Cheap carb sync
EazyDuz
PostPosted: 07:05 - 13 Sep 2012    Post subject: Cheap carb sync Reply with quote
Im sure its been asked before, but was just wondering if anyone can recommend a cheap and reliable carb sync tool?
I think my bike is running well, but if they arent too expensive i wouldnt mind any old excuse to learn how to adjust the carbs, and maybe improve fuel economy while im at it.
Its a v twin.
Thanks
The Artist
PostPosted: 07:36 - 13 Sep 2012    Post subject: Reply with quote
This is just an idea but if you get a long piece of tubing, maybe 7ft and put some sort of fluid you can easily see in it, maybe 2ft worth of fluid and make sure this fluid is sitting in the centre, maybe hang it in a U shape for a while then hook each end up to the corresponding carb. If one is "sucking" more than the other, the fluid will move towards it and you could balance it that way.
I have never tried this, I am just thinking off the top of my head here. Theoretically it should work.
GZXR400
PostPosted: 08:03 - 13 Sep 2012    Post subject: Reply with quote
the morgan carbtune is a popular carb balancer
PostPosted: 12:06 - 13 Sep 2012    Post subject: Reply with quote
It's called a manometer and yes, it does work. In fact, it works VERY accurately.
https://www.powerchutes.com/manometer.asp
https://www.obairlann.net/reaper/motorcycle/manometer.html
The Artist
PostPosted: 14:05 - 13 Sep 2012    Post subject: Reply with quote
More accurately than gauges because even the slightest of uneven pressures and it would move.
Casper
PostPosted: 14:28 - 13 Sep 2012    Post subject: Reply with quote
I use a home made job and its ace. I made a set for the four carbs and it cost just under £5 for the parts needed.
The last post was made 14 years, 35 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.5 - MySQL Queries: 13 - Page Size: 47.85 Kb
