Thundercat New Front Pads Judder
MAR5H7
PostPosted: 18:56 - 03 Sep 2012    Post subject: Thundercat New Front Pads Judder Reply with quote
Hey there
Iv known for a while my front pads needed replacing, as there was little to no friction on the brake and the MOT inspector hinted towards them a few months back.
I also noticed a Juddering feel when I was using the front brake, the more I pulled the more noticeable it became. so I stopped using it until I got the new pads as I thought this would solve it.... I was wrong
I never had a problem when I first purchased the bike but then it just suddenly appeared around 2 months ago
With the new pads, they are sticking to the disc and pulling away is rather a chore on the bike, like it doesnt want to go but then budges through :/
As for the calipers, when removing the old pads, I noticed on each caliper, on one side, the pots were stuck, and to back this up, one of the old pads still had about 1/2 the graphite on it still
Anyone have any ideas/ solutions??? would really love my front brake back smooth and to not put more stress on the engine from pulling away at lights
Thanks
Ex: CBR 125 R 06', ZXR 400 96' (RIP), Bandit 650 06'
Owned: SRAD 600 97'
Current: YZF Thundercat 600 96'
Nick 50
PostPosted: 19:34 - 03 Sep 2012    Post subject: Reply with quote
If the pistons are stuck, clean them. If I were you I would strip the calipers, clean them, stick pads back in and then bleed the system.
Have you checked the brake discs? Wheel alignment? (not sure if this would cause the symptoms you mention) Front wheel bearings? Head Stock bearings?
How old are the tyres? Is one side more worn than the other?
MAR5H7
PostPosted: 19:42 - 03 Sep 2012    Post subject: Reply with quote
Thats what I feared I might need to do, but if its gotta b done, its gotta be done
Tyre condition - desperately need replacing, however its worn evenly, not more one side than the other
If it helps, one of the pot seals im pretty sure has perished, to back if up, while replacing the pads, I noticed fluid come onto my wheel during the process... it only happened once, maybe this could be the cause of uneven stopping???
Owned: SRAD 600 97'
janner_10
PostPosted: 19:50 - 03 Sep 2012    Post subject: Reply with quote
I rebuilt all my calipers on my last bike. Its not that bad of a job to do, a good mornings work but fairly straight forward.
I would purchase genuine Yamaha seals though if you go for it, a couple on here in the past have have problems with other makes. Also, find a small watch makers type screwdriver, makes a great tool for scraping away the crap behind where the seals sit.
Nick 50
PostPosted: 20:02 - 03 Sep 2012    Post subject: Reply with quote
Personally I see the front brake as the most critical mechanism on a bike. Your bike has something wrong which means it wont go, not a big deal. having something wrong which means it wont stop properly Shocked .......... that's how I look at it.
Stripping the calipers, cleaning the pistons, fitting new o-rings doesn't take that long like janner has stated.
Not only will you have much better brakes, but you will have the piece of mind knowing that you sorted it and they are spot on.
dangerousdave
PostPosted: 21:31 - 03 Sep 2012    Post subject: Reply with quote
i had something similar on my Thunderace - it turned out the front tyre was the culprit.
Although the tread was just about within its limits, the tyre was old and hadn't had the pressure checked regularly. This lead to the tyre developing subtle but visible bulges around the centre of the tread. When the brake was whacked on hard it vibrated like hell !
I'd even bought a set of disks to go on the front as I was convinced the disk was warped, but as soon as the tyre was changed the problem vanished.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
MAR5H7
PostPosted: 20:41 - 04 Sep 2012    Post subject: Reply with quote
Nick 50 wrote:
Personally I see the front brake as the most critical mechanism on a bike. Your bike has something wrong which means it wont go, not a big deal. having something wrong which means it wont stop properly.
I know this is a big problem, dont get me wrong, but i dont ride erratically and always leave plenty of time to stop, if need me I can use the brake and it will work
as for it not going, the bike itself is fine, its when I pull the front brake to stop at lights, the pads get stuck to the discs and the bike is struggling to go, but after a second the pads are forced back and it runs fine until the next time I touch the front brake :/
I do want to sort them, but Im no expert at calipers. I know how to pop the pots out and that is it lol :S
Owned: SRAD 600 97'
el_oso
PostPosted: 21:03 - 04 Sep 2012    Post subject: Reply with quote
popping the sticky pistons on them blue spot calipers is a bitch!
There really isn't many/any complicated parts to the part of the brakes. It's just the hassle more than anything. If you have patience, it is easy as pie.
pop the piston out > remove seals and replace as necessary > clean the groove where the seal sits with a poking/scraping device > put new seals back in > out the piston back in;
like everyone else has mentioned fairly easy. Just takes a bit of time
The real pain with these brake is the bleeding of an empty system. I had to use a syringe to push the fluid back through the system to get a good hard lever
Duke 390
Car: Jeep Wrangler 4.0L
The last post was made 14 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.66 - MySQL Queries: 13 - Page Size: 64.6 Kb
