| russell210276 |
 russell210276 Renault 5 Driver
 Posted: 18:24 - 30 Aug 2012 Post subject: fuel leaking nightmare |
hi got a bit of a nightmare on my rg gamma fuel is pissing out of the over flow starting to piss me off removed the carb and everything in the carb at least 6 times today things i have done.
replaced valve needle from another mikuni carb i had seemed to have sorted the problem for 10 mins then it dripped this time ever minute or so air bubbles in the line aswell if that makes a diffrence
set the float height to 25mm as per manual
checked the floats in water and seem ok they dont sink and no holes in them just float around.
cleaned carb as was due anyway
checked the valve float works by opening and closing the floats with my hand and i can go red in the face blowing into the carb it still doesnt leak till petrol is added the needle valve i put in was only used for a hour out of a brand new carb (chinky)
so now as we speak its filling the carb up as i can see through the petrol filter
i blocked off the second overflow which is half way up the carb and it pisses even more is that to do with anything?
many thanks russ |
| Casper |
 Casper World Chat Champion
| Scotsman37 |
 Scotsman37 World Chat Champion
| russell210276 |
 Posted: 23:26 - 30 Aug 2012 Post subject: |
i took both of your advice i checked the new valve needle against the old need and the new needle was slightly bigger about a few mm if that i changed back to the old needle because there looked to be nothing wrong in the first place sanded the pin and it been standing for the last 2 hours and running without a drip so many thanks too you both both of you get karma cheers russ |
| Casper |
 Posted: 00:04 - 31 Aug 2012 Post subject: |
Glad you got sorted mate. BTW, If you carbs are Mikuni and you ever need parts this crowd are quite cheap and a good service.
https://www.motocarb.co.uk/index.htm |
| Scotsman37 |
The last post was made 14 years, 43 days ago. Instead of replying here, would creating a new thread be more useful? |
