 alexjones03 L Plate Warrior
 Ichy World Chat Champion
 Posted: 05:41 - 14 Sep 2012 Post subject: |
Simple answer is that you will have to measure everything to select the correct bearings.
Naming the bike and a couple of photos will get you a better answer. I've never seem a crankcase without a split, how else would you get anything inside there? ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
 bikenut World Chat Champion
 Posted: 11:36 - 14 Sep 2012 Post subject: crank |
so the bike is a gt550.............see telepathy really does work!!
bearing shells are graded by number or colour or both, and should be matched.
your bike ( gt550 ) uses the lower crankcase and upper crankcase to form the "holes "for the bearing shells ( mains ), which are line bored during manufacture, so are a matched pair.
other bikes may use a crankshaft "ladder" means of securing the bearing shells, which are line bored during mnanufacture and are a matched pair.
do you see the proble,m??
shells are selected according to shaft journal diameter ( graded ) which is indicated on the shaft, with the outside diameter ( inside dia of bearing "hole" ) indicated on the casting.
using thios info and a selection table, the corredct shells are seklected giving the corredct runnin clearance ( 0.3 thouish )
do you now see your problem.
some pics would be wonderfull.
sorry for the keyitiss, large fingers etc.........  |
