a 350 power valve to the DR, so being used to kicking the 2 smoke over, with a good handful of throttle, the inevitable happened!  ____________________ "Everybody needs money, that's why they call it money!"  |
| colicabcadam |
| Suntan Sid |
| colicabcadam |
 Posted: 23:30 - 09 Aug 2012 Post subject: |
| P.addy |
 P.addy Red Rocket
| colicabcadam |
 Posted: 23:58 - 09 Aug 2012 Post subject: |
1 - kick bike over slowly once or twice to loosen it up
2 - find the compression stroke, pull the decompressor in, push the kick down a bit, release the decompressor, as soon as you feel that it's bouncy, let the kick come back up then whack it down with a bit of speed with full throttle, you should hear a suction type sound, do this twice
3 - do as above, but with NO throttle and the ignition on, done ____________________ my rides ---->> https://img406.imageshack.us/img406/5051/ktmaudiducati2.jpg |
| P.addy |
 P.addy Red Rocket
 Posted: 06:05 - 10 Aug 2012 Post subject: |
Has auto decomp on the kickstart which only opens from top, not when kickstart is lower down. Looks like an odd system  |
| Suntan Sid |
 Posted: 06:44 - 10 Aug 2012 Post subject: |
DRZ400 has auto decomp to help the electric foot! ____________________ "Everybody needs money, that's why they call it money!"  |
| G |
 G The Voice of Reason
| P.addy |
 P.addy Red Rocket
 Posted: 08:37 - 10 Aug 2012 Post subject: |
Having a minimum weight for a kickstart is pretty hilarious on its own.
Food for thought really.. Must gain weight |
| Suntan Sid |
 Posted: 09:45 - 10 Aug 2012 Post subject: |
I was about 10.5 stone when I had my DR600, once you have the technique I don't think weight comes into it, (within reason).
It's like Ariel said you just need to commit to the kick, pussy footing around will result in either not starting it or a kick back.
The compression on my Gas Gas Trials feels quite high, although the kickstart is very short, (so not getting much leverage). If you don't commit to it it won't go passed TDC, but as I said once you get the knack you'll have no problems. ____________________ "Everybody needs money, that's why they call it money!"  |
The last post was made 14 years, 81 days ago. Instead of replying here, would creating a new thread be more useful? |
