Question's about MOT
Matt-
PostPosted: 14:51 - 12 Aug 2012    Post subject: Question's about MOT Reply with quote
Got a couple of question's about the Bike MOT
my bike is booked in for it's MOT in a week or so's time and i am just going through and checking and ticking off with everything as i check it on the bike. this is the website i am using to do base my check's on:
https://www.motuk.com/Motorcycle%20MOT.asp
thing's i have found so far which my bike might fail on-
- Reflector's - will they pass or fail it, it has none on the rear ?
- Exhaust - It say's on a MOT website i have to have a " BSAU 193 stamp " i don't think my arrow exhaust system has one, it has the arrow symbol and arrow stamp but not a BSAU Stamp /
- Head Set Bearing's - how do i check them ?
also -swingarm or suspension linkage bearings and
Pivot bearings ?
Any help would be appreciated Smile
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
RichieZX6R
PostPosted: 15:50 - 12 Aug 2012    Post subject: Reply with quote
You can buy stick on number plate reflectors for a few quid off eBay. Had a set of hands on my old CB.
Most MOT tester's tend not to worry so much about exhausts. Only thing you can do is take it there and see if passes of fails based on that.
Thanks
Current: Kawazaki ZX6R 51
Past: Kawazaki ZX6R 96 - Honda CBR 600F4 05 - Dragstar 125 02 - Honda CB 400 SF 94 - Honda NSR 125 51 - Gilera Runner XV125 04
_matt
PostPosted: 16:02 - 12 Aug 2012    Post subject: Reply with quote
Since when did we need Reflectors to pass an MOT?
None on the 535 and that's just been MOT'd and none on Jinny when it was done last year.
1990 Yamaha XV 535 (Alive Again!) / 2007 Jinlun Texan 125-11 (formerly 2k3, wrong details, now going rusty in the back garden )
Matt-
PostPosted: 16:23 - 12 Aug 2012    Post subject: Reply with quote
Thanks
Yeah i didn't think they worried about the exhaust side of thing's to much as they must have load's of aftermarket can's or bodged can's in as well Thumbs Up
as for the reflector issue it's been in for quite a few year's some MOT test center's must not care.
how big does the reflector have to be ?
Matt
DMCpro
PostPosted: 16:48 - 12 Aug 2012    Post subject: Reply with quote
the reflecter needs to be about the size of a 2p...
Head race bearing... hold your front brake and push up and forward on the handlebars can you feel movement?
Honda CB-1, TS125X
VW Golf Estate
Matt-
PostPosted: 17:01 - 12 Aug 2012    Post subject: Reply with quote
Yes but very little :'(
anyway of adjusting them or tightining them up ?
Teflon-Mike
tl;dr
PostPosted: 18:53 - 12 Aug 2012    Post subject: Reply with quote
Rear position reflectors are there so no-one rear ends you if your tail lamp goes out..... Probably not applicable to cruisers...... of why would you ride one Razz (or is this joke too subtle for bcf?)
Rear red refectors are required, but on many bikes they are incorporated into the tail lamp lens
DMCpro
PostPosted: 19:08 - 12 Aug 2012    Post subject: Reply with quote
https://www.goldwings-northwest.org.uk/wp-content/uploads/2010/05/Head-race-bearings-005.jpg
see the bit with kinda teeth on it? there will be one of them somewhere below your top yoke you need to tighten it, get a flatheaded screw driver or cold chisel and tighten it like that (hit it with a hammer in the direction that tightens) if that doesn't work tighten the top bolt and if that doesn't work you need new head race bearings... I took a bike that the head race bearings were completely fucked on and he still passed it with a £10 tip Wink the mot is £29.50 i just give £40 and say im sure it will pass anyway... always does
Honda CB-1, TS125X
VW Golf Estate
Patriot180
PostPosted: 19:11 - 12 Aug 2012    Post subject: Reply with quote
Well played Sir! Thumbs Up Laughing
Mod 1 Passed 31/7/12:::Mod 2 Passed 7/8/12
Current bike Honda CBF 600S
Matt-
PostPosted: 19:26 - 12 Aug 2012    Post subject: Reply with quote
That's great, hopefully this will work, don't think tipping this place will do any good they are fairly legal Wink
and thanks for the information about reflector tef Smile
PostPosted: 19:31 - 12 Aug 2012    Post subject: Re: Question's about MOT Reply with quote
Almost certainly fail. They will probably flog you one for a nominal amount to stick to the numberplate.
Current rules are that it should be as quiet as a standard system in reasonable condition in the opinion of the MOT tester (who could be deaf.....).
Support the bike so the front wheel of the bike is in the air. Then grip the forks and try to pull them backwards and forwards. If you can feel a clonk then they are lose. Try turning the forks and feel if they turn smoothly. If not then they are likely too tight and / or knackered (notchy).
Pivot bearings ?
Support the bike with the back wheel in the air, NOT supported under the swinging arm or the rear wheel. Attempt to lift the wheel and feel for play before the suspension stops moving easily. A small amount is normal, but more than 5mm or so is probably a fail (and a new bike might well be pretty close to that amount).
Matt-
PostPosted: 19:37 - 12 Aug 2012    Post subject: Reply with quote
such a relief when i see Keith has posted on my thread Smile
thanks lad Smile
i will UPDATE you all when i get around to tightening the nut's Smile
The last post was made 13 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.76 - MySQL Queries: 13 - Page Size: 80.37 Kb
