| Benman |
 Benman Renault 5 Driver
| MarkJ |
 MarkJ World Chat Champion
| Benman |
| map |
 map Mr Calendar
 Posted: 12:45 - 17 Sep 2012 Post subject: |
Change the flasher relay to a multi wattage type, aka constant rate flasher unit IIRC or universal flasher type.
Do a search on eBay or the like, can be had for ballpark £5.
This will sort out the led flashing issue.
Also useful if you mix standard wire element bulbs and led ones.
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Shinigami |
 Shinigami World Chat Champion
| Benman |
| map |
 map Mr Calendar
| Benman |
| map |
 map Mr Calendar
| Alpha-9 |
 Alpha-9 Super Spammer
| Benman |
| map |
 map Mr Calendar
 Posted: 16:58 - 17 Sep 2012 Post subject: |
It works with the original bulbs and not with the new ones because the flasher unit is designed for a certain wattage.
Power (wattage) = Volts x Current (amps).
I'm guessing you may find original bulbs are rated at 21w, new ones may only be 5w or 10w.
The universal ones don't care about the wattage. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| Benman |
 Posted: 18:09 - 17 Sep 2012 Post subject: |
Have searched on eBay for multi wattage relay and can only see ones suitable for led so is this what I need? Also mine is only two pin does this matter or will a three pin suit if I deck it to the frame or any other suitable earth point? Why is this so friggin difficult?? If I know exactly what to buy I will by the fucking thing and stick it in and problem solved. I understand that the draw is wrong. The relay I am now using is not suitable for the new indicators I get that so how do I solve that?? What exactly do I need to rectify this. Aaaarrgg!!!    ____________________ Ben1972 |
| map |
 map Mr Calendar
| Benman |
 Posted: 19:05 - 18 Sep 2012 Post subject: |
Sorted now!!! Thanks for all the help    ____________________ Ben1972 |
| _Iain_ |
 _Iain_ Banned
 Posted: 19:18 - 18 Sep 2012 Post subject: |
My indicators arent LED but had to fit an LED relay to make em work. Bout a fiver posted and will fix problem. ____________________ Please be aware that the above post may be full of complete nonsense.
| Benman |
| Benman |
| Islander |
 Islander World Chat Champion
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 13:04 - 20 Sep 2012 Post subject: |
Right, pay attention!
I bought new "mini" indicators for my CBR6.
After I fitted them they flashed too fast.
The reason they flashed too fast was that the original bulbs were 23W items, the bulbs in the "mini" indicators were 6W items.
I bought a box of twelve 23W bulbs suitable for the "mini" indicators, for less than a fiver, the propblem dissappeared.
What MAP is telling you is factually correct but all you need to do is fit four bulbs of the correct wattage! ____________________ "Everybody needs money, that's why they call it money!"  |
| Islander |
| Benman |
| Suntan Sid |
| Suntan Sid |
| Casper |
 Casper World Chat Champion
The last post was made 14 years, 13 days ago. Instead of replying here, would creating a new thread be more useful? |
