GS500E Restriction
scarborough_lad
PostPosted: 13:36 - 21 Aug 2012    Post subject: GS500E Restriction Reply with quote
Hi, I'm trading up for a 1998 GS500E in a few months after I pass my test. It'll need to be restricted and I've been looking at ways to do that. FI want £200 for some washers, and I'll have to get them fitted so that's £250 all in. I was wondering whether a kit like this would be more cost-effective.
https://www.ebay.co.uk/itm/Suzuki-GS-500-GS500-Restrictor-Kit-33-BHP-25kw-certificate-/320958417991?pt=UK_Motorcycle_Parts&hash=item4aba9ccc47#ht_1238wt_884
It's still £42 but it's the best I can fine, unless anyone has some second hand ones they can sell me? Just looking for opinions, cheers!
'96 Suzuki GS500
PostPosted: 13:38 - 21 Aug 2012    Post subject: Re: GS500E Restriction Reply with quote
Of course it's more cost effective, it's over £200 cheaper Laughing
scarborough_lad
PostPosted: 13:46 - 21 Aug 2012    Post subject: Reply with quote
Just thinking if it's good idea buying these off eBay. How do I know if they're proper and won't drop me in the shit when it comes to insurance or the po-po?
'96 Suzuki GS500
mysterious_rider
PostPosted: 13:55 - 21 Aug 2012    Post subject: Reply with quote
they're great. Really easy to fit and restrict it well. Plus you get a certificate. Thumbs Up
kotachi
PostPosted: 14:13 - 21 Aug 2012    Post subject: Reply with quote
_Iain_ wrote:
Get a frequency switch kit, connect the output relay to the sidestand switch and peg the rev's at about 6k (engine makes about 30 bhp there looking at a few dyno graphs.)
Will make lots of popping banging noises, costs £7, and has an on off switch so when you do get pulled up, click your switch to enable the limiter. Youtube Bee*R limiter. Basicly does that, without the pricetag. Flames and bangs depends on fuelling, revs and the gain setting on the PCB.
Havent got mine permenantly fitted as i'm making a few mods to the board and trying to find a suitable waterproof housing to put it in, but have had it on the bike and it does quite happily drop the rev limiter to wherever you want it set. Five wires. One to the yellow and black on the CDI, one to the + on the battery, one to the - on the battery and the other two to the sidestand switch (green and black i think, i'll write up a guide once i've got it setup 100%)
Cheap, quick and will fit any carbed 12v bike. Probbably the EFI ones aswell, but the install would be different i think if the ECU controlled the spark instead of a standalone CDI unit? Not sure.
More info pl0x!!!
Does this work for any bike?!
To avoid /hijack please PM me if the explanation gets a bit long, I'm just very very interested in a potential on/off switch restrictor Razz (although mine is for a Thundercat and not a GS500.. Lol)
CBT done - 24/03/2012, theory test done - 03/04/2012.. Mod 1 done -26/06/2012, Mod 2 done - 29/06/2012. Current steed: Cage.
Suntan Sid said: "Look at it this way, your employer wants to pay you the minimum amount, it thinks it can get away with, and extract from you the maximum amount of graft. Ergo it's your responsibility to ensure that karma is restored and you do as little work as you think you can get away with, for the maximum amount of money."
kotachi
PostPosted: 14:54 - 21 Aug 2012    Post subject: Reply with quote
Haha I love the disclaimer at the end.. Just thinking this sort of restrictor could suit me.
kotachi
PostPosted: 15:19 - 21 Aug 2012    Post subject: Reply with quote
Ha! I never noticed that one though I saw that thread... And would your discussed, not at all promoted or advised restriction method invoke similar anger?
PostPosted: 15:37 - 21 Aug 2012    Post subject: Reply with quote
That would be horrid to ride. If you restrict it to 6k RPM that means you would only be able to get to about 60mph. Do it properly the bike will be much more ridable.
