bike running hot
llewellyn
PostPosted: 10:15 - 31 Aug 2012    Post subject: bike running hot Reply with quote
RE: Srad 750v 1997
Hi guys.
Weather was hot today so I decided to take the bike out. I was at traffic lights, and the bike just cut out. I tried to re-start, the engine was turning over but not firing. I left the bike for about 15 mins and she started fine so I took her home. Once home, she cut out again. Same as before, tried a re-start but nothing, left the bike for 10 mins and bingo, started.
I just started the bike up again and she idled up to 107oc then the fan kicked in and brought her down to 100oc. But as soon as the fan stopped, she started climbing again to 107oc. Also she idles like shes missing. If I leave the bike cool to about 80oc, she starts. But anything over that and it's a no no.
Any ideas what the problem may be, or what I can do or what to look/check for?
Gutted I cant take her out in the nice weather Sad
Cheers.
Casper
PostPosted: 10:20 - 31 Aug 2012    Post subject: Reply with quote
Could be
Buggered thermostate.
Air block.
Low water.
Rad/expansion cap seal gone.
Fan temp/switch buggered.
Water pump on the way out.
bikenut
PostPosted: 10:21 - 31 Aug 2012    Post subject: overheat Reply with quote
Karma hi dude,
so, is thermostate working properly ( opening at what degrees )and good flow when open, any cold patches on rad when hot!
valve clearances where done when? and hows the fuel?
some pics would be good for the site....... Smile
Kradmelder
PostPosted: 10:21 - 31 Aug 2012    Post subject: Re: bike running hot Reply with quote
llewellyn wrote:
RE: Srad 750v 1997
Hi guys.
Cheers.
timing or fuel mixture? A faulty ECU can also cause cutting out and is often an intermittent problem.
2011 KTM 990 Dakar
2009 BMW 1200 GS
russell210276
PostPosted: 10:27 - 31 Aug 2012    Post subject: Reply with quote
valve clearances
but i would lean more towards a fault coil thats breaking down when hot then when it cools works again.
sickpup
Old Timer
PostPosted: 10:46 - 31 Aug 2012    Post subject: Reply with quote
russell210276 wrote:
valve clearances
Specifically inlet valve clearances are probably too tight.
llewellyn
PostPosted: 10:53 - 31 Aug 2012    Post subject: Reply with quote
1888 wrote:
Could be
Air block.
Low water.
wow that some list, will go through them 1 by 1 this afternoon and let you know what I find. Cheers
llewellyn
PostPosted: 11:02 - 31 Aug 2012    Post subject: Re: overheat Reply with quote
bikenut wrote:
Karma hi dude,
To be honest I don't know if the therm stat is working, any way to check? I'' check the rad for patches this afternoon and let you know how I get on. The fuel seems fine, and I havent got a clue when valve clearances were done. And here's the bike Wink
https://i1092.photobucket.com/albums/i408/dennisleej/1-2.jpg
llewellyn
PostPosted: 11:05 - 31 Aug 2012    Post subject: Re: bike running hot Reply with quote
Kradmelder wrote:
llewellyn wrote:
RE: Srad 750v 1997
Hi guys.
Cheers.
I'' check this out this afternoon and get back. Cheers
Casper
PostPosted: 11:07 - 31 Aug 2012    Post subject: Reply with quote
Worth doing the simple stuff fist mate as you could be spending cash on this that and the other only to find you had air in the system. Worth Draining the water and get fresh stuff if you dont know when last done. If you have the manual it should tell you how to test the thermostat. You stick it in a pan of water with a thermomoter and watch what temp it opens at. Your manual should tell you the right temp.
llewellyn
valve clearances
Stupid question I know, but how would I go about clearing the valves? Coil, would that be the ignition coil?
llewellyn
PostPosted: 11:08 - 31 Aug 2012    Post subject: Reply with quote
valve clearances
How would one go about loosening them?
llewellyn
PostPosted: 11:12 - 31 Aug 2012    Post subject: Reply with quote
Appreciate that thanks.
