zxr 750 removing seized pistons from caliper
royzxr750
PostPosted: 20:17 - 11 Sep 2012    Post subject: zxr 750 removing seized pistons from caliper Reply with quote
Hi guys iv just taken off my breaks on my zxr 750 to rebuild them as the brakes are crap. well tbh just dont work.Anyways i have split them in half and i can see they been seized and pushed right in for sometime. What i would like to know is wots the best way to get them out or will i be looking at new brakes?
0ddball
PostPosted: 08:23 - 12 Sep 2012    Post subject: Reply with quote
Piston pliers might work depending on which pistons you have. Some have the pistons with the removable rubber insert, others have the bonded in cork ones.
Best way is find someone with a compressor and a blow gun (or buy one for about £4 from machine mart). Bolt the halves back together and give them 120psi down the fluid hole with a bit of wood between the pistons. When they are all popped out and touching the wood remove the wood and let them come out more till they are touching each other before separating the halves again.
ZXR750L
Matt-
PostPosted: 08:26 - 12 Sep 2012    Post subject: Reply with quote
Piston Pliers if possible.
Get them moving, Spray some lubrication in their WD40, then pound some air, go to your local garage and ask if you can borrow their Air line.
Make sure you clean the Pot's up after you have them out Thumbs Up
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
Mungel
PostPosted: 12:10 - 12 Sep 2012    Post subject: Reply with quote
I learnt this the hard way, like yourself. You need to free the pistons up before you drain the fluid. Once you have split the caliper halves, it becomes far more difficult to free stuck pistons. Compressed air or grease gun will do it, maybe a local garage would help you with this?
When I first rebuilt my tokico 6 pots (good brakes if serviced regularly, don't believe the hype about needing to swap them out), I couldn't remove a couple of stuck pistons and had no access to compressed air or a grease gun, so I put the whole lot back together, using the old fluid, bled the system and then mounted them back on the bike. Without replacing the brake pads, I then carefully pumped the pistons out of the calipers, onto the brake disc. It takes a while and you have to keep the master cylinder topped up whilst doing it.
Once all the pistons are pressed up against the disc, you can remove the calipers and split the halves. With the pistons pumped so far out of the calipers, you can easily remove them.
With everything removed and cleaned up, I personally recommend getting genuine replacement seals as opposed to the cheap ebay copies, but that's merely my preference resulting from a bad experience with cheap seals.
HTH
Mungel
ZZR600 (dead) - ZX9R (sold) - FZ1S
gandy666
PostPosted: 16:24 - 12 Sep 2012    Post subject: Reply with quote
I did the same as mungel but took the pads out and put a g clamp on the piston I did NOT want to pop out and that worked.
then i rebled it and moved the clamp to the other piston.
was 2 pot brakes tho, but the principal is the same
royzxr750
PostPosted: 18:46 - 12 Sep 2012    Post subject: Reply with quote
Right well this evening iv put the calipers back on the bike and bleed the brakes and the pistons in the calipers will not move not even 1mm. So anymore ideas?
Islander
PostPosted: 19:39 - 12 Sep 2012    Post subject: Reply with quote
Does the lever feel spongy or firm?
royzxr750
PostPosted: 05:26 - 13 Sep 2012    Post subject: Reply with quote
brake lever feels spongy. Was even like this before i took the calipers off
Ichy
PostPosted: 05:40 - 13 Sep 2012    Post subject: Reply with quote
Sounds as if you still have air in the system. Try cable ties to hold the lever tight to the bar for a few hours.
royzxr750
PostPosted: 06:08 - 14 Sep 2012    Post subject: Reply with quote
No there was no air in the system but tbh i think the seals in the master system are shot
Fizzer Thou
PostPosted: 08:43 - 14 Sep 2012    Post subject: Reply with quote
When dealing with seized brake calipers I use an old but working master cylinder fitted to an old handlebar clamped in a vice.This is the best way of pushing out caliper pistons.It is a lot easier to sort out one caliper at a time rather than attempting to bleed and sort both simultaneously.
I have a compressor,but using this would not be as effective as pushing out th pistons using hydraulic pressure.I have heard of people using a grease gun to push seized pistons out of calipers,but it does make a hell of a mess once the piston is out and you would need to spend quite some time cleaning it all out.
If you suspect the master cylinder seals as having perished it does not take too much to strip this and at least clean it all up.When I did my one on my Exup recently I found a big glob of congealed brake fluid in the main chamber.The bike has done over 40,000 miles but the seals were still good and the brakes are now as good as.
Always have a 'Plan B'
Budgetboy
PostPosted: 08:46 - 14 Sep 2012    Post subject: Reply with quote
Poor seals is another one that is often overlooked.These are perishable items and once the fluid starts to go past the main seal that is it.. But the dust seals will hold the fluid in..
If i were you i would bleed the brakes starting from the MC as air tends to get stuck in here. Then bleed your calipers keeping the bleed nipple at the highest point. Once you have done that remove the brake pads & caliper (keep hose attached). Pump pistons out and clean them, dont go to far though (2-3cm normally)
Use red rubber grease and push the pistons back again, remember do one side at a time. push the pistons in and out at least 2-3 times to get the red rubber grease to work.
Replace calipers & pads after that and try the brakes again.
If it still does is move onto the MC.
If you have standard lines check for cracks or damage/getting old.. replace with braided lines.
My guess is it will be air or poor seals.
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
Fizzer Thou
PostPosted: 09:33 - 14 Sep 2012    Post subject: Reply with quote
I doubt that the dust seals would hold back hydraulic pressures.They would leak faster than worn distortion seals.
And it would not be worth pumping seized pistons out only so far as to clean the piston itself without cleaning up where the distortion seals sit in the ring land.More often than not it is congealed brake fluid that causes the seals to push against the pistons which stops movement.If the seized piston has been pushed out under hydraulic pressure it would be quite difficult to push it back into the caliper body without using force.The piston should move quite freely if the system is working correctly.Far better to completely remove all pistons and seals and to start afresh.
Budgetboy
PostPosted: 11:25 - 14 Sep 2012    Post subject: Reply with quote
ok
The last post was made 14 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 84.15 Kb
