| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 16:54 - 02 Sep 2012 Post subject: Datatool System 21 not responding to fob! Yam FZ6.. SORTED! |
Go to get my bike out last night, all kitted up and ready to go. Press the button as I usually do to disarm the alarm, no response. Moved the fob closer, took the seat off and put it right next to the alarm and still nothing. It's not responding to anythng, tried the spare fob. Nothing.
It happened the other day when I went to wheel the bike in to the garage. I pressed the button on the fob to disable the motion sensor but the alarm didn't respond. Came back down the next morning to use the bike... it was fine. Went over and disarmed it like normal, have used in a fair few times since with no problems.
Has anyone had anything like this before?
Reading on the net would suggest the fuse is gone, but it can't be if it happened the other day and I've used the bike since.
So any thoughts would be useful! Rather steer away from 'rip it out they are shit' if we can void it. I know they are, the one on my last bike caused me problems as well. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| james1988 |
 james1988 World Chat Champion
| Casper |
 Casper World Chat Champion
| arry |
 arry Super Spammer
 Posted: 17:51 - 02 Sep 2012 Post subject: |
Unfortunately yes, it's a PITA
It's probably 'spiked' - here's how you go about unspiking it:
https://www.datatool.co.uk/pdfs/system3_ds.pdf
I spent a very unsavoury day stripping my old GPZ back because of a 'spike', which I've no idea what caused.
Datatool = fit for bin IMO  |
| Pete. |
 Pete. Super Spammer
 Posted: 18:13 - 02 Sep 2012 Post subject: |
Sorry to say, but that's exactly what mine did a couple of times just before it expired on me completely. I was stuck away from home and had to tear it off.
I did rip off all the potting from the circuit board and ran a soldering iron over it to sweat all the joints, and it started working, but then I put it back in the casing and fitted it to the bike again - when it promptly stopped working. In the end I got to the stage where it would arm and disarm if you bent the circuit board slightly over a biro or something so I called it a bad job and binned it. ____________________ a.k.a 'Geri'
| 0l0dom0l0 |
 Posted: 18:47 - 02 Sep 2012 Post subject: |
So me and my dad have had a play.
The bike is currently sitting with the ignition on and the alarm disarmed after it responded to disarming it (has responded a couple of times in an hour of pressing the fob lol) which I assume means the alarm can't be spiked?
I can't find the inline fuse though, isn't it meant to be easy to get to? Can someone point me as to where I am most likely to find it?
Also, is the antenna literally a wire? Or does it have a little thing on the end because I've found what looks like the receiver. It has two brown wires going to it though, and I thought that purple was the colour that datatool use. Will upload a pic soon, and its not the protective trigger switch before someone suggests that. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| 0l0dom0l0 |
 Posted: 19:28 - 02 Sep 2012 Post subject: |
https://photos-h.ak.fbcdn.net/hphotos-ak-ash4/255397_10151016994147167_1479551984_n.jpg
This is the thing I was on abouut... Anyone know what it is? ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
 Posted: 21:33 - 02 Sep 2012 Post subject: |
That's a magnetic reed switch to stop somebody removing the seat and tampering with the alarm. There will be another bit that looks almost identical but with no wire on your seat I assume. It will sit on top of that switch when the seat is placed back on the bike.
The alarm antenna is built-in usually. The fuse is usually a 15A push in type like this:
https://tinyurl.com/8fb9aem ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| 0l0dom0l0 |
 Posted: 12:22 - 03 Sep 2012 Post subject: |
Thanks, that makes sense. However there is no 'other bit' but its possible that didn't get installed or something. Looks like when the alarm arm, it looks for the other bit and if its not there it doesn't include it or something.
So am I write in thinking the antenna for the alarm is a purple wire?
Would it be worth me trying to find this to see if it is causing a problems? ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| P.addy |
 P.addy Red Rocket
| Islander |
 Islander World Chat Champion
| 0l0dom0l0 |
 Posted: 12:31 - 03 Sep 2012 Post subject: |
| ##Paddy## wrote: | This on your D6 by any chance?
Mine had a fairly similar issue which was down to the + connection which runs to live being a little bit damaged and had started going a weird green/white powdery type colour at the joint. |
Nah, I've sold that now .
