Need help GSXR K3 600
deamoon
PostPosted: 20:30 - 24 Aug 2012    Post subject: Need help GSXR K3 600 Reply with quote
Problem is that when im riding it speedo misreads the speed when you actually on 30mph it shows 40+-mph, so the difference is about 10 miles.
Could you tell me where to look or to do to sort it out?
Speedo sensor cleaned. There are some scratching on sensor itself but not to deep, maybe that causes misread?
Thank you for all help
PostPosted: 21:10 - 24 Aug 2012    Post subject: Reply with quote
Different sprockets installed on the bike?
Budgetboy
PostPosted: 21:21 - 24 Aug 2012    Post subject: Reply with quote
16 tooth front
45 tooth rear
thats standard for your model
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
deamoon
not that i know. I have the bike just over a month
deamoon
PostPosted: 21:22 - 24 Aug 2012    Post subject: Reply with quote
Budgetboy wrote:
16 tooth front
45 tooth rear
ok ill go to check tomorrow
PostPosted: 21:28 - 24 Aug 2012    Post subject: Reply with quote
That would cause an issue for you for sure! Check current teeth and you will probably find they are out.
deamoon
PostPosted: 21:30 - 24 Aug 2012    Post subject: Reply with quote
Will do in day light to make sure im accurate. Speedo healer would be my solution right?
deamoon
PostPosted: 20:27 - 25 Aug 2012    Post subject: Reply with quote
right looked at rear sprocket and its a TALON 525 TR377-43
So i think its a 43Tooth sprocket not 45 original
Casper
PostPosted: 20:47 - 25 Aug 2012    Post subject: Reply with quote
Is it a UK bike? Some cowboy may have changed the clock face from KPH.
PostPosted: 20:58 - 25 Aug 2012    Post subject: Reply with quote
You can do MPH + KMH on the GSXR speedos if its a digital one.
Those sprockets will mess the speed up, its been set more more top end.
Casper
PostPosted: 21:13 - 25 Aug 2012    Post subject: Reply with quote
Now you mention it i think it is digital with the rev counter being a clock.
Ill shut up now. Very Happy
deamoon
PostPosted: 21:46 - 25 Aug 2012    Post subject: Reply with quote
It is UK bike and yes you can change KPH or MPH and it says MPH
PostPosted: 21:48 - 25 Aug 2012    Post subject: Reply with quote
You can get a speedo healer which will sort that for you.
deamoon
PostPosted: 21:54 - 25 Aug 2012    Post subject: Reply with quote
Thinking about it just that its nearly 90 smackers
PostPosted: 21:55 - 25 Aug 2012    Post subject: Reply with quote
Cheaper to buy the stock rear sprocket and a chain Wink
deamoon
PostPosted: 21:56 - 25 Aug 2012    Post subject: Reply with quote
It is but i never done sprocket change will i be able to do it myself?
PostPosted: 22:00 - 25 Aug 2012    Post subject: Reply with quote
Changing the rear sprocket on one of those is simple.
Loosen the sprocket nuts whilst wheel is still on bike.
Unbolt the rear wheel, think you need a 36mm socket.
Slide spindle out and lay wheel down, undo the bolts, remove sprocket and add new one.
Do the reverse. You'll have enough room on the adjusters to match your chain up to a slightly bigger sprocket Thumbs Up
That said, you are in Essex, if you were able to ride to Maidstone in Kent, I'd happily give you guidance on doing it/do it for you for free Thumbs Up Pretty sure someone in Essex would be able to do so also Wink
Rob W
PostPosted: 22:06 - 25 Aug 2012    Post subject: Reply with quote
Your not far from me, I could give you a hand to change the rear sprocket.
deamoon
PostPosted: 22:46 - 25 Aug 2012    Post subject: Reply with quote
Thats very nice of you guys. Now what sprocket to look for any company that you use most?
Sorry guys but this is my 1st big bike and 2nd bike in my life so not much of knowledge here Embarassed Embarassed
Rob W
PostPosted: 22:49 - 25 Aug 2012    Post subject: Reply with quote
Whereabouts are you?
You could try John's of Romford, they usually have a fair bit in stock. If not try Soper's in Southend. Failing that eBay it and wait a few days.
Gimme a shout when you get one, and I'll change it for you if you want.
Casper
PostPosted: 23:28 - 25 Aug 2012    Post subject: Reply with quote
How is the chain? If its looking almost past it look at spending 120 quid (posted) on a new chain and sprocket kit.
https://www.wemoto.com/bikes/suzuki/gsxr_600_k3_zk3/03/picture/chain_and_sprocket_kit_did/
More for your bike
PostPosted: 08:41 - 26 Aug 2012    Post subject: Reply with quote
nice one Rob Thumbs Up
Rob W
PostPosted: 10:24 - 27 Aug 2012    Post subject: Reply with quote
Did you get anything sorted?
deamoon
PostPosted: 17:29 - 29 Aug 2012    Post subject: Reply with quote
No not yet waiting for speedo healer to finish on ebay hoping no one going to bid on it.
deamoon
PostPosted: 15:13 - 30 Aug 2012    Post subject: Reply with quote
right guys:
FRONT sprocket 13 tooth
REAR sprocket 43Tooth
What this setup gives if anything
Many thanks
The last post was made 14 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 123.12 Kb
