Linux sound issues and xp graphic stability issues
c_dug
PostPosted: 16:11 - 06 Sep 2012    Post subject: Linux sound issues and xp graphic stability issues Reply with quote
Hi guys,
I'm using an old desktop PC at the moment and I'm struggling to get it to play videos. It has 3 OS' installed, XP Professional, Linux Mint, and the latest Ubuntu.
When running XP I'm having issues with it playing video smoothly, the CPU doesn't seem able to hack it, even when running relatively low quality videos the CPU is up at 100% and it is jumpy to the point of un-watchable. This is using VLC, I haven't tried other media players.
When running Linux with the same video the picture is perfect and sharp, however I don't have any sound. It recognises the sound card fine, and in fact I'm sure to start with it was playing sound ok, I have no idea what I've changed but now I have no sound at all. I've checked all of the obvious stuff including checking for missing drivers. The picture is sharp in VLC and Banshee.
I haven't tried ubuntu with the video yet but I'll give that a go now, it didn't run very well when I downloaded it so I've pretty much ignored it is on here.
The film in question is in AVI format if it makes any difference
UnknownStuntm...
PostPosted: 16:19 - 06 Sep 2012    Post subject: Reply with quote
Linux sound issue: fire up a terminal and type alsamixer - then play with the settings. Google can tell you more about alsamixer but as a starter I would look at whether the selected sound card (press F6) has the oudio outputs turned up.
c_dug
PostPosted: 16:28 - 06 Sep 2012    Post subject: Reply with quote
Yep soundblaster card is selected, all up to max, still nothing.
c_dug
PostPosted: 16:33 - 06 Sep 2012    Post subject: Reply with quote
Tried the front headphone port and all channels of the surround sound card with no luck. Fairly sure it's not a hardware issue because it works fine on xp but could it help to shift the card over a slot in the motherboard? I'm guessing no since it seems to pick up the card fine.
c_dug
PostPosted: 16:38 - 06 Sep 2012    Post subject: Reply with quote
Ok, gone into PulseAudio Volume Control on the Media menu, when fiddling with the settings I get the pop sound to show how loud it is set. No other sign of sound though.
UnknownStuntm...
PostPosted: 16:41 - 06 Sep 2012    Post subject: Reply with quote
alsamixer again (it really is the best way to sort this!)
F5 shows all available controls for the selected device. Move sideways with the arrow keys, bear in mind there may be more controls than you can see on the screen... In most of my experience it will be that a slider is slid down, muted or simply not selected. Smile
Also look here: https://linux.die.net/man/1/alsamixer
c_dug
PostPosted: 16:54 - 06 Sep 2012    Post subject: Reply with quote
https://i235.photobucket.com/albums/ee81/paddy2007dug/alsamixer.png
Definitely all up all of the way along, I do notice on the far right of the screenshot that there is nothing shown in the video bar, make a difference?
UnknownStuntm...
PostPosted: 17:25 - 06 Sep 2012    Post subject: Reply with quote
Hmm.
This help?
https://forums.linuxmint.com/viewtopic.php?f=49&t=31224
Or... https://wiki.ubuntu.com/DebuggingSoundProblems
Jamie.
PostPosted: 18:59 - 06 Sep 2012    Post subject: Reply with quote
Have you tried playing the video with another player in linux? VLC would be a good start.
c_dug
PostPosted: 19:51 - 06 Sep 2012    Post subject: Reply with quote
Yep tried Banshee and VLC, no luck.
Used aplay -l and got the following:
**** List of PLAYBACK Hardware Devices ****
card 0: ICH5 [Intel ICH5], device 0: Intel ICH [Intel ICH5]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: ICH5 [Intel ICH5], device 4: Intel ICH - IEC958 [Intel ICH5 - IEC958]
Subdevices: 1/1
card 1: Live [Dell Sound Blaster Live!], device 0: emu10k1x [EMU10K1X Front]
Subdevices: 1/1
card 1: Live [Dell Sound Blaster Live!], device 1: emu10k1x [EMU10K1X Rear]
Subdevices: 1/1
card 1: Live [Dell Sound Blaster Live!], device 2: emu10k1x [EMU10K1X Center/LFE]
Subdevices: 1/1
How do I disable the intel device?
neil.
PostPosted: 21:19 - 06 Sep 2012    Post subject: Reply with quote
In the BIOS is there an option to disable the 'on board' or 'built in' audio?
Going
PostPosted: 01:54 - 07 Sep 2012    Post subject: Reply with quote
Try changing the sound profile, under sound settings.
This is usually the issue with mine.
neil.
PostPosted: 06:38 - 07 Sep 2012    Post subject: Reply with quote
In Ubuntu there is the Sound Settings dialog (click the speaker volume icon in the top right to get to it):
https://www.bikechatforums.com/download.php?id=85667
Select the sound output there.
c_dug
PostPosted: 10:42 - 07 Sep 2012    Post subject: Reply with quote
Got it, thanks guys.
Frost
PostPosted: 18:04 - 07 Sep 2012    Post subject: Reply with quote
It now works?
If not boot it from a pen drive containing the latest version. If sound then works just do a clean install.
neil.
PostPosted: 18:20 - 07 Sep 2012    Post subject: Reply with quote
How did you fix it?
el_oso
PostPosted: 09:24 - 08 Sep 2012    Post subject: Reply with quote
neil. wrote:
How did you fix it?
what you said......tried to guide him over the phone
Duke 390
Car: Jeep Wrangler 4.0L
The last post was made 13 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 93.61 Kb
