Brakes- UPDATE
promufa
PostPosted: 22:36 - 22 Aug 2012    Post subject: Brakes- UPDATE Reply with quote
I 've had spongy brake syndrome for quite a while now, w/o any fluid leaks anywhere. Even after bleeding several times, the problem persists. Bike has braided lines from stock by maybe they went bad... dunno. I decided to pop the calipers off the forks and give the pistons a good clean.
None of the pistons are seized or anything but they definitely don't move at the same time. Even after I cleaned them as best I good while still in the caliper, not much changed. I also noticed some pitting and surface rust on one or two pistons.
I guess I ll have to take the pistons out to give them a really good clean. Unfortunately the pistons are very long and cannot pop them out w/o spliting the caliper (I think, if there is a way let me know pls) Is there any way to repair the pitted ones or I need to fork out for new pistons? Damage is minimal really.
TL;DR are slightly pitted caliper pistons salvageable?
Thanks
'02 Triumph Speed Four
Casper
PostPosted: 23:29 - 22 Aug 2012    Post subject: Reply with quote
Pistons dont move at the same time as you have air in the lines. Try a big syringe and pump the fluid in the nipple pushing the air up to the res.
promufa
PostPosted: 23:51 - 22 Aug 2012    Post subject: Reply with quote
Forgot to mention that, tried reverse bleeding as well
A bit better but still not great :S
Thanks for the hint though
Budgetboy
PostPosted: 00:10 - 23 Aug 2012    Post subject: Reply with quote
Pitting on the pistons wont help with movement also dodgy seals or cheap seals will also cause the same effect.
Pitting will cause the piston to catch on the seal and will stop it or slow it down from moving..And bad seals or old seals are just that,, they swell and cause more friction on the pistons and slow the movement.
IMO it sounds like you need to strip and rebuild your calipers. Thumbs Up
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
promufa
PostPosted: 00:23 - 23 Aug 2012    Post subject: Reply with quote
That's what I was planning to do. Split calipers pop pistons out, change seals. I just cant fork out any cash for new pistons atm. Is there any way of repairing the ones that are slightly pitted? Will something like wet and dry or autosol work on this or is it just going to make it worse?
Budgetboy
PostPosted: 09:42 - 23 Aug 2012    Post subject: Reply with quote
2000 grit wet n dry will get some pitting out. But imo you should not be skimping on brakes.
Do a job once and do it right is my motto mate. Thumbs Up
PostPosted: 10:38 - 23 Aug 2012    Post subject: Reply with quote
Sponginess in a closed hydraulic system is either air in the system or knackered rubber brake lines.
It's nothing to do with the pistons.
Try bleeding it at the banjo bolts rather than the bleed nipple.
Also try tying the lever down to the handlebars overnight.
PostPosted: 10:50 - 23 Aug 2012    Post subject: Reply with quote
Nonsense, it means some are sticking and it needs either a clean up of the pistons, or even a rebuild with new seals/pistons.
Personally I would pop the pistons out and clean then with brake cleaner and a toothbrush, maybe as has been said with sandpaper/ but I wouldn't want to use something that abrasive maybe start with a kitchen scourer. Once clean grease them up with Red rubber grease/silicon grease. and they should be fine. If not a rebuild is required. I think wemoto sell replacement pistons seals, If you can afford it I would go down that route rather than using sandpaper etc.
+1 to what stinkwheel said about the spongyness
Casper
PostPosted: 10:59 - 23 Aug 2012    Post subject: Reply with quote
chris-red wrote:
So one side cant have more air than the other then. All the energy will be getting used to compress the air rather than push the fluid. This would be more so with two brake lines going straight to M/C rather than a splitter half way up.
On the subject of spliters. My brakes would not bleed proper and after a good think i was down to blaming the splitter. It turns out it has a lip on the inside and could trap air. I undid this from the yoke and sat it sideways and bled the brakes. More air came out.
supZ
PostPosted: 11:39 - 23 Aug 2012    Post subject: Reply with quote
right, a few confusions in this thread.
