Wheel Bearings on the way out?
Wise1
PostPosted: 18:22 - 04 Sep 2012    Post subject: Wheel Bearings on the way out? Reply with quote
Was coming home from work tonight on the 1250, felt as if I had a flat tyre at points, bit wobbly at the front end. Type pressure is fine and wheel seems fine when I put in the centre stand to check for movement.
Sign of the wheel bearings heading out?
Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
Previous - GSXR750 SRAD, Fireblade, ZXR750, CBR600
Matt-
PostPosted: 18:36 - 04 Sep 2012    Post subject: Reply with quote
When you checked the wheel bearing, did you spin the wheel, and listen for any judders or any ruff spot's, also try and feel any play from side to side or down and up. may be a worn tyre ?
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
Wise1
PostPosted: 19:45 - 04 Sep 2012    Post subject: Reply with quote
Can't feel anything rough when it's spinning, does not seem to be any movement or hear anything, well I can but it's the pads against the disc, the pads are about 3/4 through, wonder if brakes could be binding.
I will order new pads and bearings just to be on the safe side.
el_oso
PostPosted: 20:05 - 04 Sep 2012    Post subject: Reply with quote
have you checked the head race bearings are done up?
Duke 390
Car: Jeep Wrangler 4.0L
Wise1
PostPosted: 20:10 - 04 Sep 2012    Post subject: Reply with quote
Yeah, checked them, definately coming from low down though. I remember I had issues with the head bearings on a bike before and this is not what I am feeling this time.
Wise1
PostPosted: 18:05 - 05 Sep 2012    Post subject: Reply with quote
Decided to take the wheel off and have a proper look. The bearings are spotless, the dust covers don't even have a scratch on them. No rough bits , smooth as I would expect to be honest.
The pads are a different story, about a year old, rusted to f**k, not cheap ones either. One of the pads on the left caliper required a lot of effort to remove, it was like it was glued in position, only to the caliper body though not the pistons.
I pushed the pistons back to make room for new pads and they appeared free and clean too.
The last post was made 14 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 53.19 Kb
