Removing stuck oil filter
AcIdBuRnZ
PostPosted: 02:52 - 23 Oct 2004    Post subject: Removing stuck oil filter Reply with quote
As title.
Got any tips anyone?
I drained the oil and spent hours trying to get the fecker off, but it won't budge. In the end I had to give up and fill up with new oil as I needed the bike for transport the next morning.
My Dad suggested hammering a screwdriver through it and turning it that way - but he said sometimes that may not work and you're left with it stuck.
Help!
Mark
Hex
Party Boy
PostPosted: 03:20 - 23 Oct 2004    Post subject: Re: Removing stuck oil filter Reply with quote
If I ever have a stuck one thats the way I do it... car or bike.
Makes abit of a mess as the oil leaks out but it will get it moving and as such you can remove and replace it.
hex
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
Scooby
Scrappy Doo
PostPosted: 03:49 - 23 Oct 2004    Post subject: Reply with quote
What Hex said. Just make sure you don't damage the thread the filters attached to.
sickpup
Old Timer
PostPosted: 06:25 - 23 Oct 2004    Post subject: Reply with quote
As the chaps above suggest but it might be worth trying a 'boa-constrictor' first. I think B&Q sell them.
PostPosted: 11:04 - 23 Oct 2004    Post subject: Reply with quote
I tend to use a chain wrench to remove oil filters. They are more likely to stick if you do not oil the rubber O ring before fitting the filter.
stryker
PostPosted: 11:20 - 23 Oct 2004    Post subject: Reply with quote
I think the process of hammering a screw driver through the filter probably loosens the thread anyway, hence why it usually works.
Now what?
Guest
PostPosted: 11:24 - 23 Oct 2004    Post subject: Reply with quote
And then go and buy one of these ............
https://www.bikers-cafe.co.uk/acatalog/ofw.jpg
Robby
Dirty Old Man
PostPosted: 15:36 - 23 Oct 2004    Post subject: Reply with quote
I use a chain wrench. Only difficult oil filter I ever came across was the one on my BMW, and this one got it off.
Also have a strap type one, which has the advantage in that it can exert a lot more force than the chain wrench without splitting it, but you need to be using it on a clean surface - if you have punctured the surface with a chain wrench then the strap will just slip.
AcIdBuRnZ
PostPosted: 12:58 - 24 Oct 2004    Post subject: Reply with quote
Thanks for the suggestions guys Thumbs Up
I've actually been using one of the chain type tools, but it won't budge it.
/me goes off in search of a big screwdriver and hammer.
Mark
jay12329
Dr. Evil
PostPosted: 13:04 - 24 Oct 2004    Post subject: Reply with quote
I used a rubber mallet and a screwdriver just hit it softly a few times and it made progress but it wont damage the thread it if comes into contack with it.
J
TiN
Pocket Tin
PostPosted: 13:44 - 24 Oct 2004    Post subject: Reply with quote
Hmm, I just spent the past 3 days tackling the same problem... Rolling Eyes Embarassed
I tried the screwdriver method - didn't work. I also invested in 3 different tools - one of those boa-constrictor things (I already had one lying around, and have used it before for the same purpose), a universal filter wrench, and a filter "key" that matched the filter. None of those methods worked, so in the end, I just used a channellock (one of these https://ts.smoothcorp.com/cornerhardware/125028.299x299.jpeg ) and a bit of brute force.
TiN
dotgems.net
WildGoose
White Van Man
PostPosted: 13:56 - 24 Oct 2004    Post subject: Reply with quote
chain wrenches are good for undoing, cos if it wont move, then the chain just munches into the filter and grips it that way
tightening with a chain wrench is slightly more dodgy cos of this, but if it starts to munch the filter, then its tight enough Razz
PostPosted: 16:12 - 24 Oct 2004    Post subject: Reply with quote
Errr...Tightening your oil filter using a wrench! Shocked Shocked
Finger-tight is perfectly sufficient.
WildGoose
White Van Man
PostPosted: 18:22 - 24 Oct 2004    Post subject: Reply with quote
hello, my name is goose, and i'm a torque-aholic Razz
clemsta
PostPosted: 18:44 - 24 Oct 2004    Post subject: Reply with quote
Get a big set of plumbers grips, squeeze the filter until it caves in a little then try to turn it, if it's still to tight then try to tighten it then slacken it repeatedly, it should come off with a bit of brute force.
Hope this helps
Adam
SOMEONE CALL THE DOCTOR! I've got 2 stroke fever!!!
OGRI - Stuff everything, i've always got my bike!
DAS Passed - 7/6/06
PostPosted: 23:05 - 24 Oct 2004    Post subject: Reply with quote
Just make very certain taht you oil the rubber O ring first.
Ade067
PostPosted: 23:27 - 24 Oct 2004    Post subject: Reply with quote
The problem with the hammer and screwdriver method is other than making a bloody mess if the filter is very tight the screwdriver will just rip the filter apart when you try to undo it.
Like others have suggested I always use the large adjustable plumbers type grips,I think thier proper name is waterpump pliers,I've never known a filter yet to argue with those things and thats including the really large oil filters on trucks which can be mega tight!
This is what I mean...
https://www.tool-up.co.uk/tooldev/images/items/22187.jpg
AcIdBuRnZ
PostPosted: 03:46 - 26 Oct 2004    Post subject: Reply with quote
Cool Thumbs Up
I'll need to invest in a set of those (and pray for dry weather again Praying )
Mark
The last post was made 21 years, 353 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.39 - MySQL Queries: 13 - Page Size: 102.24 Kb
