| promufa |
 promufa Scooby Slapper
| Casper |
 Casper World Chat Champion
| promufa |
| Budgetboy |
 Budgetboy Scooby Slapper
 Posted: 00:10 - 23 Aug 2012 Post subject: |
Pitting on the pistons wont help with movement also dodgy seals or cheap seals will also cause the same effect.
Pitting will cause the piston to catch on the seal and will stop it or slow it down from moving..And bad seals or old seals are just that,, they swell and cause more friction on the pistons and slow the movement.
IMO it sounds like you need to strip and rebuild your calipers.  ____________________ www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken. |
| promufa |
| Budgetboy |
 Posted: 09:42 - 23 Aug 2012 Post subject: |
2000 grit wet n dry will get some pitting out. But imo you should not be skimping on brakes.
Do a job once and do it right is my motto mate.  ____________________ www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken. |
| stinkwheel |
 Posted: 10:38 - 23 Aug 2012 Post subject: |
Sponginess in a closed hydraulic system is either air in the system or knackered rubber brake lines.
It's nothing to do with the pistons.
Try bleeding it at the banjo bolts rather than the bleed nipple.
Also try tying the lever down to the handlebars overnight. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Vincent |
 Vincent Banned
| chris-red |
| Casper |
| supZ |
 supZ World Chat Champion
 Posted: 11:39 - 23 Aug 2012 Post subject: |
right, a few confusions in this thread.
1. a little pitting on the exposed sides of the piston is fine. if the pitting runs down to the seal then you'll have a problem and they need to be replaced. otherwise dont worry. (technically, you only need to worry if the pitting is as far down as the main seal but if its reached the dust seal then its a good idea to change)
2. pistons always move differently to each other. one will always get more force than the other. its not a sign of a problem.
to the OP when you say its always spongy what exactly do you mean? does it get solid if you pump the lever but the next day its spongy again? in this case it'll be your m/c seals going and you'll need to buy a recon/repair kit off ebay (less than £20) and replace the seals/spring. easy job to do.
if its just consistently spongy then either there is air in the system or there is a bad seal somewhere (banjo washer/calliper seal). i had this with a crap washer, took me a while to realise that was the reason it wouldnt bleed properly.
reverse bleeding as mentioned above is a superb method but if you say its not making a difference then there probably is a leak somewhere. it shouldnt be that hard to bleed the brakes. when bleeding normally do you continuously get bubbles or does the fluid look air free before you nip the valve up again?
you are bleeding both callipers properly yeh?
might be worth buying some copper crush washers, replacing the old ones and buying a calliper seal kit. its very easy to change them. pop the pistons, get the seals out, soak in new fluid and replace with new ones then pop pistons back in. job done.
bit of a cop out to say 'if you cant figure it out replace all your seals and washers and start again' but sometimes its the only way to be sure  ____________________ CBR954RR - Daily toy
CBR600RR - Trackbike |
| promufa |
| stinkwheel |
| Vincent |
 Vincent Banned
 Posted: 13:55 - 23 Aug 2012 Post subject: |
None of us has asked what the bike/caliper type is yet If it's in two halfs, could be that the seal in between is leaking. ____________________ Space Is Deep |
| Vincent |
 Vincent Banned
 Posted: 13:58 - 23 Aug 2012 Post subject: |
| map |
 map Mr Calendar
| supZ |
 Posted: 16:22 - 23 Aug 2012 Post subject: |
| promufa |
 Posted: 01:55 - 24 Aug 2012 Post subject: |
Ordered a master cylinder kit, new piston seals all around, fluid washers etc.
I 'll get the pistons out when everything is here and have a go at cleaning them properly. I hope I wont need new ones
The bike has braided lines from stock. Do they go bad at some point or is it just an issue of not bending them? Bike is 10 years old now around 29k miles
Thanks all for the help  ____________________ '02 Triumph Speed Four |
| supZ |
 Posted: 10:08 - 24 Aug 2012 Post subject: |
nah braided lines should, within reason, last forever. its only the standard rubber hoses that can perish and weaken over time.
when i cleaned my pistons up i used a wire attachment on my dremel to get the grime off and then swapped to a polishing end to bring it up. worked wonders
not the best pics but..
https://farm9.staticflickr.com/8286/7723865456_c1e519edba_b.jpg
to
https://farm9.staticflickr.com/8281/7723867134_d1f681559b_b.jpg
you can just see the pitting at the end of the piston. no where near the seals so it wasnt an issue for mine.
with mine i took everything apart. cleaned all anti-rattle springs, replaced slider boots..
its perhaps a bit late now but i presume when you ordered new seals for the callipers you also ordered new dust seals as well? ideally you'd get new slider boots but that all depends on the condition of yours (if your brakes are similar to my trackbikes)
good luck! let us know how you get on  ____________________ CBR954RR - Daily toy
| promufa |
 Posted: 10:53 - 24 Aug 2012 Post subject: |
| supZ wrote: | nah braided lines should, within reason, last forever. its only the standard rubber hoses that can perish and weaken over time.
to
good luck! let us know how you get on  |
My pistons are in about the same condition. Dont have a dremel handy here so its gonna by elbow grease possibly with a kitchen sponge (green scoury side). It's not too harsh is it?
Seals are a set. It has oil and dust seals in ... ____________________ '02 Triumph Speed Four |
| supZ |
| promufa |
| promufa |
| map |
 map Mr Calendar
| supZ |
 Posted: 15:47 - 04 Sep 2012 Post subject: |
sounds like you're on the right track now, nice one
personally though i wouldnt have used any rubber grease, id have just soaked them in new brake fluid for 10mins before fitting the seals (as per haynes recommendation)
and definitely wouldnt reuse crush washers.. from the very name, they crush as you use them so unless you've been annealing them in the oven id use new. you can end up with a bad seal by reusing old ones.
just my opinion.
as you say though.. see how it goes, hopefully any air thats left in will work its way out and your brakes will be back to how they're meant to be again  ____________________ CBR954RR - Daily toy
The last post was made 14 years, 33 days ago. Instead of replying here, would creating a new thread be more useful? |
