| royzxr750 |
 royzxr750 Two Stroke Sniffer
| 0ddball |
 0ddball World Chat Champion
| Matt- |
 Matt- World Chat Champion
 Posted: 08:26 - 12 Sep 2012 Post subject: |
Piston Pliers if possible.
Get them moving, Spray some lubrication in their WD40, then pound some air, go to your local garage and ask if you can borrow their Air line.
Make sure you clean the Pot's up after you have them out  ____________________ RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010 |
| Mungel |
 Mungel Scooby Slapper
 Posted: 12:10 - 12 Sep 2012 Post subject: |
I learnt this the hard way, like yourself. You need to free the pistons up before you drain the fluid. Once you have split the caliper halves, it becomes far more difficult to free stuck pistons. Compressed air or grease gun will do it, maybe a local garage would help you with this?
When I first rebuilt my tokico 6 pots (good brakes if serviced regularly, don't believe the hype about needing to swap them out), I couldn't remove a couple of stuck pistons and had no access to compressed air or a grease gun, so I put the whole lot back together, using the old fluid, bled the system and then mounted them back on the bike. Without replacing the brake pads, I then carefully pumped the pistons out of the calipers, onto the brake disc. It takes a while and you have to keep the master cylinder topped up whilst doing it.
Once all the pistons are pressed up against the disc, you can remove the calipers and split the halves. With the pistons pumped so far out of the calipers, you can easily remove them.
With everything removed and cleaned up, I personally recommend getting genuine replacement seals as opposed to the cheap ebay copies, but that's merely my preference resulting from a bad experience with cheap seals.
HTH ____________________ Mungel
ZZR600 (dead) - ZX9R (sold) - FZ1S |
| gandy666 |
 gandy666 Nova Slayer
| royzxr750 |
| Islander |
 Islander World Chat Champion
| royzxr750 |
| Ichy |
 Ichy World Chat Champion
| royzxr750 |
| Fizzer Thou |
| Budgetboy |
 Budgetboy Scooby Slapper
 Posted: 08:46 - 14 Sep 2012 Post subject: |
Poor seals is another one that is often overlooked.These are perishable items and once the fluid starts to go past the main seal that is it.. But the dust seals will hold the fluid in..
If i were you i would bleed the brakes starting from the MC as air tends to get stuck in here. Then bleed your calipers keeping the bleed nipple at the highest point. Once you have done that remove the brake pads & caliper (keep hose attached). Pump pistons out and clean them, dont go to far though (2-3cm normally)
Use red rubber grease and push the pistons back again, remember do one side at a time. push the pistons in and out at least 2-3 times to get the red rubber grease to work.
Replace calipers & pads after that and try the brakes again.
If it still does is move onto the MC.
If you have standard lines check for cracks or damage/getting old.. replace with braided lines.
My guess is it will be air or poor seals. ____________________ www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken. |
| Fizzer Thou |
| Budgetboy |
The last post was made 14 years, 63 days ago. Instead of replying here, would creating a new thread be more useful? |
