Cheap way to make seat more comfortable?
EazyDuz
PostPosted: 17:59 - 15 Aug 2012    Post subject: Cheap way to make seat more comfortable? Reply with quote
My arse/tail bone was well sore after about a 100 mile ride i did yesterday, so i was wondering what the cheapest method would be to improve comfort.
Did a search and someone recommended a saddle saver, which is designed for horse riders but are supposedly much mor comfortable and cheaper, something like this:
https://www.ebay.co.uk/itm/Quality-Soft-Fur-Saddle-Seat-Saver-All-Colours-Sizes-Available-/390444059382?pt=UK_Horse_Wear_Equipment&var=&hash=item5ae8478af6
Or are there better options? Dont mind making something if i need to.
Knightsy
PostPosted: 18:03 - 15 Aug 2012    Post subject: Reply with quote
Padded bicycle shorts?
09' Versys 650 | 07' FJR1300A
DrDonnyBrago
PostPosted: 18:04 - 15 Aug 2012    Post subject: Reply with quote
Sheep skin seems to be the most common way.
https://www.bikechatforums.com/viewtopic.php?t=201694
Someone did make something out of bicycle gel seat covers too, it looked absolutely fucking hilarious Laughing Laughing - like he had hidden dildos under his seat but he claimed it was comfortable.
EDIT this thread - pretty damn funny:
https://www.bikechatforums.com/viewtopic.php?t=181778&postdays=0&postorder=asc&start=0
PostPosted: 18:30 - 15 Aug 2012    Post subject: Reply with quote
There's a common mod on the Savage where the nose of the seat is raised an inch or so - this stops the "hip rolling forward" feeling. Maybe there's something similar for the XV?
yambabe
PostPosted: 18:42 - 15 Aug 2012    Post subject: Reply with quote
Learn to move around more on your seat, on your bike (and mine) because you are fairly upright and your arms and knees/feet are at more or less 90 degrees you can find that your weight bears straight down through your spine.
Shifting position will help this.
One trick I often use is to strap a bag or cushion to the pillion seat which effectively gives me a backrest and means I can lean back and shift that pressure every now and again. Move your feet back and to on the pegs (toe to front, heel to front etc), rest your left forearm on your left thigh and lean slightly forwards.
All of these things will ease the pressure off your spine and should help ease the tailbone!
One last thing, although my tank range is more I usually do 100 miles between fillups and when I stop I take a few minutes to get off the bike, walk around and stretch a bit. Hope this helps.
EazyDuz
PostPosted: 18:51 - 15 Aug 2012    Post subject: Reply with quote
thanks for the tips, might get a sheepskin cover anyway as they are only £15, trying to find one cheaper though lol
https://www.lambland.co.uk/item/2594/genuine-sheepskin-motorcycle-seat-pad-in-black
PostPosted: 18:59 - 15 Aug 2012    Post subject: Reply with quote
https://ecx.images-amazon.com/images/I/21xuIHKvFQL._SL500_AA300_.jpg
EazyDuz
PostPosted: 19:08 - 15 Aug 2012    Post subject: Reply with quote
would simulated sheepskin be as good as real sheepskin?
DrDonnyBrago
PostPosted: 19:09 - 15 Aug 2012    Post subject: Reply with quote
Would probably feel the same, but not last as long.
Find a car boot sale, you can pick up a sheepskin and make your own for a few quid.
PostPosted: 19:26 - 15 Aug 2012    Post subject: Reply with quote
If cheap is your main criteria, go down to the £1 shop, buy 2 bead-filled travel neck pillows, arrange them to your liking, then duct tape them together. Total cost £2.20 or so including the tape.
EazyDuz
PostPosted: 19:47 - 15 Aug 2012    Post subject: Reply with quote
Too basic, im thinking £15 max.
I'd rather be butthurt than spend money
PostPosted: 19:57 - 15 Aug 2012    Post subject: Reply with quote
I dont know what the world is coming to. Men are no longer men. Fluffy sheep skin seat covers to stop your piles aching on a bike. Next you'll all be walking around like this guy:
https://miamiherald.typepad.com/gaysouthflorida/WindowsLiveWriter/228-Op_Launch_Party_CACP104_standalone_prod_affiliate_56.jpg
Bring back the real men of BCF. You're all Nancys!
T0MMY
PostPosted: 21:00 - 15 Aug 2012    Post subject: Reply with quote
I bought one of these:-
https://static.guim.co.uk/sys-images/Guardian/Pix/pictures/2009/4/16/1239871311962/Chips-in-a-deep-fat-fryer-001.jpg
And lots of this:-
https://www.ocado.com/catalog/images-hires/44121011_H.jpg?identifier=38732407d38373b7309faf59f44d34ec
And as well as having delicious chips whenever I wanted, I also found my saddle getting more and more comfortable. I'm not sure by what mechanism it's working but it really does Thumbs Up Although it also seems to make my leathers shrink Sad
ZX6R + CBR600RR
PostPosted: 21:08 - 15 Aug 2012    Post subject: Reply with quote
What you do is get a triangular frame made of steel flatbar which is slightly wider than your buttocks at the widest point. At the front point of the frame you attach a pivot. At the rear two points you attach a large coil spring. You attach the triangle to the bike frame by the pivot and springs so it is free to move round the pivot while floating on the springs.
You then stretch more, longer springs horizontally across the triangular frame, cover them with a generous layer of wadded horsehair then top it off with a leather cover stretched over the whole lot and rivetted on.
Works for me.
https://i48.photobucket.com/albums/f216/stinkwheel/rbr/64a.png
defblade
PostPosted: 21:11 - 15 Aug 2012    Post subject: Reply with quote
Ride standing up.
Even cheaper than chips Smile
map
Mr Calendar
PostPosted: 10:59 - 16 Aug 2012    Post subject: Reply with quote
Strange as it may seem if you get the seamless underwear or compression stuff it can help with long distance touring.
PostPosted: 12:06 - 16 Aug 2012    Post subject: Reply with quote
EazyDuz wrote:
Too basic,
Works though. Up to you, Richy McSplurge. Razz
Zen Dog
PostPosted: 12:29 - 16 Aug 2012    Post subject: Reply with quote
Don't you just get a massively soggy arse in the rain if you have a sheepskin cover on your seat?
It what's always put me off having a corbin seat or similar, they always seem to be full of holes, so i just think they'll be like a sponge...
Zen Dog
EazyDuz
PostPosted: 15:22 - 16 Aug 2012    Post subject: Reply with quote
I use 20's as rizzlas
PostPosted: 16:51 - 16 Aug 2012    Post subject: Reply with quote
Be off, peasant, or I shall have my butler remove you to the Workhouse forthwith.
https://i48.tinypic.com/2h5lac8.jpg
The last post was made 13 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 114.63 Kb
