Seat Cowl nightmare - Stripping paint from plastic?
DSK
PostPosted: 08:33 - 21 Aug 2012    Post subject: Seat Cowl nightmare - Stripping paint from plastic? Reply with quote
Basically I painted this to Honda Ross white, the colour was wrong, got sent a new can, but its all gone wrong.
It seems to have reacted with the layer beneath, weird as its from the same supplier.
I need to strip it back to the plastic and start again.
What can I use that won't damage the plastic?
Current Bike - 1990 CBR600 FL Benetton edition.
Matt-
PostPosted: 09:25 - 21 Aug 2012    Post subject: Reply with quote
Wait until it's DRY not touch dry
use small kitchen pad, the one that most people use to do their washing up Thumbs Up
not a Brillo a scour i think it's called, just keep rubbing until it comes off
then what ever bit's you are left with use a very very light bit of rubbing down paper, or better still wet & dry should take it off smoothly and damage free Thumbs Up
Hope this helps
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
DSK
PostPosted: 12:04 - 21 Aug 2012    Post subject: Reply with quote
The scourer/wet and dry idea is what I thought, just hoped there was a quick way.
I suppose quick normally means cock up....
Stu
lihp
PostPosted: 12:19 - 21 Aug 2012    Post subject: Reply with quote
just reprimer and paint again?
ruck bodgers
PostPosted: 12:44 - 21 Aug 2012    Post subject: Reply with quote
_Iain_ wrote:
Brake fluid.
i also found this whilst bleeding my brakes messily Laughing works good dont it for stuff . cleaning wheels especially
thomp1983
PostPosted: 13:00 - 21 Aug 2012    Post subject: Reply with quote
fairly fresh paint just 800 grit wet and dry it, it'll be of in 10-15 minutes
chris
Matt-
PostPosted: 13:35 - 21 Aug 2012    Post subject: Reply with quote
Don't just re - primer it wont be enough and may react to the new paint Thumbs Up
clean it up as i said, use some Medium Grit wet and dry with some brake fluid or Petrol would even be better.
Once you have cleaned it all up wash it with water then let it naturally dry in the sun ( that's if we ever have any again this year )
then re- primer and paint, then it will be fine
All the best and hope this helps
Matt
lihp
PostPosted: 20:16 - 21 Aug 2012    Post subject: Reply with quote
It's new paint he's put on, and wants to repaint, why would it react?
Ronin
PostPosted: 20:31 - 21 Aug 2012    Post subject: Reply with quote
You can buy plastic only strippers or use nitro mores but it can eat the plastic if you leave it to long.
As long as it hasn't run really badly it will be best to let it dry .Give it a couple if days .(lets all the solvents evaporate)Then rub it down you can start with about 400 but finish with 800grit .
When you apply the paint the couple should be very light so very little coverage .Build it up slowly until it is covered ie it looks the right colour and none of the repairs or scratches are visible then apply two or three wet coats and allow to dry.
Allow 5-10 mins between coats .
DSK
PostPosted: 22:26 - 21 Aug 2012    Post subject: Reply with quote
I used 400, the 800, got it right down, then 2 dust coats of the plastic adhesion primer where the plastic showed through, then 3light coats of primer. Then it went dark.
Left 15 mins between coats and so far so good.
Needs a few more coats of primer to cover all imperfetions/hide where the bla plastic woe through.
Should be sorted by the weekend.
Thanks for all the advice dudes.
Stu
The last post was made 13 years, 186 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 77.67 Kb