PostPosted: 15:53 - 21 Aug 2012    Post subject: Reply with quote
The "kit" you need is two 38mm washers with 20mm holes drilled in them and stuffed between the carbs and the engine.
https://img.photobucket.com/albums/v116/rd350r/01012006057.jpg
https://img.photobucket.com/albums/v116/rd350r/01012006056.jpg
https://img.photobucket.com/albums/v116/rd350r/01012006055.jpg
The "certificate" that you'll get from FI international or anywhere else is a piece of paper that says "Yo, is totes 25kW 4 realz!" on it. If you have a printer - or a crayon - then you can produce an equally valuable piece of paper which will prove exactly the same (nothing) about the actual bike.
33bhp certificate rip off.
scarborough_lad
PostPosted: 01:44 - 22 Aug 2012    Post subject: Reply with quote
I think I'm going to be a good boy and get the kit, that board sounds interesting but seems too complicated for me. It sounds like you can either ride illegally or backfire like a bitch, not too keen on doing either.
'96 Suzuki GS500
scarborough_lad
PostPosted: 01:51 - 22 Aug 2012    Post subject: Reply with quote
Is this sarcasm?
'96 Suzuki GS500
cdlxxvi
PostPosted: 08:25 - 22 Aug 2012    Post subject: Re: GS500E Restriction Reply with quote
PostPosted: 09:48 - 22 Aug 2012    Post subject: Reply with quote
Just noticed this:
The "certificate" is likely to offer you all the peace of mind that you'll need in practice. But... it's just a bit of paper. You have access to a printer, right?
If push comes to shove though, the responsibility is on you to ensure that the actual bike is making no more than 25kW net power output. "Bloke said down the internet" or "I had a go" are not defences, although they may be mitigation.
If you want to be sure, you'll need to pay for a dyno run, and even then you'll only get an estimated engine power result which Plod's dyno squad may disagree with by using different Voodomaths, or even just by running the bike on a colder day.
It's really up to you how you do it, there's no right or wrong answer. If you want to pay £45.29 for two washer and a bit of paper, well, people pay a lot more for the same thing from FI International.
scarborough_lad
PostPosted: 13:15 - 22 Aug 2012    Post subject: Reply with quote
Cool, thanks for all your advice everyone. I'm gonna go with this kit thing.
'96 Suzuki GS500
Zen Dog
PostPosted: 15:08 - 22 Aug 2012    Post subject: Reply with quote
Has anyone on here actually had their bike dyno'ed by the filth?
Zen Dog
PostPosted: 16:15 - 22 Aug 2012    Post subject: Reply with quote
What's-his-name who stacked it into a farm gate, I'm not sure we ever heard the conclusion of that one. Actually, was it dyno'd, or did they just say "Dear Mr What's-his-name, there's sod all evidence of restriction on the remains of your bike, so since we're doing you for Careless anyway, want to tell us what your defence would be to an Otherwise Than In Accordance charge?" Thinking
Then there was the epic thread at the SV650 forums about the youngish chap who was nabbed (unlawfully, I believe) and then the dyno place caught fire with his bike in it Exclamation And he wasn't prosecuted in the end, even though Plod claimed his bike was reading more than 10% over.
Don't crash, don't get caught at 3 figures, ideally have a bit of paper to wave at Plod or insurers, and I reckon the chances of being accused let alone convicted are absolutely minimal. It's not an obvious or easy collar, and there isn't the budget out there to police it pro-actively.
scarborough_lad
PostPosted: 22:53 - 22 Aug 2012    Post subject: Reply with quote
You've got to link that.
'96 Suzuki GS500
PostPosted: 23:54 - 22 Aug 2012    Post subject: Reply with quote
Which one? They SV650 thread is here, settle down for a loooong read.
scarborough_lad
PostPosted: 00:40 - 23 Aug 2012    Post subject: Reply with quote
Page 1 of 94.
I'm alright actually....
'96 Suzuki GS500
The last post was made 14 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 146.95 Kb