1. a little pitting on the exposed sides of the piston is fine. if the pitting runs down to the seal then you'll have a problem and they need to be replaced. otherwise dont worry. (technically, you only need to worry if the pitting is as far down as the main seal but if its reached the dust seal then its a good idea to change)
2. pistons always move differently to each other. one will always get more force than the other. its not a sign of a problem.
to the OP when you say its always spongy what exactly do you mean? does it get solid if you pump the lever but the next day its spongy again? in this case it'll be your m/c seals going and you'll need to buy a recon/repair kit off ebay (less than £20) and replace the seals/spring. easy job to do.
if its just consistently spongy then either there is air in the system or there is a bad seal somewhere (banjo washer/calliper seal). i had this with a crap washer, took me a while to realise that was the reason it wouldnt bleed properly.
reverse bleeding as mentioned above is a superb method but if you say its not making a difference then there probably is a leak somewhere. it shouldnt be that hard to bleed the brakes. when bleeding normally do you continuously get bubbles or does the fluid look air free before you nip the valve up again?
you are bleeding both callipers properly yeh?
might be worth buying some copper crush washers, replacing the old ones and buying a calliper seal kit. its very easy to change them. pop the pistons, get the seals out, soak in new fluid and replace with new ones then pop pistons back in. job done.
bit of a cop out to say 'if you cant figure it out replace all your seals and washers and start again' but sometimes its the only way to be sure Smile
CBR954RR - Daily toy
CBR600RR - Trackbike
promufa
PostPosted: 12:33 - 23 Aug 2012    Post subject: Reply with quote
Thanks all for you replies.
Pitting is just outside the dust seal and the pads are almost new so I guess it wont be going behind the seals (could probably leave it as it is for now)
How do you bleed from the banjo?
It doesnt look like there is a leak in the system. I have checked every washer/piston seal, no sign of brake fluid around it.
The bike has an over-the-mudguard link setup. I start reverse bleeding for the left caliper (further away from the M/C). I pump about 2-3 reservoirs worth of brake fluid through and the repeat on the right. I also tap the line lightly while pumping the fluid through.
Pretty much spot on. I managed to get the lever hard once but it went spongy again 4-5 traffic lights later.
PostPosted: 13:55 - 23 Aug 2012    Post subject: Reply with quote
Same way you do from the nipple, only messier.
map
Mr Calendar
PostPosted: 14:03 - 23 Aug 2012    Post subject: Reply with quote
I generally find getting access to the banjo bolt at the reservoir, put a rag under it and crack the bolt open. Hopefully air followed by a little fluid should then appear. Nip up the bolt quickly to stop fluid. Then check if the reservoir needs topping up.
Find some air can get trapped in the usual bend to the banjo.
If still have problems then I can only think it maybe the seals in the reservoir. You should be able to get a kit to refurb that quite easily. See if the likes of wemoto have the kit for your bike.
I'm having a similar issue with an hydraulic clutch. Constant use in traffic sees the bite point moving closer to the bars. SO much so the clutch refuses to disengage. I'm thinking it's the seal on the slave reservoir. Leave the bike stood and it corrects itself! Go figure.
supZ
PostPosted: 16:22 - 23 Aug 2012    Post subject: Reply with quote
tis a pretty good bet that the m/c seals are going then as said Smile
no amount of bleeding is going to sort it and you'll just be wasting fluid.
get a recon/repair kit off ebay (search for master cylinder repair 'insert bike here') and off you go. as said its a very easy thing to do, although you will need some new crush washers as well as its far easier to take the m/c off to do it rather than attempting to get it done with the lines attached Smile
if you a haynes manual follow that, if not post up and i'll be able to direct you. the cir-clip under the dust seal/cap that holds the barrel in can be a right pain to get off if waters got in and its rusted but its not 'too' difficult. i worked mine loose with a little screwdriver. you'll need some cir-clip pliers though to get it out. once the clips out you'll be able to pull the barrel and spring out and see where the seals go. all you do is assemble the new stuff the same way (soaking in brake fluid first) and re-assemble into the m/c. job done.
good luck Smile
promufa
PostPosted: 01:55 - 24 Aug 2012    Post subject: Reply with quote
Ordered a master cylinder kit, new piston seals all around, fluid washers etc.
