Annoying little problem.
Clutchy
PostPosted: 17:03 - 13 Sep 2012    Post subject: Annoying little problem. Reply with quote
Now and then when I come to a halt if ive finished my journey or whenever I put it in neutral (usually happens more when the bikes been ridden a while) it will sometimes refuse to go into neutral.
I can cure this a lot of the time by rolling back with the clutch in and then ride forward a bit with a bit of clutch and then re try usually fixes it, however this is starting to take a few more attempts and is getting worse.
If I put it in neutral while still rolling it will always find neutral straight away. What do you rekon the problem is? Gear box oil may need changing as I do not think it has been done for a while, or could it be the full gear box thats at fault Crying or Very sad
Thanks H
Redoko
PostPosted: 17:08 - 13 Sep 2012    Post subject: Reply with quote
Though this thread was about Alpha 9.
janner_10
PostPosted: 17:17 - 13 Sep 2012    Post subject: Reply with quote
Mine does the same - never bothered me though. Only happens on my drive for some reason.
numpty2
PostPosted: 20:36 - 13 Sep 2012    Post subject: Reply with quote
Some bikes are like this, don't worry. Perhaps your clutch cable has a bit too much play, but I've had a few that were always like it. It's not a Honda by any chance?
Frost
PostPosted: 21:05 - 13 Sep 2012    Post subject: Reply with quote
Dragging clutch makes it worse.
Sometimes a short rev up to 2000rpm then applying lever pressure as the revs drop help it to click in.
DMCpro
PostPosted: 21:08 - 13 Sep 2012    Post subject: Reply with quote
as said rev a little, or if its that worrying remember to change to neutral before coming to a halt.
or if its really bothering you buy new clutch springs and plates and cable Smile
Honda CB-1, TS125X
VW Golf Estate
Clutchy
PostPosted: 21:18 - 13 Sep 2012    Post subject: Reply with quote
Yep tis a honda, how did you know Wink
Cheers for the revving advise will definitely give it a go Smile
Frost
PostPosted: 23:10 - 13 Sep 2012    Post subject: Reply with quote
I figured it out through experimentation and i bet i can get any stubborn honda into neutral even after years of not owning one. I always thought it was a unique skill, but i soon found out it's one all honda riders develop pretty quickly Laughing
PostPosted: 23:39 - 13 Sep 2012    Post subject: Reply with quote
It's not a fault. It's a "feature".
Some bikes are virtually impossible to put into neutral while stationary with the engine running.
numpty2
PostPosted: 05:35 - 14 Sep 2012    Post subject: Reply with quote
The Honda guess was easy. Over the years I've had 5 Hondas, 2 Suzukis, 1 Yamaha & 1 Kawasaki. Guess which brand was the worst for finding neutral.
It is just a case of technique & just the right amount of revs.
One other thing that might help is adjusting the height of the gear change foot lever. It has to be in the right position for you & your keft boot.
The last post was made 14 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 64.47 Kb
