bad noise, please help
ocatoro
PostPosted: 23:31 - 17 Sep 2012    Post subject: bad noise, please help Reply with quote
so after doing my cbt today, i was hiding from the rain all evening. then the weather come right tonight, so i thought i'd take the h100 up and down the farm track a few times for something to do...
seemed ok at first, like it has been during the days since i've had it. only difference being that i put a 5litres of petrol in there earlier thisevening.
it started making this bad noise on idle, but revved freely and accelerated fine still. but i brought it back to the house anyway.
here is noise 1
https://www.youtube.com/watch?v=HTWY1GCRb1A&feature=youtu.be
then after a few minutes of head scratching trying to work out what on earth has happened, it got worse and ended up sounding like this.....
https://www.youtube.com/watch?v=AX8sweSsO3Y&feature=youtu.be
it now won't idle, the 2nd video i had to hold the throttle open a little to keep it running.
this noise sounds like death to me. what on earth is happening to it?
anyone offer any help?
CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
Current - None Sad but shed project H100 (first bike Smile )
Past - ER5, '93 ZZR600, '92 CB400 SF, ZZR600 (again), yellow Monster 620, Blackbird - black Monster 620ie - '96 ZZR600
Joenitro
PostPosted: 23:35 - 17 Sep 2012    Post subject: Reply with quote
Is your spark plug loose?
ocatoro
PostPosted: 23:43 - 17 Sep 2012    Post subject: Reply with quote
nope it's tight as you like
dungbug
PostPosted: 00:18 - 18 Sep 2012    Post subject: Reply with quote
Did you add any 2 stroke oil????
CBT: Pass 25/06/2011 Theory Test: Pass12/06/2012 Mod 1: Fail 08/07/2012
Mod 1 Retest: Pass 15/0702012 Mod 2: Pass 03/08/2012
Suzuki GN125 (Sold) ~ Current bike: Yamaha YZF 600R Thundercat
ocatoro
PostPosted: 00:25 - 18 Sep 2012    Post subject: Reply with quote
it has a separate reservoir under the seat, which is almost 3/4 full
so it should be getting oil, though i can't be sure it's getting the oil through. the pipe is connected, and she does smoke, or at least smoked when i had her running saturday in the daylight. it was dark and wet tonight so can't be sure if there was smoke to say it was getting oil
cb1rocket
PostPosted: 00:45 - 18 Sep 2012    Post subject: Reply with quote
you haven't empty the gearbox oil by chance and not filled it up?
They do run rough at first when warming up thou, although I can't tell. Is the choke off? That will cause it to run bad, they literally like only the best part of 5 secs of being on!
ocatoro
PostPosted: 00:57 - 18 Sep 2012    Post subject: Reply with quote
nah i haven't emptied anything... there's gearbox oil in it as i looked yesterday.
choke was off yeah.
is it possible that it's oil feed is clogged and it's starved itself of oil? it ran brilliantly every day since i bought it thursday. yet now it's gone to pot after i put fresh fuel in it tonight.
also it is struggling to find idle, could the clanking sound just be a bit of clutch or something similar?
dungbug
PostPosted: 09:33 - 18 Sep 2012    Post subject: Reply with quote
What's the condition of the spark plug? 2 smoke plugs will foul over time.
RichieZX6R
PostPosted: 10:19 - 18 Sep 2012    Post subject: Reply with quote
Was just about to suggest this.
Have a look at your plug colour and compare with this:
https://1.bp.blogspot.com/_Zl3HQgWfsPc/TAaRbYTjUnI/AAAAAAAAD9M/mMWXiGIFQMY/s1600/honda-spark-plug-inspection-chart.jpg
Current: Kawazaki ZX6R 51
Past: Kawazaki ZX6R 96 - Honda CBR 600F4 05 - Dragstar 125 02 - Honda CB 400 SF 94 - Honda NSR 125 51 - Gilera Runner XV125 04
ocatoro
PostPosted: 10:27 - 18 Sep 2012    Post subject: Reply with quote
this is the spark plug
https://s19.postimage.org/5ef3nn5z7/76588_10151184587385795_675070296_n.jpg
the spark would just make it run rough though wouldnt it? as opposed to something banging about?
Speed
PostPosted: 11:59 - 18 Sep 2012    Post subject: Reply with quote
For the cost of a plug (£5 or so) i'd just replace it and see if that does the trick.