I 'll get the pistons out when everything is here and have a go at cleaning them properly. I hope I wont need new ones Sick
The bike has braided lines from stock. Do they go bad at some point or is it just an issue of not bending them? Bike is 10 years old now around 29k miles
Thanks all for the help Smile
supZ
PostPosted: 10:08 - 24 Aug 2012    Post subject: Reply with quote
nah braided lines should, within reason, last forever. its only the standard rubber hoses that can perish and weaken over time.
when i cleaned my pistons up i used a wire attachment on my dremel to get the grime off and then swapped to a polishing end to bring it up. worked wonders Very Happy
not the best pics but..
https://farm9.staticflickr.com/8286/7723865456_c1e519edba_b.jpg
to
https://farm9.staticflickr.com/8281/7723867134_d1f681559b_b.jpg
you can just see the pitting at the end of the piston. no where near the seals so it wasnt an issue for mine.
with mine i took everything apart. cleaned all anti-rattle springs, replaced slider boots..
its perhaps a bit late now but i presume when you ordered new seals for the callipers you also ordered new dust seals as well? ideally you'd get new slider boots but that all depends on the condition of yours (if your brakes are similar to my trackbikes)
good luck! let us know how you get on Smile
promufa
PostPosted: 10:53 - 24 Aug 2012    Post subject: Reply with quote
to
My pistons are in about the same condition. Dont have a dremel handy here so its gonna by elbow grease possibly with a kitchen sponge (green scoury side). It's not too harsh is it?
Seals are a set. It has oil and dust seals in ...
supZ
PostPosted: 23:57 - 28 Aug 2012    Post subject: Reply with quote
so how'd you get on in the end?
all fixed?
promufa
PostPosted: 13:09 - 04 Sep 2012    Post subject: Reply with quote
Just finished the whole job today.
Pistons cleaned up quite nicely with a green kitchen scourer and 2-3 hours worth of scrubbing. 1 of the pistons has a small ship but that is on the exposed surface just past the dust seal so it should be ok.
The seal seat where completely clean, no corrosion or gunk of any kind. Replaced all seals after sparingly coating them with rubber grease.
Light coat of rubber grease on the pistons and back in the caliper they went.
Replaced the crush washers on both calipers.
The rubber rings on the M/C piston were perished and I suspect that was the source of the problem. Now changed.
Filled up with brake fluid from the nipple. On the plus side the brakes work so I didn't fuck it up. It still a bit spongy but much better than what it was. I will let it settle and bleed again tonight or tomorrow.
The only things that are now used are the brake lines, 2 crush washers on the M/C and the small seals inside the caliper halves.
Those seals were in really good condition and had no signs of leaks when I split the calipers (ie brake fluid only on the inside of the seal, outside and seating completely dry)
promufa
PostPosted: 13:14 - 04 Sep 2012    Post subject: Reply with quote
On a different note, how tight do the caliper bolts need to be? I am talking about the 4 bolts that keep the 2 halves together - workshop manual doesn't say anything about it. I 've done them up to 25ft/lb atm.
map
Mr Calendar
PostPosted: 13:19 - 04 Sep 2012    Post subject: Reply with quote
promufa wrote:
...still a bit spongy but much better than what it was. I will let it settle and bleed again tonight or tomorrow....
Leave lever tied back to bars overnight and then check (similar can do with rear pedal if you can tie/weight it down).
Otherwise good news Thumbs Up
supZ
PostPosted: 15:47 - 04 Sep 2012    Post subject: Reply with quote
sounds like you're on the right track now, nice one Smile
personally though i wouldnt have used any rubber grease, id have just soaked them in new brake fluid for 10mins before fitting the seals (as per haynes recommendation)
and definitely wouldnt reuse crush washers.. from the very name, they crush as you use them so unless you've been annealing them in the oven id use new. you can end up with a bad seal by reusing old ones.
just my opinion.
as you say though.. see how it goes, hopefully any air thats left in will work its way out and your brakes will be back to how they're meant to be again Very Happy
The last post was made 14 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 140.75 Kb
