| binge |
 binge Emo Kiddy
 Posted: 16:30 - 08 Sep 2012 Post subject: Small lightweight alternative to an acid motorbike battery? |
I'm having voltage regulation issues with the Chaly.
With the small Reg/Rec fitted, it will run fine, but once I put my lights on, the horn worn work properly unless I rev the engine.
With the big Reg/Rec fitted, it over charges and pops bulbs.
So either way, I NEED a battery.
Now I'm trying to work out the best solution.
Could I:
a) Run the small reg/rec, with a 12v lithium battery pack?
This will provide the umph to use the horn etc at tick over, but will also charge properly when I'm riding along, with higher revs etc.
b) Run the bigger rec/rec, and wire a battery eliminator in, instead of the battery, to soak up the excess charge.
Which of the above (If any) are possible?
Will a Li battery work? Or will it just blow up under the alternator charge of 13.5v?
Any help MUCH appreciated.
Ben |
| Pete. |
 Pete. Super Spammer
 Posted: 16:39 - 08 Sep 2012 Post subject: |
Fire panel battery. I have a tiny 12v one here but I have no idea what condition it's in. I'll put it on charge for a while and if it picks up you can have it. ____________________ a.k.a 'Geri'
| promufa |
 promufa Scooby Slapper
| binge |
 binge Emo Kiddy
| Robby |
 Robby Dirty Old Man
| promufa |
 Posted: 17:11 - 08 Sep 2012 Post subject: |
Yeah, I ve been reading the chaly project thread. I think I sent you a link on there for some lithium batteries. They are a lot smaller than the standard lead-acid. Think they have the dimensions on the ebay ad. Have a look if they would fit would be
Or as said, a large capacitor should work as well.. you only need the battery to smoothen out the reg/rec output as you ll be using the kick start. You could maybe even cook a capacitor with a decent voltage regulating transistor-type thingy to kep it steady at 13.2V or so ____________________ '02 Triumph Speed Four |
| binge |
 binge Emo Kiddy
 Posted: 17:16 - 08 Sep 2012 Post subject: |
The original reg/rec (Small one) NEEDS a battery, as the lights are all too dim. At tickover there is only 11v coming out of it.
But as soon as I blip the throttle, it goes up to a steady 13 or so.
But obviously at traffic lights, or low RPM, with the headlight on, nothing else works.
So I need something to just assist it at low RPM.
OR
With the bigger reg/rec, as you say, a capacitor/eliminator, to buffer the charging voltage.
It cooked all my bulbs, and the body of the reg/rec started to smell a bit.  |
| promufa |
 Posted: 17:18 - 08 Sep 2012 Post subject: |
Found the ebay thing it's a small four-cell Li battery Clicky ____________________ '02 Triumph Speed Four |
| binge |
 binge Emo Kiddy
| stinkwheel |
 Posted: 19:05 - 08 Sep 2012 Post subject: |
Please consider what happens if you overcharge a lithium battery and DO NOT fit one to your motorcycle because they are fucking dangerous at the best of times.
There are better examples but I chose THIS ONE because they used a fairly small current to achieve the effect.
How many charging phases do you have?
If it's three, Use two of them through your small reg/rec to run the flashers, brake light and horn. Use the third through a 12v AC regulator for direct lighting. They do 12v AC regulators for enfield bullets and vespas. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| binge |
 binge Emo Kiddy
| stinkwheel |
 Posted: 19:41 - 08 Sep 2012 Post subject: |
A small lead-acid burglar alarm battery or one out of an emergency lighting unit might help.
12v AC direct lighting is unusual but not unheard of. As far as I know the Japanese never got the hang of it. Works really well on my Enfield. I have a standard H4 bulb in it.
You need more than one phase though.
EDIT: If you have a seperate phase, you just wire the AC phase into the input for the headlight switch with the regulator connected into the circuit somewhere. It can only come on when the engine is running anyway.
Your system sounds odd and you couldn't do it with a single phase.
The way the Japs do it from a single coil is to split the lighting coil output so the entire coil is charging the battery when the lights are off but when they're on, half charges the battery and half runs the lights. This necessitates a slightly more complex light switch because the charging system passes through it too.
They also tried to go too simple and not use a regulator. This means you have to carefully balance the wattage of the various bulbs or they either pop or fail to light fully. It's why all those 6v bikes with direct lighting are useless in the dark.
Not hard to get your head round the AC/DC thing though. ALL the output is AC anyway, your rectifier just dumps the backwards half of it to earth before it gets to the battery. That's why they use the AC because you get more useable amps from a weedy generator. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 22:55 - 08 Sep 2012 Post subject: |
Couldn't you just put a capacitor in there? I had one on my KTM400 to replace the battery. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Pete. |
 Pete. Super Spammer
| N cee thirty |
 N cee thirty Banned
| sickpup |
 sickpup Old Timer
| promufa |
| stinkwheel |
| sickpup |
 sickpup Old Timer
| stinkwheel |
 Posted: 16:31 - 09 Sep 2012 Post subject: |
It should be noted that glass mat absorbtion batteries are pretty much the pinnacle of current motorcycle battery technology. It's still a lead/acid battery but not as we know it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| promufa |
 Posted: 20:22 - 09 Sep 2012 Post subject: |
| stinkwheel wrote: | | promufa wrote: |
I dont think I have ever seen a bike charging system work at >14.4V. Normally if it is more than that it is a reason to suspect busted reg. |
| sickup wrote: | They'll spike to 15 or 16v quite happily when you switch lights off and suchlike. Takes a while for the zennor in the regulator to saturate and desaturate.
People never see this because they use digital multimeters, which by necessity have a degree of lag or you'd never get a stable display. Look at one with an analogue meter and you get a whole different picture.
| promufa wrote: |
Look harder with the correct tools, as Stinkwheel says try an analogue meter for starts.
On a perfectly working reg/rec I would expect transients of 14.4-14.8volts and spikes of over 15V. One of the reasons lead acid batteries are still in use when battery technology has moved on so far is that they can handle transients and spikes.
When it comes to a LiPo battery sitting a couple of inches beneath my testicles I quite simply wouldn't take the risk. |
Fair enough. I haven't used an analogue multimeter for years so I am inclined to think you are right about the spikes. Just didnt think a milisecond spike would be enough to fry a battery. Good to know, since I was thinking of getting one as well but I have become quite attached to my balls over the years so I ll pass. ____________________ '02 Triumph Speed Four |
| sickpup |
 sickpup Old Timer
| mudcow007 |
 mudcow007 World Chat Champion
 Posted: 13:06 - 13 Sep 2012 Post subject: |
I fly RC planes an know only too well what a lipo fire looks like
Clicky
be careful out there kids |
The last post was made 14 years, 36 days ago. Instead of replying here, would creating a new thread be more useful? |
