Front sprocket nut coming loose. Why?, How?, What's the fix?
map
Mr Calendar
PostPosted: 15:50 - 03 Sep 2012    Post subject: Front sprocket nut coming loose. Why?, How?, What's the fix? Reply with quote
Following on from this thread on the Hysung GT125 Comet.
The nut holding the front sprocket has come off again.
So not sure why this is happening, any plausible explanation welcome.
The nut was certainly tight (1 metre breaker bar).
Short of some threadlock loctite not sure how to prevent. More important to know why suddenly occurring (over-tight chain?)
Fisty
PostPosted: 16:02 - 03 Sep 2012    Post subject: Reply with quote
A new nut (they are a locknut IIRC and should really only be used once) or a tab washer if there is a groove on the shaft.
Pic of the nut and shaft please.
Fatter and faster than Fret
Suntan Sid
PostPosted: 16:42 - 03 Sep 2012    Post subject: Reply with quote
You'll have to use thread lock, if there is no lock washer.
It's a common problem on DRZ's, the recommended fix is the correct torque plus thread lock.
PostPosted: 18:08 - 03 Sep 2012    Post subject: Reply with quote
Put a flat washer under it.
The last post was made 14 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.39 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 45.57 Kb