This is on my FZ6, only got one bike now  ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| 0l0dom0l0 |
 Posted: 11:32 - 04 Sep 2012 Post subject: |
So I managed to get the alarm disarmed and the bike going, and it has been working ish over the last couple of days.
However still wasn't responding properly earlier though.
Is it likely that the circuit board is fried and if I change it for another one this would cure the problem?
Or is it worth still trying to trace the inline fuse and replacing that as a matter of course. I guess it could have come loose or something?
EDIT:
I also found out its a system 21 not a system 3 as the FZ6 already has an imob circuit. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| Islander |
| ZaphodBeeble |
 Posted: 14:55 - 04 Sep 2012 Post subject: |
As far as I'm aware all Fazers etc. have a couple of block connectors for alarm wiring under the seat. You'll be able to tell by the multitude of black wires going into the connectors. I think there's about 9 wires across two or three connector blocks. Two of them will be 12V (one switched and one permanent), two will be for the indicators (left and right) and at least one will be ground.
Also, I just realised that the alarm fuse is more than likely amongst your other fuses. It won't be in an in-line fuse holder. ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| 0l0dom0l0 |
| Islander |
 Posted: 21:17 - 05 Sep 2012 Post subject: |
Check your Datatool manual - it may be written in there. Failing that, trace the red wire from the alarm unit.  |
| sickpup |
 sickpup Old Timer
| 0l0dom0l0 |
 Posted: 08:53 - 06 Sep 2012 Post subject: |
As I've found this is a system 21 now, from research it doesn't actually have an immobiliser circuit I believe. So theoritcally I should still be able to start the bike with the alarm armed.
To avoid looking like a donkey, I can unplug the siren, that's fine... But the indicators will still flash. Does anyone know how to stop them flashing so I can at least use the bike for the time being?
If I unplug the jumper block on the board (the one to de spike) and let the internal battery dscharge will thiis do the trick? ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| ZaphodBeeble |
| 0l0dom0l0 |
 Posted: 09:31 - 06 Sep 2012 Post subject: |
I checked the manual, and there is no auxilary fuse or smilar lsted in the fuse box, but I will have a look anyway. I guuess that is the most likely place to find it, so thanks for that.
Did you read my last post about stopping the indcators flashing btw?
I've managed to source a brand new system 21 with 2 fobs (never used) for £35 so I wil change the board out and see if that cures it.
As its going to be my only form of transport its imperatiive it is reliable, which is why I bought the bike in the first place. Its also going to be parked not in the greatest of areas and that was one of the reasons I wanted one with an alarm, so knowing how to be able to still use the bike if the alarm causes me problems would be useful .
Thanks for the helpp so far btw. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| 0l0dom0l0 |
 Posted: 21:28 - 09 Sep 2012 Post subject: |
Just thought I would update this in case anyone ever had a similar problem.
I had another look today, with the siren removed (to stop the noise) and the bike would still start with no problems. As this is the system 21 it doesn't contain an immobiliser circuit like the system 3 as the imob system is a coded key and ecu on this bike.
It is indeed plug and play also.
The fuse was located in the right hand rear side panel as you suggested under 'back up'. I checked the installation certificate for the alarm and it told me where it was all along!
I then removed the circuit board completely and tried to start the bike and it starts with no problems at all, so if I ever have problems again I can still use the bike. I then replaced the circuit board with the one from the complete system I bought. Problem solved .
Well for now anyway, but it seems to be responding like it used to. I also engaged silent mode so I don't have to listen to the bloody thing beep every time I disarm the alarm which is good .
I've managed to set myself a PIN too. It was pretty easy to be fair ( the alarm can't be in silent mode to do this though, so maybe that was where you were going wrong pete?). I also practised disarming the bike with the PIN in-case for what ever reason I got stranded because the fob went flat etc.
All in all I'm happy with the result and hopefully it doesn't cause me any problems. If it does I'm less worried now though, so hopefully this information might be useful to someone else too. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| ZaphodBeeble |
 Posted: 13:11 - 10 Sep 2012 Post subject: |
Good to hear it's sorted.  ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
The last post was made 14 years, 51 days ago. Instead of replying here, would creating a new thread be more useful? |
