Indicator relays are they meant to get hot?
woo
PostPosted: 14:01 - 16 Aug 2012    Post subject: Indicator relays are they meant to get hot? Reply with quote
I bought these indicator relays for my bike and they got very hot for just being on for between 30 to 60 seconds.
They are the type which fit between the indicator and the wire which connects to the wiring loom
I find this worrying as sometimes you can be sat in traffic lights for more than 1 minute and with the way these got so hot it left me very conerned!
I have emailed the seller stating that I dont wish to send them back or leave negative feedback as I cant be arsed as they only cost me £6.50
The seller has offered to take them back and offer a full refund but at £6.50 I CBA!
So are these things meant to get hot?
Elen sila lummen omentielvo!
PostPosted: 14:14 - 16 Aug 2012    Post subject: Reply with quote
Err...
Just use them when you
a - see the other traffic stopping due to lights changing or
b - indicate to signal lane change, filter to front and don't bother indicating/sit in traffic and indicate when you start moving.
janner_10
PostPosted: 14:15 - 16 Aug 2012    Post subject: Reply with quote
Most relays will get warm when used, if your indicators are functioning ok ie. the relay isn't chattering, then all sounds quite normal.
Note warm should mean you can touch it without burning yourself and not glowing red hot.
Can you keep your hand on yours?
woo
PostPosted: 14:18 - 16 Aug 2012    Post subject: Reply with quote
no they get so hot that I was beginning to understand the meaning of FIRE in Third Party Fire and Theft level of insurance cover, and this was from just testing them out before road use.
PostPosted: 15:20 - 16 Aug 2012    Post subject: Reply with quote
They aren't relays you are describing they are resistors and a complete waste of time IMO.
The reason LED bulbs flash flasher is because they draw less power which is good! However they flash faster as a result. You have but resistors in each circuit which resists the current to so down the flash. Essentially you are just making the indicators draw more power to flash at a better rate.
It would have been better to change the flasher relay for a better one that works based on time not on the draw for power.
A quick Ebay finds this.
https://www.ebay.co.uk/itm/LED-FLASHER-RELAY-for-YAMAHA-R1-2000-2011-/300734453462?pt=UK_Motorcycle_Parts&hash=item46052b96d6#ht_1924wt_964
For an extra few quid you could have a solution that plugs in, would have taken minutes to fit and you wouldn't have had to hack up your loom.
woo
PostPosted: 15:26 - 16 Aug 2012    Post subject: Reply with quote
yes you are right they not relays but resistors, in the meantime I have ordered a relay from motrax but not the one you have linked if that fails I will check the one you have linked, cheers!
PostPosted: 15:30 - 16 Aug 2012    Post subject: Reply with quote
The one I linked was literally the first one I found it wasn't an endorsement!
PostPosted: 16:14 - 16 Aug 2012    Post subject: Reply with quote
Put incandescent bulbs back in, clamp your hand directly over a bulb, turn them on and see how long it takes to say "Ouch".
You've just moved that heat to the resistors.
Timer based relay FTW. Thumbs Up
woo
PostPosted: 16:16 - 16 Aug 2012    Post subject: Reply with quote
was worried they might catch fire or blow a fuse as Im riding to scotland in about a week and want no mishaps
The last post was made 13 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.06 - MySQL Queries: 13 - Page Size: 61.45 Kb
