| scarborough_lad |
 scarborough_lad Trackday Trickster
| chris-red |
 Posted: 13:38 - 21 Aug 2012 Post subject: Re: GS500E Restriction |
Of course it's more cost effective, it's over £200 cheaper  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| scarborough_lad |
| mysterious_rider |
 mysterious_rider World Chat Champion
 Posted: 13:55 - 21 Aug 2012 Post subject: |
they're great. Really easy to fit and restrict it well. Plus you get a certificate.  |
| _Iain_ |
 _Iain_ Banned
 Posted: 13:57 - 21 Aug 2012 Post subject: |
Get a frequency switch kit, connect the output relay to the sidestand switch and peg the rev's at about 6k (engine makes about 30 bhp there looking at a few dyno graphs.)
https://i1148.photobucket.com/albums/o574/_Iain_/EFA99870-E360-499F-B846-55E0ED820AF0-2527-00000339791031B5.jpg
Will make lots of popping banging noises, costs £7, and has an on off switch so when you do get pulled up, click your switch to enable the limiter. Youtube Bee*R limiter. Basicly does that, without the pricetag. Flames and bangs depends on fuelling, revs and the gain setting on the PCB.
Havent got mine permenantly fitted as i'm making a few mods to the board and trying to find a suitable waterproof housing to put it in, but have had it on the bike and it does quite happily drop the rev limiter to wherever you want it set. Five wires. One to the yellow and black on the CDI, one to the + on the battery, one to the - on the battery and the other two to the sidestand switch (green and black i think, i'll write up a guide once i've got it setup 100%)
Cheap, quick and will fit any carbed 12v bike. Probbably the EFI ones aswell, but the install would be different i think if the ECU controlled the spark instead of a standalone CDI unit? Not sure.
https://www.rob-brown.com/images/stories/blogs/simples.jpg
Or be a good boy, and leave it 33bhp all the time. in which case run the washers off ebay at about £40 a go. Kickstart engineering i think?
Legality as i understand it;
Certificates legally dont count for fuck all. They're worthless paperwork.
If insurance ask for proof of restriction, take the bike to a dyno. Get a power run that shows it only made 33bhp or less. Have the operator sign this paper, and send them that. I've never been asked for any of this certificate nonsense.
Police wise, they dyno your bike, it simply wont rev high enough to make 33bhp, and unless they can PROVE that your limiter wasnt switched on then they cant do jackshit apart from be angry at it.
In the event of an accident, if the PCB is there, this is evidence of a restriction device, and thus proof enough that the bike probbably was restricted which gets you off the hook as you can claim that it was damaged in the crash.
From my experience;
I ride the bike everywhere. It looks like it's escaped from the scrapyard. It sounds like - and i quote "Spawn of satan". I've never been pulled, never had any greif with the old bill, never had an insurer ask about a restriction certificate. I did get stopped by the police once limping it to a petrol station with a flat tyre, and had nothing said. Previous experience of popo says that if you're alright with them, have a laugh and a joke and try and be as freindly as possible you'll be fine. If the car says traffic police on it, dont bother as they're jobsworth cunts who WILL fuck you for whatever they can. ____________________ Please be aware that the above post may be full of complete nonsense.
| kotachi |
 kotachi Traffic Copper
 Posted: 14:13 - 21 Aug 2012 Post subject: |
| _Iain_ wrote: | Get a frequency switch kit, connect the output relay to the sidestand switch and peg the rev's at about 6k (engine makes about 30 bhp there looking at a few dyno graphs.)
More info pl0x!!!
Does this work for any bike?!
To avoid /hijack please PM me if the explanation gets a bit long, I'm just very very interested in a potential on/off switch restrictor (although mine is for a Thundercat and not a GS500.. Lol) ____________________ CBT done - 24/03/2012, theory test done - 03/04/2012.. Mod 1 done -26/06/2012, Mod 2 done - 29/06/2012. Current steed: Cage.
Suntan Sid said: "Look at it this way, your employer wants to pay you the minimum amount, it thinks it can get away with, and extract from you the maximum amount of graft. Ergo it's your responsibility to ensure that karma is restored and you do as little work as you think you can get away with, for the maximum amount of money." |
| _Iain_ |
 _Iain_ Banned
 Posted: 14:32 - 21 Aug 2012 Post subject: |
You get a dyno chart for said bike, wherever that says 30bhp? 20bhp? Whatever you want it to make, you note the revs & set the board to do this.
The board monitors a pulse input, i.e from your ignition coil. This tells it what revs the engines at.
At a set rev the board trips a relay. You wire this relay to the sidestand switch, or ignition kill switch.
Revs rise to the point where the engine makes 30bhp, board detects this and switches the engine off.
