This stupid engine modification...
karthead
PostPosted: 11:55 - 22 Aug 2012    Post subject: This stupid engine modification... Reply with quote
So my friend was on about some engine modification where one cuts the camshaft and/or crankshaft, rotates them a certain amount of degrees and welds it back together, along with some machining and what not to make the camshaft/crankshaft smooth again. in doing this, half the engine will fire, then the other half and so on. there would be no gain in power of course, but seeing it run would be fricken hilarious i would imagine (he was referring to a v8 or I4 when he was talking about this). He said his uncle did it to a v8 and it was pretty crazy...
He referred to it as an actual modification, like, it actually had a name. Anyone familiar with it? Anyone heard of it being done?
The engine would be so off balance and vibrate so much the mounts wouldn't last very long i would imagine. I'm pretty sure some engines are purposely set up like this, but he was talking about four of the cylinders on a v8 firing, then the other four...
I've been trying to find videos of something similar being done, no luck. So, anyone else heard of engine modifications like these being done?
PostPosted: 11:57 - 22 Aug 2012    Post subject: Reply with quote
Sounds like your being wound up...
Jamie.
PostPosted: 11:59 - 22 Aug 2012    Post subject: Reply with quote
The question here is why? Confused
Suntan Sid
PostPosted: 12:03 - 22 Aug 2012    Post subject: Reply with quote
Some light reading here:-
https://en.wikipedia.org/wiki/Big-bang_firing_order
stonesie
PostPosted: 12:38 - 22 Aug 2012    Post subject: Reply with quote
The main one I can think of is the current R1 with it's crossplane engine, still not a big bang engine though.
OP, you are being wound up, cutting and welding a crank is not something you can do in your garden shed, and I have never heard of it being done. It would have to be a very good and even weld to keep the crank from snapping like a twig... Friction welding might work.
PostPosted: 13:23 - 22 Aug 2012    Post subject: Reply with quote
My TDM has a big bang engine Cool
ThoughtContro...
PostPosted: 14:37 - 22 Aug 2012    Post subject: Reply with quote
I imagine you'd have to be able to weld to at least 4 thou too Wink
Prize cunt
PostPosted: 17:00 - 22 Aug 2012    Post subject: Reply with quote
Yes you can. But you use a sleeve and key, not just welding.
Allen Millyard is famous for doing it. It's how he makes these:
https://www.machiv.fr/anniv/after/5cyl.jpg
The999Kid
PostPosted: 21:25 - 22 Aug 2012    Post subject: Reply with quote
5 cylinder engine?! This is madness!!
Frost
PostPosted: 21:56 - 22 Aug 2012    Post subject: Reply with quote
Not madness, common sense that won honda motoGP titles
https://www.roadcarvin.com/sites/default/files/images/rc211v_engine.JPG
a 5 cylinder stroker is a bit bonkers though Very Happy
karthead
PostPosted: 06:07 - 23 Aug 2012    Post subject: Reply with quote
Yeah well my friend referred to it as welding the crankshaft or camshaft or whatever. Friction welding did come across in my mind, but i would imagine it would be quite difficult to end the weld at the right angle.
So, big-bang engine, that sounds like the one Very Happy
I would imagine the rpms would be pretty low.
Also there isn't really a question, its more of a discussion.
PostPosted: 06:59 - 23 Aug 2012    Post subject: Reply with quote
You could very easily make an engine 'big bang' by cutting and welding the camshaft (or making a new one). No need to touch the crank at all. Cut the camshaft in the middle and rotate one half 180 degrees then re-join by weld/sleeve/both. Now, cylinders 1 and 4 will fire together and so will 2 and 3. Don't even have to touch the ignition.
I might do it one day just for a laff.
The Artist
PostPosted: 08:11 - 23 Aug 2012    Post subject: Reply with quote
Big difference. Laughing
PostPosted: 09:40 - 23 Aug 2012    Post subject: Reply with quote
Really? How?
nowhere.elysium
The Pork Lord
PostPosted: 09:43 - 23 Aug 2012    Post subject: Reply with quote
chris-red wrote:
Really? How?
Wasted spark, I'd imagine.
beast rider
PostPosted: 10:17 - 23 Aug 2012    Post subject: Reply with quote
chris-red wrote:
Really? How?
At a guess, swapping the HT leads around so instead of 1.3.4.2 it would fire 1.4.3.2
PostPosted: 10:29 - 23 Aug 2012    Post subject: Reply with quote
chris-red wrote:
Really? How?
Because for most inline-4 bikes the spark occurs at every TDC, though it's only needed for every other - 'wasted spark', as above.
Fizzer Thou
PostPosted: 14:49 - 23 Aug 2012    Post subject: Reply with quote
HRC Honda built the 6X which was a VFR750 with a modified crank which had been cut and rewelded to change the firing pattern,effectively changing it from a V4 with an even firing to become an engine firing two cylinders simultaneously.I seem to remember a bloke who worked for Honda UK also built one and was very successful.
Found this : https://www.youtube.com/watch?v=BoXm6aeGl_Y
Always have a 'Plan B'
nowhere.elysium
The Pork Lord
PostPosted: 14:53 - 23 Aug 2012    Post subject: Reply with quote
That's got the most amazing musical accompaniment Laughing
PostPosted: 15:26 - 23 Aug 2012    Post subject: Reply with quote
The VFR doesn't have an even firing pattern - not possible with a shared journal vee configuration. Rotating half the crank effectively created a V4 with V-twin characteristics.
sniff6
PostPosted: 16:22 - 23 Aug 2012    Post subject: Reply with quote
Yeh But what does it sound like?????
https://www.youtube.com/watch?v=_hn9LidVa6g
'Great Britain' Love it https://img43.imageshack.us/img43/3967/67004290.gif or Leave it
400bandit
PostPosted: 18:46 - 24 Aug 2012    Post subject: Reply with quote
XS650's have this done quite often, I think it's referred to as re-phasing...
Joe
stonesie
PostPosted: 20:45 - 24 Aug 2012    Post subject: Reply with quote
I will consider myself educated on this then Laughing That 5 pot stroker sounds awesome.
The last post was made 13 years, 193 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 124.91 Kb
