Engine ticking / clicking
MissBex
PostPosted: 10:54 - 03 Sep 2012    Post subject: Engine ticking / clicking Reply with quote
Heya all,
Was warming up my Bandit 600 yesterday before going out and as I was kneeling beside the engine checking over the bike, I noticed a noise I havn't noticed before.
There is a fast Clicking / Ticking noise coming from the front of the engine.
I tried the screwdriver to engine technique but cant seem to pinpoint a place where I can hear it the most.
It doesn't go away with clutch pulled in.
Is it something I should worry about?
Direct Access Passed - 30/05/14
00' Honda Hornet 600
MissBex
PostPosted: 12:19 - 03 Sep 2012    Post subject: Reply with quote
Video
https://www.youtube.com/watch?v=qb9LQGytSi0&feature=youtu.be
mysterious_rider
PostPosted: 12:27 - 03 Sep 2012    Post subject: Reply with quote
Most likely exhaust gasket leaking slightly. Mine does this.
bikenut
PostPosted: 13:12 - 03 Sep 2012    Post subject: noise Reply with quote
:karma: hi dude,
any popin or bangin on the overun, even slightly??
UrbanRacer
PostPosted: 13:23 - 03 Sep 2012    Post subject: Reply with quote
You need to find out if the bike has an automatic cam chain tensioner, that can cause some ticking just before it adjusts.
MissBex
PostPosted: 21:51 - 03 Sep 2012    Post subject: Reply with quote
Heya thanks for the replies.
I'm not sure to be honest about whether it has a automatic cam chain tensioner...
I haven't noticed any popping or banging.
I've also found out that letting the bike warm right up and the clicking seems to go.
Bezzer
PostPosted: 22:30 - 03 Sep 2012    Post subject: Reply with quote
Bandit camchains and tensioner blades last for ages, they're not a weak spot. They do have an automatic tensioner that can stick or have the spring weaken, it's awkward to get at low down in the rear centre of the cylinders but it is possible to do without stripping things off. Remove it as per the manual so you keep the right tension to see if it's free etc . Doesn't particularly sound like a camchain or tensioner problem it make it sound a lot more rattly with the speaker being so close.
Ticking is usually a loose exhaust collar as mentioned, check them before you mess with anything else as it's the easiest.
MissBex
PostPosted: 23:40 - 03 Sep 2012    Post subject: Reply with quote
unitynotsocrippledatmo wrote:
from the sound of it i think it needs another camchain or at least a tensioner blade to reduce the noise.Its worth doing the whole head if its got a high mileage,shims, de coke, valve guides,
wether the tensioner i automatic or not sounds a little irrelevant.automatic tensioners have a history of sticking.
It's got 15,000 miles. The only info I know about what it's had done was the guy I got it from said it's had new needle valve and seals on all 4 carbs.
I'm not at all mechanically minded so all what you mentioned doesn't make much sense to me, but sounds like it could costly.
I might take it down to the local bike garage tommorrow and ask them what they think about it, been trying to gather some info from researching online and asking on here so I can see if they say the same things.
Casper
PostPosted: 23:43 - 03 Sep 2012    Post subject: Reply with quote
This^^^ is first thing to check. See if you can tighten the exhaust nuts a 1/2 turn as they can come lose. Its the cheapest fix to try before spunking good money on can chains. New gaskets are a couple of quid on eBay. Look at pot number 3 spark plug. The cap looks slightly lose. You spark may be jumping about. Doubt it but might be worth a look.
Spudda
FWIW .... I had a Yamaha Thundercat (RIP 2004) which had an 'engine noise'. Turned out to be pinholes in my down pipes which disappeared after I had them welded in
I'm guessing theres no fairing on your bandit, might be worth a look even if its to cross it of the list of possible causes
It's Nice To Be Important BUT Its Important To Be Nice ©
www.tankslap.co.uk
Triumph Daytona 650 Union Jack Nose Cone.Metzeler M5's.Carbon Bling.ASV Levers.LED Adapted Rear.LED Adapted Indicators.RIM Tape.PiperCross Filter. Smoked Aero Screen.Harris Hanger.Carbon Wrap.Renthal Sprockets.Coded Chain Guard.Shortened Carbon Can
MissBex
PostPosted: 23:47 - 03 Sep 2012    Post subject: Reply with quote
Yea there's no fairing, just naked Bandit.
I'll check the pipes etc... see if I can see anything not right.
Thanks
The last post was made 14 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 72.89 Kb
