Chain Adjustment
Jonathan A
PostPosted: 21:57 - 27 Aug 2012    Post subject: Chain Adjustment Reply with quote
Hello!
The chain on my 125 has worked itself loose to the point of a jerky throttle and a horrid vibration. Me being the wimp I am I would usually go to my dealer to have it adjusted, but I am away from home at the moment Confused
Is it wise to bite the bullet and sort it out my self, and if so, what tips do you all have?
cheers
jon
the_quick
PostPosted: 22:02 - 27 Aug 2012    Post subject: Reply with quote
it is quite easy.
Just remember to turn both adjusting bolt by same amount of turns, and don't forget to tight wheel nut when you finished.
Easy job.
Bandit GSF600 '00
Cuchulain
PostPosted: 22:02 - 27 Aug 2012    Post subject: Re: Chain Adjustment Reply with quote
Jonathan A wrote:
Hello!
cheers
jon
It's a really simple job. There are loads of tutorials on youtube.
Have you got the owners manual for the bike? Mine tells you how to go about checking and adjusting the chain.
CBT 15/6/2011 Theory Test Passed 6/2/2012 Module 1 Passed 11/6/2012
Module 2 Passed!!! 19/6/2012
Jonathan A
PostPosted: 22:41 - 27 Aug 2012    Post subject: Reply with quote
Looked a bit at youtube and I think I have it sussed. Just one question, how tight should the axle nut be?
I looked at the manual,but its barely in English and it doesn't go into detail about the chain Mad
cheers
dungbug
PostPosted: 22:58 - 27 Aug 2012    Post subject: Reply with quote
What bike is it?
CBT: Pass 25/06/2011 Theory Test: Pass12/06/2012 Mod 1: Fail 08/07/2012
Mod 1 Retest: Pass 15/0702012 Mod 2: Pass 03/08/2012
Suzuki GN125 (Sold) ~ Current bike: Yamaha YZF 600R Thundercat
Jonathan A
PostPosted: 23:03 - 27 Aug 2012    Post subject: Reply with quote
Its a CPI Sprint Very Happy
blito
PostPosted: 08:47 - 28 Aug 2012    Post subject: Reply with quote
1) Measure the amount of slack on the chain - it should be between 1-2 inches of slack in the centre of the lower run of the chain. If the total amount of play is more than 2 inches then read on.
2) Loosen rear wheel retaining nuts (but not taking them off - you just want them to relinquish their grip)
3) There may be locking nuts on the adjusters to slacken.
4) Wind in the tension nuts - this effectively pulls the rear wheel backwards adding tension to the chain. Make sure you adjust both nuts evenly.
5) Measure the slack on the chain and also that the the wheel is straight.
6) Tighten the locknuts
7) Tighten the wheel nuts
8) Double check your measurements!
Takes about 5 minutes. Maybe worthwhile giving it a shot of chain lube at the same time as this will help slow down the wear rates of the chain and sprockets.
2012 Zontes Monster
PostPosted: 08:57 - 28 Aug 2012    Post subject: Reply with quote
All. All the tight. Use a spanner / socket bar less than twice your penis length (about 24", right?) and you're not going to shear it by hand.
Alpha-9
PostPosted: 09:03 - 28 Aug 2012    Post subject: Reply with quote
I imagine it's awkward taking you to a DIY store Thinking
Fzr-600 1999
PostPosted: 09:13 - 28 Aug 2012    Post subject: Reply with quote
No need to elaborate on whats been said but a good tip is to use a sharpie marker to draw a little line vertically on the end of your tension nuts. That way you can keep an eye on their position so you know you have done them both the same.
https://img.photobucket.com/albums/v494/be1ly/IMG_2436Medium.jpg
Like so. You know then if the black marks are in the same position on both sides your wheels straight.
Jonathan A
PostPosted: 12:07 - 28 Aug 2012    Post subject: Reply with quote
Cheers for all your help Smile I will give it a shot later on
map
Mr Calendar
PostPosted: 12:12 - 28 Aug 2012    Post subject: Reply with quote
Sort of on topic has anyone any step by step advice of adjusting chain tension with only a side stand?
This is for my lad who's currently stuck at his gf with a too slack chain. So, no sympathy from me then, numpty should indulge in some regular checks and maintenance (bike and gf, boom boom*).
I'm not too happy with his suggestion of strapping a paddock stand to my bike and taking it round for him (it's about 15 miles!). Going up after work anyhow to see if he's sorted it.
If it was me I'd just adjust it with the tension/adjusters on the side stand. At a push lever it on the side stand and front wheel and put an axle stand to raise the back wheel (forming a narrow triangle of 3 points of support). Anything I'm missing?
Thanks.
* as Basil would say
crackfinder
PostPosted: 18:08 - 28 Aug 2012    Post subject: Reply with quote
Thanks.
same process as with a centre/paddock stand, i adjust mine on the side stand....in fact my manual states to check it while on the side stand. Thumbs Up
Yamaha FZS600 Fazer (gone but not forgotten). Current - Kawasaki ZX6R A1P
Kwakki Si
PostPosted: 21:20 - 28 Aug 2012    Post subject: Reply with quote
Easy peesy my friend, just look on the tube. Wheel locking nut nice and snug.
MOD1 passed 26/01/12... MOD2 passed 08/02/12
My current ride: ZX6R NINJA G2, The GREEEEN one!
Is it a bird? Is it a plane? No, it's a mother fucking motorbike!
Andy_Pagin
PostPosted: 21:38 - 28 Aug 2012    Post subject: Reply with quote
If you've got a drum brake there will be a tie rod holding the middle part in place, you'll need to unbolt it along with the brake adjuster rod before you adjust the slack.
The last post was made 14 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 88.01 Kb