I have the manual, so I'll take a look. I'll also start draining the replacing the water and coolant and see how that goes. Not nice having the bike just sitting there in hot weather and cant ride Sad
mysterious_rider
PostPosted: 11:24 - 31 Aug 2012    Post subject: Reply with quote
On the subject, Anyone know what the average running temp is? And whats too hot?
Scotsman37
PostPosted: 12:19 - 31 Aug 2012    Post subject: Reply with quote
Double check your HT leads going into the spark plug caps just in case one of them have come lose or has corrossion at the end of the wire, as that would cause it to idle wildly with poor electrical connection to the firing of the plugs.
With having to leave the bike for a while before being able to restart it sounds almost like fuel starvation, and so do you have an inline fuel filter I would replace or it's the wrong size inline filter not allowing enough fuel to flow through.
Casper
PostPosted: 12:22 - 31 Aug 2012    Post subject: Reply with quote
Scotsman37 wrote:
With having to leave the bike for a while before being to restart sounds almost like fuel starvation, and so do you have an inline fuel valve filter I would replace or it's the wrong size inline filter not allowing enough fuel to flow through.
Thats a good shout. If it does it on the way home listen for hiss at the tank. Open cap and see if it starts. If it does then your tank vent is blocked or a problem with your vacume.
Vent first.
Kradmelder
PostPosted: 12:36 - 31 Aug 2012    Post subject: Reply with quote
Vent first.
ja good options. Fuel starvation is anything from too lean a mixture, which is worse as engine gets hot, to a fuel filter problem or a vacuum problem in the tank resricting flow.
2011 KTM 990 Dakar
2009 BMW 1200 GS
Shinigami
PostPosted: 12:02 - 01 Sep 2012    Post subject: Reply with quote
Completely off topic but love the autobot sticker
llewellyn
PostPosted: 12:18 - 01 Sep 2012    Post subject: Reply with quote
Hahaha I know, it was on the bike when I bought it. But afraid to peel is off just incase I peel the paint off in the process.
So I guess I'm stuck with a Transformer Wink
Shinigami
PostPosted: 15:10 - 01 Sep 2012    Post subject: Reply with quote
Why would you even consider removing it?! I'm gonna look where to get one for my next bike lol
Shinigami
PostPosted: 15:11 - 01 Sep 2012    Post subject: Reply with quote
llewellyn
PostPosted: 18:57 - 01 Sep 2012    Post subject: Reply with quote
Just drained the rad/coolant and flushed it out before re-filling 50/50. The bike stil idles hot, but I'm thinking that maybe that's normal for a 97?
Took her out for a spin and on the motorway she reached 81oc max with a low of 74oc. And she didn't seem to go over that. So maybe the mixture from the previous owner was too rich or not rich enough. I know for a 97 GSXR the running temp should be around the 90oc or maybe more on a hot day, so with a bad coolant mix this may have caused the problem. Thankfully she seems to be running ok for now. But when I got more time I will take her out for a propper run and see how she goes.
I cant check the plugs for the wild idling yet as the prev owner has rounded off the allankey bolt on the fuel tank (amongst others) so I cant lift it. When I got time I'll sort it out and get back.
Cheers for the help guys, I really do appreciate it. Top class forum. Think I'm gonna hang around for a while Wink
llewellyn
PostPosted: 21:44 - 01 Sep 2012    Post subject: Reply with quote
Vincent wrote:
Boats are "She"s, mass-produced bikes and motors are "It"s Wink
Fair enough, but I treat my bike like I treat my woman. Fill her up a couple of times a week, rub her down as often as possible, take care of niggling problems when they arise and she runs smooth, behaves as she should and gives me a 1st class ride in return. Now if that doesn't deserve the title ''She'', what does? Very Happy
The last post was made 14 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 131.88 Kb
