| ocatoro |
 ocatoro World Chat Champion
 Posted: 23:31 - 17 Sep 2012 Post subject: bad noise, please help |
so after doing my cbt today, i was hiding from the rain all evening. then the weather come right tonight, so i thought i'd take the h100 up and down the farm track a few times for something to do...
seemed ok at first, like it has been during the days since i've had it. only difference being that i put a 5litres of petrol in there earlier thisevening.
it started making this bad noise on idle, but revved freely and accelerated fine still. but i brought it back to the house anyway.
here is noise 1
https://www.youtube.com/watch?v=HTWY1GCRb1A&feature=youtu.be
then after a few minutes of head scratching trying to work out what on earth has happened, it got worse and ended up sounding like this.....
https://www.youtube.com/watch?v=AX8sweSsO3Y&feature=youtu.be
it now won't idle, the 2nd video i had to hold the throttle open a little to keep it running.
this noise sounds like death to me. what on earth is happening to it?
anyone offer any help? ____________________ CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
Current - None but shed project H100 (first bike )
Past - ER5, '93 ZZR600, '92 CB400 SF, ZZR600 (again), yellow Monster 620, Blackbird - black Monster 620ie - '96 ZZR600 |
| Joenitro |
 Joenitro Spanner Monkey
| ocatoro |
| dungbug |
 dungbug Could Be A Chat Bot
| ocatoro |
| cb1rocket |
 cb1rocket World Chat Champion
| ocatoro |
| dungbug |
| RichieZX6R |
 RichieZX6R Nearly there...
| ocatoro |
| Speed |
 Speed Could Be A Chat Bot
| Speed |
| Vincent |
 Vincent Banned
 Posted: 13:37 - 18 Sep 2012 Post subject: |
I'm not sure how poor spark plug condition would make the engine rattle
The little ends are definitely rattling but they usually do on two strokes anyway. Are you sure the exhaust isn't leaking anywhere? If not, it'll be rings, big end or mains I would have thought. What's the mileage and do you know if it's had a top end strip down at all? ____________________ Space Is Deep |
| ocatoro |
 Posted: 14:31 - 18 Sep 2012 Post subject: |
ok, so head and barrel off. piston looks brand new, as do the bearings at either end of the conrod... like they've just come out of the packet new.
barrel is very very smooth all round, has honing marks on though can't feel them.
so it's probably safe to say it's had the work done that was claimed.
however, i ran the engine with the left hand cover off for a few seconds, the side the chain and generator are on... and when it drops in revs and/or to idle, when the knocking noise can be heard.... the cylindrical unit (coil?) rattles back and forth. so something is loose in the bottom end. i just don't know what's in there to know what could be loose
(ps... i now can't seem to get the piston back in the barrel... is there a nack to this?) ____________________ CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
| ocatoro |
| Vincent |
 Vincent Banned
 Posted: 14:37 - 18 Sep 2012 Post subject: |
I think it's top end tear down time Not a massive or expensive job unless you find something major in there. ____________________ Space Is Deep |
| ocatoro |
 Posted: 14:47 - 18 Sep 2012 Post subject: |
do you mean bottom end?
yeah i agree, i don't think anything in there is expensive. it's just a job i'm unsure of ____________________ CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
| Vincent |
 Vincent Banned
| ocatoro |
 Posted: 16:54 - 18 Sep 2012 Post subject: |
yes, i'd already had the top end off... the rings are spanking new with no damage at all. as is the piston etc...
however, whilst putting it all back together, i've noticed that the exhaust front pipe has been forced on with some oversized bolts and ripped all the threads out, so they won't go back in properly i dunno how they were holding to be honest.
so with that in mind, i started it without the exhaust bolted up... same noise, louder/worse.
could that make the engine make a bad knocking noise? or will that have caused something else to break and make a knocking? ____________________ CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
| Beamexican |
 Beamexican Borekit Bruiser
| ocatoro |
 Posted: 00:48 - 19 Sep 2012 Post subject: |
| Beamexican wrote: | If you took the cover off and the flywheel/magneto is loose check the nut holding it on if you haven't already, if its bolted onto the crank properly I would say its probably the main bearing, if you grab the magneto can you move it up/down side to side?
Can't really tell what the noise sounds like on my phone but if the magneto is loose moved the timing could be hugely out which could make it run bad, sound odd I think.
Not sure if your bike has points or whether this would make any difference but someone else will know more about this bike than I do. |
hey fella, no the magneto thing is solid, i can't move it except to turn the engine over. however, when the engine is running and making that knocking noise..... the magneto flaps about then, presumably along with the rest of the crank.
is the main bearing the same as the big end bearing? or another one again?
it's not points no, it's cdi ignition.
after running with exhaust off, the same noise got worse, so i am hoping it is literally just that. theres a chap coming to pick up the barrel tomorrow and bringing it back weekend re-tapped so i can bolt the exhaust up properly, and i can then take it from there.... if it was the exhaust all along, it'll run properly, if not, i have crossed another thing off the list.
cheers for the suggestions everyone, given me plenty to check and fiddle with. i was close to tears when it started having been so excited about doing my cbt. fingers crossed, be able to get out now on the weekend with it ____________________ CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
| Beamexican |
| ocatoro |
 Posted: 10:25 - 19 Sep 2012 Post subject: |
yeah the magneto does that, and no movement at all except when the bike is dropping off revs. when the knocking is apparent. by hand, i cannot move it in any way it shouldn't move.
ok thanks for clearing that up... so if it is not just the exhaust it'll be the main bearings most likely and can get them swapped out. just checked, theyre £8 for one side, and £5 for the other side. never met such a hilariously cheap engine before.
the bike doesn't vibrate, no. not really even a great deal when the knocking is in progress as the engine comes off revs back to idle. so perhaps the main bearings are not too bad? ____________________ CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
| karthead |
 karthead Trackday Trickster
| cb1rocket |
The last post was made 13 years, 207 days ago. Instead of replying here, would creating a new thread be more useful? |
