| karthead |
 karthead Trackday Trickster
 Posted: 11:55 - 22 Aug 2012 Post subject: This stupid engine modification... |
So my friend was on about some engine modification where one cuts the camshaft and/or crankshaft, rotates them a certain amount of degrees and welds it back together, along with some machining and what not to make the camshaft/crankshaft smooth again. in doing this, half the engine will fire, then the other half and so on. there would be no gain in power of course, but seeing it run would be fricken hilarious i would imagine (he was referring to a v8 or I4 when he was talking about this). He said his uncle did it to a v8 and it was pretty crazy...
He referred to it as an actual modification, like, it actually had a name. Anyone familiar with it? Anyone heard of it being done?
The engine would be so off balance and vibrate so much the mounts wouldn't last very long i would imagine. I'm pretty sure some engines are purposely set up like this, but he was talking about four of the cylinders on a v8 firing, then the other four...
I've been trying to find videos of something similar being done, no luck. So, anyone else heard of engine modifications like these being done?
| MarJay |
 MarJay But it's British!
| Jamie. |
 Jamie. World Chat Champion
 Posted: 11:59 - 22 Aug 2012 Post subject: |
The question here is why?  |
| Suntan Sid |
 Suntan Sid World Chat Champion
| stonesie |
 stonesie World Chat Champion
| chris-red |
 Posted: 13:23 - 22 Aug 2012 Post subject: |
My TDM has a big bang engine  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| ThoughtContro... |
 ThoughtContro... World Chat Champion
| stinkwheel |
| The999Kid |
 The999Kid World Chat Champion
| Frost |
 Frost World Chat Champion
| karthead |
 Posted: 06:07 - 23 Aug 2012 Post subject: |
Yeah well my friend referred to it as welding the crankshaft or camshaft or whatever. Friction welding did come across in my mind, but i would imagine it would be quite difficult to end the weld at the right angle.
So, big-bang engine, that sounds like the one
I would imagine the rpms would be pretty low.
Also there isn't really a question, its more of a discussion. |
| Pete. |
 Pete. Super Spammer
 Posted: 06:59 - 23 Aug 2012 Post subject: |
You could very easily make an engine 'big bang' by cutting and welding the camshaft (or making a new one). No need to touch the crank at all. Cut the camshaft in the middle and rotate one half 180 degrees then re-join by weld/sleeve/both. Now, cylinders 1 and 4 will fire together and so will 2 and 3. Don't even have to touch the ignition.
I might do it one day just for a laff. ____________________ a.k.a 'Geri'
| The Artist |
 The Artist Super Spammer
 Posted: 08:11 - 23 Aug 2012 Post subject: |
| andresoccer10 wrote: | Yeah well my friend referred to it as welding the crankshaft or camshaft or whatever. Friction welding did come across in my mind, but i would imagine it would be quite difficult to end the weld at the right angle.
Big difference.  |
| chris-red |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| beast rider |
 beast rider Could Be A Chat Bot
| Pete. |
 Pete. Super Spammer
| Fizzer Thou |
 Posted: 14:49 - 23 Aug 2012 Post subject: |
HRC Honda built the 6X which was a VFR750 with a modified crank which had been cut and rewelded to change the firing pattern,effectively changing it from a V4 with an even firing to become an engine firing two cylinders simultaneously.I seem to remember a bloke who worked for Honda UK also built one and was very successful.
Found this : https://www.youtube.com/watch?v=BoXm6aeGl_Y ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| nowhere.elysium |
| Pete. |
 Pete. Super Spammer
 Posted: 15:26 - 23 Aug 2012 Post subject: |
The VFR doesn't have an even firing pattern - not possible with a shared journal vee configuration. Rotating half the crank effectively created a V4 with V-twin characteristics. ____________________ a.k.a 'Geri'
| sniff6 |
 sniff6 World Chat Champion
| 400bandit |
 400bandit World Chat Champion
| stonesie |
 Posted: 20:45 - 24 Aug 2012 Post subject: |
I will consider myself educated on this then That 5 pot stroker sounds awesome. |
The last post was made 13 years, 195 days ago. Instead of replying here, would creating a new thread be more useful? |