Speed
PostPosted: 12:02 - 18 Sep 2012    Post subject: Reply with quote
Forgot to mention, you don't have a hole/crack in your exhaust do you? Run it and have a listen/feel of the exhaust for any blowing
ocatoro
PostPosted: 14:31 - 18 Sep 2012    Post subject: Reply with quote
ok, so head and barrel off. piston looks brand new, as do the bearings at either end of the conrod... like they've just come out of the packet new.
barrel is very very smooth all round, has honing marks on though can't feel them.
so it's probably safe to say it's had the work done that was claimed.
however, i ran the engine with the left hand cover off for a few seconds, the side the chain and generator are on... and when it drops in revs and/or to idle, when the knocking noise can be heard.... the cylindrical unit (coil?) rattles back and forth. so something is loose in the bottom end. i just don't know what's in there to know what could be loose
(ps... i now can't seem to get the piston back in the barrel... is there a nack to this?)
ocatoro
PostPosted: 14:33 - 18 Sep 2012    Post subject: Reply with quote
Vincent wrote:
I'm not sure how poor spark plug condition would make the engine rattle Confused
The little ends are definitely rattling but they usually do on two strokes anyway. Are you sure the exhaust isn't leaking anywhere? If not, it'll be rings, big end or mains I would have thought. What's the mileage and do you know if it's had a top end strip down at all?
yes i have thoroughly checked the exhaust all the way along and all the way around... there is no leak in the exhaust whatsoever.
ocatoro
PostPosted: 14:47 - 18 Sep 2012    Post subject: Reply with quote
do you mean bottom end?
yeah i agree, i don't think anything in there is expensive. it's just a job i'm unsure of
ocatoro
PostPosted: 16:54 - 18 Sep 2012    Post subject: Reply with quote
yes, i'd already had the top end off... the rings are spanking new with no damage at all. as is the piston etc...
however, whilst putting it all back together, i've noticed that the exhaust front pipe has been forced on with some oversized bolts and ripped all the threads out, so they won't go back in properly i dunno how they were holding to be honest.
so with that in mind, i started it without the exhaust bolted up... same noise, louder/worse.
could that make the engine make a bad knocking noise? or will that have caused something else to break and make a knocking?
Beamexican
PostPosted: 19:55 - 18 Sep 2012    Post subject: Reply with quote
If you took the cover off and the flywheel/magneto is loose check the nut holding it on if you haven't already, if its bolted onto the crank properly I would say its probably the main bearing, if you grab the magneto can you move it up/down side to side?
Can't really tell what the noise sounds like on my phone but if the magneto is loose moved the timing could be hugely out which could make it run bad, sound odd I think.
Not sure if your bike has points or whether this would make any difference but someone else will know more about this bike than I do.
ocatoro
PostPosted: 00:48 - 19 Sep 2012    Post subject: Reply with quote
hey fella, no the magneto thing is solid, i can't move it except to turn the engine over. however, when the engine is running and making that knocking noise..... the magneto flaps about then, presumably along with the rest of the crank.
is the main bearing the same as the big end bearing? or another one again?
it's not points no, it's cdi ignition.
after running with exhaust off, the same noise got worse, so i am hoping it is literally just that. theres a chap coming to pick up the barrel tomorrow and bringing it back weekend re-tapped so i can bolt the exhaust up properly, and i can then take it from there.... if it was the exhaust all along, it'll run properly, if not, i have crossed another thing off the list.
cheers for the suggestions everyone, given me plenty to check and fiddle with. i was close to tears when it started having been so excited about doing my cbt. fingers crossed, be able to get out now on the weekend with it
Beamexican
PostPosted: 09:23 - 19 Sep 2012    Post subject: Reply with quote
Magneto should rotate smoothly without going up or down etc,.mains and big end are different big end is the bearing in the conrod sandwiched in the crank then you have a bearing in each side of the case that the crank sits in.
Sounds like there might be an issue with your crank, did the bike vibrate a lot when running?
ocatoro
PostPosted: 10:25 - 19 Sep 2012    Post subject: Reply with quote
yeah the magneto does that, and no movement at all except when the bike is dropping off revs. when the knocking is apparent. by hand, i cannot move it in any way it shouldn't move.
ok thanks for clearing that up... so if it is not just the exhaust it'll be the main bearings most likely and can get them swapped out. just checked, theyre £8 for one side, and £5 for the other side. never met such a hilariously cheap engine before.
the bike doesn't vibrate, no. not really even a great deal when the knocking is in progress as the engine comes off revs back to idle. so perhaps the main bearings are not too bad?
karthead
PostPosted: 10:44 - 19 Sep 2012    Post subject: Reply with quote
Just wondering, I would've thought that things such as bearings or rings would fail over time, not suddenly as the OP has described it..
cb1rocket
PostPosted: 13:58 - 19 Sep 2012    Post subject: Reply with quote
if the main bearings have gone it would look something like this and the flywheel going all over the place suggest this.
https://cdn.bikechatforums.com/files/swarf_left_behind_from_damage_bearing.jpg
The last post was made 13 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 133.14 Kb
