Apart from turning over your bike well...
killa
Won't Shut Up
PostPosted: 10:21 - 04 Sep 2012    Post subject: Apart from turning over your bike well... Reply with quote
What positive effects does a fresh, strong battery have on your bike's running condition?
Bezzer
PostPosted: 10:46 - 04 Sep 2012    Post subject: Reply with quote
Apart from starting, a good battery gives decent back up for every other electrical system in use especially when you're not using the bike enough to put a full charge back into it, just tootling about/commuting etc. That said even the best battery can only cope so much before it needs properly topping back up by bike or charger.
Matt-
PostPosted: 11:04 - 04 Sep 2012    Post subject: Reply with quote
Bezzer has hit the nail on the head.
If you ever notice your battery to be getting weaker, sign's of bad starting and turning over, don't be afraid to just put it on charge, some mechanics say it's best to completely flatten a battery then for a full re charge is the best.
Hope this helps
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
Bezzer
PostPosted: 12:02 - 04 Sep 2012    Post subject: Reply with quote
Matty King wrote:
[ some mechanics say it's best to completely flatten a battery then for a full re charge is the best.
That's wrong and a quick easy way to knacker your battery. Lead acid batteries don't have a "memory" like Ni Cads and don't need fully discharging, they are not built to withstand deep discharging and recharging and work better when kept as fully charged as possible which helps keep sulphation and plate bucklng at bay. You need leisure type batteries they use in caravans/boats etc for that which have stronger plates to withstand it.
Islander
PostPosted: 12:05 - 04 Sep 2012    Post subject: Reply with quote
Hope this helps
That's a good way to permanently damage a lead/acid or gel battery. That advice has only ever really applied to Ni-Cad cells.
Never let your battery fully discharge - recharge it as soon as the starter becomes sluggish.
cb1rocket
PostPosted: 13:11 - 04 Sep 2012    Post subject: Reply with quote
flatten your battery? That the way garages can rip you off for a new battery. Typical
And yes applies to Ni-Cd cells
nowhere.elysium
The Pork Lord
PostPosted: 13:28 - 04 Sep 2012    Post subject: Reply with quote
Um, diminished load on the charging circuit, on FI bikes there's a lower chance of getting any kind of complaints from the bike itself*, and you'll also get marginally brighter lights.
I'd disregard Matty King's contribution as the regurgitated crap that it clearly is.
*On CBF125s, I've noticed that a low battery makes it bunnyhop like a total sod. Not been silly enough to test it one the SV.
promufa
PostPosted: 13:33 - 04 Sep 2012    Post subject: Reply with quote
There are generaly 2 types of batteries: Deep-cycling and low cycling batteries.
Deep-cycling batteries are the type you have in a cordless phone, RC car, mobile phone etc. They are mostly Ni-MH, Ni-Cd, Li-ion and Li-polymer. These batteries are designed to give out low current over extended time periods. Complete discharging is recommended for Ni-Mh and Ni-Cd and it does not hurt Lithium batteries.
The type of batteries used in bikes/cars/boats etc are low cycling. These batteries are designed to give out lots of power in very short time (when you hit the starter button). The amount of amps the battery can deliver in 30 seconds at -18oC is the CCA number that is printed on it. All of these batteries are Pb-acid chemistry, AGM etc are just a modification of the traditional Pb-acid. These batteries do not cope with deep-cycling. Everytime you discharge a Pb-acid battery it loses about 25% of its max capacity (ie knackered). They are meant to be kept at no lower than 75% charge IIRC or lumps of sulphate salt start forming on the lead plates that cannot be dissolved again (the cause of reduced capacity).
TL;DR
lead-acid: keep topped up at all times
Ni-MH, Ni-Cd: Discharge completely before recharging
Li-Ion, Li-polymer: Can be completely discharged w/o problems
'02 Triumph Speed Four
neatbik
PostPosted: 13:46 - 04 Sep 2012    Post subject: Reply with quote
This.
killa
Won't Shut Up
PostPosted: 15:46 - 04 Sep 2012    Post subject: Reply with quote
Thanks guys.
I’ve replaced a rather dead battery in the TLR and since putting that in, she’s been purring away quite happily. I noticed a difference in all round performance and just wanted to know a bit more about weak or dead batteries. Thumbs Up
Walloper
PostPosted: 16:01 - 04 Sep 2012    Post subject: Reply with quote
That's why 'some mechanics' will always only ever be mechanics. Laughing
The last post was made 14 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 76.5 Kb