...For the amout of time you tell it to by adjusting the VR3 pot (tiny one on the board) Then switches the ignition back on.
Long delays give this effect;
https://www.youtube.com/watch?feature=endscreen&v=7oRd_8eZgtM&NR=1
And a short delay gives this effect;
https://www.youtube.com/watch?v=w5EFdGdm5No
The engine then tries to spin up to x amount of revs again, and the board turns it off. then back on again. then you get the bababababa like when it hits the OEM limiter?
However, if we then put a simple on off switch to the + feed for the board, then when the board sees no power, it cant switch the engine off. thus engine runs as normal. So if one were to hide a switch up on the bars somewhere? or in the fairing? Idk..
If your bike has a coil or electronic rev counter for the signal, and killswitch or sidestand switch then it'd work. Provided its a 12v electrical system.
I like flames, bangs and generally being a bit of a pikey. However doing it this way then gives me a legitimate excuse for having such a device on my bike. Although i sure as fuck wouldnt want to hit it whilst riding. I reckon if i got it set up right it could make for some awesome burnouts.
I'll await being flamed to f*ck by the kittendeath crowd & am in no way suggesting that the information posted by myself should be used to break the law or licence restrictions. Just saying that it COULD be done.  ____________________ Please be aware that the above post may be full of complete nonsense.
| kotachi |
| _Iain_ |
 _Iain_ Banned
| kotachi |
| _Iain_ |
 _Iain_ Banned
 Posted: 15:31 - 21 Aug 2012 Post subject: |
No idea. On/off switch reffered to is a diagnostic switch btw for fault finding.
Obviously if one was to crash and the impact was to knock the system into diagnostic mode...this would explain an iffy dyno reading wouldnt it?
All theory though. I still need to figure out waterproofing, packaging, set it up propperly and test ride it over a few thousand miles before i can comment on the systems reliability. I also intend to get it dyno tested after a driveway guestimate calibration to see how easy it would be to setup using the OEM tacho & google images dyno charts.
If i can get the thing working, road tested and everything i'll post a proper how to guide. ____________________ Please be aware that the above post may be full of complete nonsense.
| chris-red |
| _Iain_ |
 _Iain_ Banned
| Rogerborg |
 Rogerborg nimbA
| scarborough_lad |
| scarborough_lad |
| cdlxxvi |
 cdlxxvi Nearly there...
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:48 - 22 Aug 2012 Post subject: |
Just noticed this:
| scarborough_lad wrote: | How do I know if they're proper and won't drop me in the shit when it comes to insurance or the po-po? |
The "certificate" is likely to offer you all the peace of mind that you'll need in practice. But... it's just a bit of paper. You have access to a printer, right?
If push comes to shove though, the responsibility is on you to ensure that the actual bike is making no more than 25kW net power output. "Bloke said down the internet" or "I had a go" are not defences, although they may be mitigation.
If you want to be sure, you'll need to pay for a dyno run, and even then you'll only get an estimated engine power result which Plod's dyno squad may disagree with by using different Voodomaths, or even just by running the bike on a colder day.
It's really up to you how you do it, there's no right or wrong answer. If you want to pay £45.29 for two washer and a bit of paper, well, people pay a lot more for the same thing from FI International. ____________________ Biking is 1/20th as dangerous as horse riding.
| scarborough_lad |
| Zen Dog |
 Zen Dog World Chat Champion
 Posted: 15:08 - 22 Aug 2012 Post subject: |
Has anyone on here actually had their bike dyno'ed by the filth?
Zen Dog ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
My bike trip around S.E. Asia 2010/2011 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 16:15 - 22 Aug 2012 Post subject: |
What's-his-name who stacked it into a farm gate, I'm not sure we ever heard the conclusion of that one. Actually, was it dyno'd, or did they just say "Dear Mr What's-his-name, there's sod all evidence of restriction on the remains of your bike, so since we're doing you for Careless anyway, want to tell us what your defence would be to an Otherwise Than In Accordance charge?"
Then there was the epic thread at the SV650 forums about the youngish chap who was nabbed (unlawfully, I believe) and then the dyno place caught fire with his bike in it And he wasn't prosecuted in the end, even though Plod claimed his bike was reading more than 10% over.
Don't crash, don't get caught at 3 figures, ideally have a bit of paper to wave at Plod or insurers, and I reckon the chances of being accused let alone convicted are absolutely minimal. It's not an obvious or easy collar, and there isn't the budget out there to police it pro-actively. ____________________ Biking is 1/20th as dangerous as horse riding.
| scarborough_lad |
| _Iain_ |
 _Iain_ Banned
| Rogerborg |
 Rogerborg nimbA
| scarborough_lad |
The last post was made 14 years, 60 days ago. Instead of replying here, would creating a new thread be more useful? |
