Under powered, over revving
Paris2
PostPosted: 15:40 - 26 Aug 2012    Post subject: Under powered, over revving Reply with quote
So, im cruising down the motorway at about 60mph. I give it some beans to overtake a few cars, the bike gets to 70 and is sitting at around 6k rpm, I keep the throttle on and it revs to around 8k rpm but the bike doesnt speed up at all.
The engine is obviously revving higher but the bike isnt going faster, as if the wheel is spinning, which it isn't.
Any ideas on what is up. This has only happened today, after I have tightened my chain. Coincidence?
Help appreciated.
In before "its an SV of course its underpowered" Laughing Middle Finger
Current Ride: Daytona 600
Casper
PostPosted: 15:58 - 26 Aug 2012    Post subject: Reply with quote
Go an play at taking off on a hill. You clutch may be starting to slip.
PostPosted: 16:23 - 26 Aug 2012    Post subject: Reply with quote
Slipping clutch. My GSXR did similar but was very pronounced, from 70 onwards it just added a few thousand rpm but no go Laughing
Rob W
PostPosted: 16:55 - 26 Aug 2012    Post subject: Reply with quote
Vincent wrote:
You havn't filled up with any car multigrade oil recently have you?
Or fully synth? Think it was my ZXR4 that it made the clutch slip like mad when I used fully synth. Never used it since.
Paris2
PostPosted: 19:18 - 26 Aug 2012    Post subject: Reply with quote
Cheers guys.
The bike has felt very underpowered for a while also, related?
I've not changed the oil in a while so it can't be that, clutch it must be. Is it safe/ok to ride as I need it for work or is it best left alone till fixed?
Is it an easy fix, because I have limited knowledge and funds.
Casper
PostPosted: 19:31 - 26 Aug 2012    Post subject: Reply with quote
Paris2 wrote:
Cheers guys.
Easy fix and you can ride it but remember it will get worse so order the parts now but before you do check your cable has not come lose first or if hydrolic check the fluid. Take the ride easy as the hotter it gets the worse it will slip.
PostPosted: 19:46 - 26 Aug 2012    Post subject: Reply with quote
It gets worse.. Laughing
Paris2
PostPosted: 19:59 - 26 Aug 2012    Post subject: Reply with quote
Cheers, I'll check the cable first thing. Knowing my bike it's something simple like that which causes the problem.
If not I'll take it easy and await the over revving lols before parts arrive.
PostPosted: 09:42 - 27 Aug 2012    Post subject: Reply with quote
Vincent wrote:
Make sure you have 1 or 2mm freeplay at the bar lever too.
Sure, don't go diving at the clutch plates like a bull at a gate.
If there's no slack in the lever, find the adjuster which screws into the clutch lever assembly on the bars. Slacked off the locknut to allow you to screw the adjuster in a bit. This'll give some slack in the cable.
Paris2
PostPosted: 15:29 - 27 Aug 2012    Post subject: Reply with quote
I've adjusted the cable at the lever end and it hasn't helped, the cable is proper stiff though, I think the casing is bunged up a fair amount. I'll try and sort that see if it helps
Paris2
PostPosted: 17:36 - 28 Aug 2012    Post subject: Reply with quote
Old cable is shagged, new one on order.
I'm not optimistic that it will help though.
mysterious_rider
PostPosted: 17:37 - 28 Aug 2012    Post subject: Reply with quote
Old cable probably dragging. New cable will sort it aslong as clutch is okay. If not , change plates and springs in clutch. Thumbs Up
PostPosted: 17:43 - 28 Aug 2012    Post subject: Reply with quote
Expect it to give up at anytime and leave you stranded.
PostPosted: 18:46 - 28 Aug 2012    Post subject: Reply with quote
Sounds like it needs replacing anyway, so keep your pecker up, you might be lucky.
Paris2
PostPosted: 18:11 - 29 Aug 2012    Post subject: Reply with quote
New cable in with a little help from Mikey3.
The old one was so shot that between the two of us we couldn't move it through its outer casing without the use of the clutch lever. Laughing
It feels much better though I'm not convinced it has solved the problem. I shall be able to tell in a few days I'm sure.
PostPosted: 19:03 - 29 Aug 2012    Post subject: Reply with quote
It takes 5 minutes to whip the cover off and adjust the clutch Neutral
sgtcalle
PostPosted: 19:36 - 29 Aug 2012    Post subject: Reply with quote
having problems similar to this myself. quick question, my clutch first started slipping when i went over a bump, do you think this points towards clutch springs/plates, rather than the cable?
CBR600F '02
Manchester
sgtcalle
PostPosted: 19:40 - 29 Aug 2012    Post subject: Reply with quote
that is to say, the clutch slips when i go over bumps, not i went over one bump and its been slipping ever since! Wink
CBR600F '02
Manchester
Paris2
PostPosted: 19:53 - 29 Aug 2012    Post subject: Reply with quote
Indeed it does.
Though if the new cable doesn't sort the problem I'm sure it will be plate/spring renewal time.
numpty2
PostPosted: 13:20 - 30 Aug 2012    Post subject: Reply with quote
There is a fair chance it was just the cable. I had the same problem once and simply changing the cable sorted it. I was all psyched up for the hassle & expense of new clutch plates. Big smile.
PostPosted: 14:45 - 30 Aug 2012    Post subject: Reply with quote
Do you not have a clutch adjuster on the engine. Mine worked on a weird mechanism that pushed a rod into the engine, this was causing the slip.
Need to have no adjustment set at all at the lever end.
Scotsman37
PostPosted: 20:12 - 30 Aug 2012    Post subject: Reply with quote
Make sure where the the pull/push cables that are attached at the carb end where the mechanism is attached can move freely move without it scraping/catching onto anything when it turns from off to max throttle because a sliight bend in the mechanism could make it rub against something?
Also make sure your spark plugs are ok and the HT leads to them are ok showing no corrossion where the leads fit into the plug cap ends onto the spark plugs.
The last post was made 14 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 119.19 Kb
