norton jubilee 250
tombaker213
PostPosted: 15:03 - 15 Aug 2012    Post subject: norton jubilee 250 Reply with quote
I have just bought a Norton Jubilee 250, was wondering if there is anyone around with a version of the workshop manual? I have looked around and I have currently had no luck.
Thanks
Tom Baker
Somerset, England
bikenut
PostPosted: 11:11 - 17 Aug 2012    Post subject: manual Reply with quote
:karma: hi dude,
some pics would be good, the more the merrier..........
what info do you need and is she a runner?? ( stuck rings and stuck valves ( which will end up bent if your not very carefull ) open usually!! ).
what year?? will do some digging......
Ariel Badger
PostPosted: 14:45 - 17 Aug 2012    Post subject: Reply with quote
Your best bet is to join the NOC.
Ariel Badger
PostPosted: 22:47 - 17 Aug 2012    Post subject: Reply with quote
Having had a look at the NOC site I retract my last advice.
Ed Case
PostPosted: 15:33 - 18 Aug 2012    Post subject: Reply with quote
These were not the best choice in their day, lots of hocus pocus going on under the tank which didn't translate to much other than noise. Even amongst the 'classic' crowd they're viewed as a bit of a 'Curate's Egg' (good in parts). If you're handy with spanners (Imperial sizes), enjoy a challenge (a lengthy one) and are prepared to spend some money on a bike that if the current prices are maintained probably will never be the most desirable in the world......go for it. I've had what many refer to as 'Classics' in the past and they can easily become money pits and a lot of dedication is needed to keep them in any real shape. Best of luck with it. For any useful advice there really is no alternative to the Norton Owners Club where there are some Jubilees and Navigators (350s) and Electras (400s), an associated family of bikes.
PostPosted: 15:38 - 18 Aug 2012    Post subject: Re: norton jubilee 250 Reply with quote
Thanks
Just undo everything with your sonic screwdriver Very Happy
pepperami
PostPosted: 12:59 - 19 Aug 2012    Post subject: Re: norton jubilee 250 Reply with quote
Thanks
Have you thought about the VJMC ?
Bezzer
PostPosted: 14:02 - 19 Aug 2012    Post subject: Re: norton jubilee 250 Reply with quote
err it's a British Norton not a Vintage Jap Mr. Green
Take it you meant the VMCC.
There's plenty of books and manuals out there, a subscription to OldBikeMart more than pays for itself for finding parts and specialists.
pepperami
PostPosted: 14:12 - 19 Aug 2012    Post subject: Reply with quote
Embarassed my bad, I meant the VMCC Embarassed
bikenut
PostPosted: 14:29 - 21 Aug 2012    Post subject: norton Reply with quote
:karma: hi dude,
has yours got all of its skirt or is it showin its legs..........
anyways a norton short stroke twin cam ohv dry sump? , is it a runner??
be carefull for stuck valves and rings, has the eng been turned yet??
is the crankcase full of eng oil etc.........
ign points on rhside, so is oil pump.
some pics of eng would be nice........ :)
tombaker213
PostPosted: 16:37 - 20 Nov 2012    Post subject: norton jubilee Reply with quote
hi all, i managed to find a manual
dry sump oil pumps working
points are working
coils were broken since been replaced
carb needs retuning (help appricieated)
runs just about
Tom Baker
Somerset, England
YBR Ric
PostPosted: 22:49 - 20 Nov 2012    Post subject: Reply with quote
I owned one for several rebuilds Rolling Eyes
I'm located near Bristol and might be able to call round to offer my commiserations and hit it with a big stick for you.
PM me if you're not too far away and get stuck.
bikenut
PostPosted: 12:43 - 21 Nov 2012    Post subject: norton Reply with quote
single carb, so strip ( start at the tank filler cap ) clean, fit small vw ( sacrilage ) type fuel filter tween tank and carb.
set main needle to middle, slight throttle open on screw ( not too much or she'll rev too much ) and set air screw ( mixture screw for slowe running ) to 2 turns out ( or more for initial run so carb cleaner and petrol ( initial run with carb cleaner and some 2t ) is rich, drawing on "jets" ).
air filter ( as well as oil filters ( and tank ) ) all ok?
2 sets of points ( use dwell meter for really accurate setting ) with one being master.
by this i mean that one set it mounted to moveable base, and other set mounted on moveable plate, on this base.
auto advance ok?
so set master first then other set. some pics would be nice. Very Happy Thumbs Up
The last post was made 13 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 77.44 Kb
