Kinked link in chain
Mrjoolz
PostPosted: 07:15 - 09 Sep 2012    Post subject: Kinked link in chain Reply with quote
I've done about 14k on my DID chain and sprockets and upon adjusting it yesterday noticed a slight kink in chain
Can this link be removed? I am halfway through adjustment on my zzr600 so moving wheel forward again should give enough slack for link to be removed, but just wondered if this is advisable.
Want to try and sort it before BBQ
Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
Current Bike: Suzuki GSX1300R Hyabusa.....
PostPosted: 07:38 - 09 Sep 2012    Post subject: Reply with quote
Sounds like it's rusted inside. Short of boiling it in linklife there's not much hope of getting any lube in there. I had a chain snap a couple of weeks ago on my Bandit. It was 3/4 way through it's adjustment and 12k miles on it. Looked healthy enough and kept well-lubed but when it snapped the pin was rusty inside the link.
Richy CB1000
PostPosted: 08:52 - 09 Sep 2012    Post subject: Reply with quote
Don't forget it could be at the end of it's stretch limit and need changing, regardless of whether you have any adjustment left.
O/X ring type are "stretched" after 2% or something can't remember of the top of my head.
Mrjoolz
PostPosted: 13:12 - 09 Sep 2012    Post subject: Reply with quote
What I have done, is use brake cleaner on stiff links and scrub with toothbrush to get grit off. Used some penetrating oil into links and using long nose pliers slowly worked each stiff link by lightly twisting with pliers.
Then applied oil to lube chain. The links seem a little less stiff now, but may mean new chain but hoping to get little longer on it now.
Islander
PostPosted: 13:15 - 09 Sep 2012    Post subject: Reply with quote
Personally, I wouldn't risk it. Chains aren't that expensive in the scheme of things and a snapped chain can be disastrous. You've no idea what the internal condition of that link is really.
janner_10
PostPosted: 19:18 - 09 Sep 2012    Post subject: Reply with quote
Wouldn't risk it mate, just get a new set on there.
Acemastr
PostPosted: 20:29 - 09 Sep 2012    Post subject: Reply with quote
liberal coating in WD, give it a good work over by moving it, then rub it down and put extra lube on
2016 Toyota Tacoma Limited
moonzoomer
PostPosted: 21:15 - 09 Sep 2012    Post subject: Reply with quote
14k miles, the chain and sprockets owes you nothing, replace both sprockets and chain at the same time. Hardly worth injury or damage to your bike IF the chain breaks so dont even think about any kind of repair cos your bike and your body tend to be worth a lot more than a chain and sprocket kit.
V2
PostPosted: 21:33 - 09 Sep 2012    Post subject: Reply with quote
I had a cheapo chain snap on my old VFR400, it took a chunk out of the side engine casing and bent the gearbox output shaft, take it from someone who learned the hard way Laughing
CaNsA
PostPosted: 23:10 - 09 Sep 2012    Post subject: Reply with quote
stop being a pikey and get a new C&S set joolz!
It will stop you from thinking "what if"
my mates chain snapped @ 120 a few years back, fubar'd the waterpump and pump drive shaft along with cracking the swing arm.
Click for bigger pic.
https://i.imgur.com/LMNqyl.jpg
PostPosted: 07:21 - 10 Sep 2012    Post subject: Reply with quote
WD40 is the last thing you should put onto a chain. It will wash away any existing lube and grease which is supposed to be held inside the link by the O ring or X ring.
Just lube/wax it and get it changed at the next opportunity.
PostPosted: 10:01 - 10 Sep 2012    Post subject: Reply with quote
Vincent wrote:
Where is this "scheme of things"? Confused With the current "Scheme" I'm on, my last chain cost me nearly a hundred knicker. I want to change schemes Idea
He means that buying a new chain is cheaper than replacing the engine cases/swinging arm/your toes when the chain breaks.
The last post was made 14 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 77.1 Kb
