| Benno |
 Benno World Chat Champion
| Benno |
 Posted: 19:15 - 12 Sep 2012 Post subject: |
Had a suggestion from a mate who used to own bikes:
- Drain and replace oil
- Run engine on idle to circulate oil, turn off, top up oil
- Turn back on and run engine for 10 mins to warm up
- Place front wheel against sturdy wall
- Hold in clutch and front brake
- Drop into second gear and release clutch
...  ____________________ I'm autistic. That means I'm smarter than you. |
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:38 - 12 Sep 2012 Post subject: |
They all do that, mister. Well, mine does, both points.
It's had a recent oil and filter change and there's 5100 miles on the clock.
Brakes on hard, clutch right in (tighten if necessary), rev it like you mean it, and kick it into 1st like a naughty puppy.
Whining is just the tank breathing. Heck, it'll do it if I so much as nudge it. ____________________ Biking is 1/20th as dangerous as horse riding.
 Posted: 22:12 - 12 Sep 2012 Post subject: |
As Roger says, they all do that Mister. The plates stick together if they're left standing more than a couple of weeks. Easily sorted.
Start and warm up engine.
Place bike on mainstand.
Stand astride the bike and hold the front brake on.
Pull in clutch and engage first gear but keep holding that clutch and, the rear wheel will start spinning in the air (see why you're astride the bike and still holding the front brake on?).
Once it's up to speed, slam the back brake on hard. The rear wheel will stop and one of two things will happen. 1) The engine stalls, try again from the start. 2) The engine does not stall, your clutch is freed off. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Bomberman |
 Bomberman World Chat Champion
 Posted: 23:26 - 12 Sep 2012 Post subject: |
Mine does it a bit (nowhere near that bad, a bit of a jerk forward) but I find giving the clutch a good working before I start it up (or put it into first) eases it off a bit
Actually, I left it a week or so on holiday once and nearly ended up in the back garage wall now I think about it
Also, you probably won't be able to get second if you're not moving thanks to the 'Positive Neutral Finder'. So don't worry about that if you can't  ____________________ 'Allo! My name is Inigo Montoya, you killed my father, prepare to die!
'89 TZR 125 - '94 GPZ500s - ZK3 GSXR600 Alstare  |
| Benno |
The last post was made 14 years, 24 days ago. Instead of replying here, would creating a new thread be more useful? |
