do il4 1l sports bikes wheelie....
colicabcadam
PostPosted: 19:16 - 09 Aug 2012    Post subject: do il4 1l sports bikes wheelie.... Reply with quote
at 100 mph when just using the throttle ? ok not a flip over wheelie, but say 15 inches off the ground ?
my rides ---->> https://img406.imageshack.us/img406/5051/ktmaudiducati2.jpg
Chalky.
PostPosted: 19:58 - 09 Aug 2012    Post subject: Reply with quote
Yes.
moppy
PostPosted: 20:06 - 09 Aug 2012    Post subject: Reply with quote
No. They have anti wheelie rings.
nowhere.elysium
The Pork Lord
PostPosted: 20:08 - 09 Aug 2012    Post subject: Reply with quote
Maybe, if the thrunge brackets are tight enough.
moppy
PostPosted: 20:12 - 09 Aug 2012    Post subject: Reply with quote
And don't forget to check your power band. Might need some tightening.
Slacker24seve...
PostPosted: 20:18 - 09 Aug 2012    Post subject: Reply with quote
Depends what colour it is. The purple ones, though slower, are self-adjusting and need no maintenance.
Banger rallies are ace
Huambo81a
PostPosted: 20:33 - 09 Aug 2012    Post subject: Reply with quote
I know that the 04 Kawasaki zx10 C1H had splunge pistons. But the latest thous have splunge inhibitors.
Present: 2017 KTM Super Adventure S
Past: 97 Bandit 600 / 05 Bandit 1200 / 03 ZX6-R / 2006 Tuono R / 2001 VFR 800 / 2010 Street Triple R / 2013 Speed Triple S / 2017 S1000XR
multijoy
PostPosted: 20:38 - 09 Aug 2012    Post subject: Reply with quote
But only if you've not opted for a reciprocating contrary mandible. Best to get both, in my view.
Redoko
PostPosted: 20:52 - 09 Aug 2012    Post subject: Reply with quote
Are those the ones that maintain a power to weight ratio?
moppy
PostPosted: 20:55 - 09 Aug 2012    Post subject: Reply with quote
No, no you're talking about the weight to power ratio. Dur brain.
multijoy
PostPosted: 20:58 - 09 Aug 2012    Post subject: Reply with quote
I think you're mixing it up with the fleen gasket. The mandible, when reciprocating in a contrary manner, keeps the correct tension on the power band and stops the colour fade.
_mjs_
PostPosted: 20:59 - 09 Aug 2012    Post subject: Reply with quote
Don't forget to check the tagnut adjusters and dangleberry adapters are properly greased or you could blow a pisstake valve.
pendulum
PostPosted: 21:02 - 09 Aug 2012    Post subject: Reply with quote
It's actually called a clunge piston. This is a common mistake to make.
1998 CG125 (Sold) CB500 [+ Clio 172]
Usually_Wrong: I tend to fail more than pass. [Speaking about Theory Practice]
Usually_Wrong: im on unemployment at the moment
T0MMY
PostPosted: 21:14 - 09 Aug 2012    Post subject: Reply with quote
I always get confused by this; which sprocket is for power and which is for weight? I went down a tooth on the front sprocket and up 3 teeth on the rear so has that increased or decreased my power to weight ratio?
ZX6R + CBR600RR
Slacker24seve...
PostPosted: 21:15 - 09 Aug 2012    Post subject: Reply with quote
They can only be used in conjunction with a flanged bore; pretty sure Honda were the only manufacturer to offer that in '04.
janner_10
A friend of a friends girlsfriends brother, changed his flux capacitor and I read on the toilet wall in my local that his bike could.
HTH Thumbs Up
PostPosted: 21:48 - 09 Aug 2012    Post subject: Reply with quote
Stop taking the piss. No bike can wheelie at 100mph. Except my mate's RS125, on his uncle's private airstrip.
swiftb
PostPosted: 21:52 - 09 Aug 2012    Post subject: Reply with quote
I once wheelied a car. True story.
nowhere.elysium
The Pork Lord
You've just done the Heisenberg mod, so technically, both.
stonesie
PostPosted: 22:09 - 09 Aug 2012    Post subject: Reply with quote
If all else fails then tighten the front dustcap Thumbs Up
T0MMY
I used to do that all the time. Really hard to make a quick getaway without the front coming up. The trick is to make sure you don't apply anyway downwards pressure so don't let your weight pull on the bar as you accelerate...
https://about-baby.us/wp-content/uploads/2011/03/58-baby-boy-toys1.jpg
I find it a lot easier now that I'm over 3 feet tall.
ZX6R + CBR600RR
mistergixer
PostPosted: 22:16 - 09 Aug 2012    Post subject: Reply with quote
I think it all depends how much you spend on it - 22K is a good starting point.
Space Monkey #7
T0MMY
PostPosted: 22:32 - 09 Aug 2012    Post subject: Reply with quote
bluex5 wrote:
If you do want to fadge around with gearing remember that the back sprocket is the one that does top speed.
Yes, and the front does acceleration. This is why MotoGP bikes are so fast as they have more teeth on both sprockets so the bike accelerates faster and has a higher top speed.
ZX6R + CBR600RR
The last post was made 13 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.95 - MySQL Queries: 13 - Page Size: 123.12 Kb
