| Matt- |
 Matt- World Chat Champion
 Posted: 14:51 - 12 Aug 2012 Post subject: Question's about MOT |
Got a couple of question's about the Bike MOT
my bike is booked in for it's MOT in a week or so's time and i am just going through and checking and ticking off with everything as i check it on the bike. this is the website i am using to do base my check's on:
https://www.motuk.com/Motorcycle%20MOT.asp
thing's i have found so far which my bike might fail on-
- Reflector's - will they pass or fail it, it has none on the rear ?
- Exhaust - It say's on a MOT website i have to have a " BSAU 193 stamp " i don't think my arrow exhaust system has one, it has the arrow symbol and arrow stamp but not a BSAU Stamp /
- Head Set Bearing's - how do i check them ?
also -swingarm or suspension linkage bearings and
Pivot bearings ?
Any help would be appreciated
Matt ____________________ RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010 |
| RichieZX6R |
 RichieZX6R Nearly there...
| _matt |
 _matt Trackday Trickster
| Matt- |
| DMCpro |
 DMCpro Traffic Copper
| Matt- |
| Teflon-Mike |
| DMCpro |
| Patriot180 |
 Patriot180 Renault 5 Driver
| Matt- |
 Posted: 19:26 - 12 Aug 2012 Post subject: |
That's great, hopefully this will work, don't think tipping this place will do any good they are fairly legal
and thanks for the information about reflector tef  ____________________ RIP jack (wheelie king), you will never be forgotten.
 Posted: 19:31 - 12 Aug 2012 Post subject: Re: Question's about MOT |
| SomeGuyy wrote: |
- Reflector's - will they pass or fail it, it has none on the rear ? |
Almost certainly fail. They will probably flog you one for a nominal amount to stick to the numberplate.
| SomeGuyy wrote: | - Exhaust - It say's on a MOT website i have to have a " BSAU 193 stamp " i don't think my arrow exhaust system has one, it has the arrow symbol and arrow stamp but not a BSAU Stamp / |
Current rules are that it should be as quiet as a standard system in reasonable condition in the opinion of the MOT tester (who could be deaf.....).
| SomeGuyy wrote: | - Head Set Bearing's - how do i check them ? |
Support the bike so the front wheel of the bike is in the air. Then grip the forks and try to pull them backwards and forwards. If you can feel a clonk then they are lose. Try turning the forks and feel if they turn smoothly. If not then they are likely too tight and / or knackered (notchy).
| SomeGuyy wrote: | also -swingarm or suspension linkage bearings and
Pivot bearings ? |
Support the bike with the back wheel in the air, NOT supported under the swinging arm or the rear wheel. Attempt to lift the wheel and feel for play before the suspension stops moving easily. A small amount is normal, but more than 5mm or so is probably a fail (and a new bike might well be pretty close to that amount).
| Matt- |
 Posted: 19:37 - 12 Aug 2012 Post subject: |
such a relief when i see Keith has posted on my thread
thanks lad
i will UPDATE you all when i get around to tightening the nut's  ____________________ RIP jack (wheelie king), you will never be forgotten.
The last post was made 13 years, 323 days ago. Instead of replying here, would creating a new thread be more useful? |
