Petrol leak is this normal.
Matt-
PostPosted: 08:59 - 19 Sep 2012    Post subject: Petrol leak is this normal. Reply with quote
Basically got my NSR back together From
Having top end rebuild, carb clean, and all new carb gaskets and seals,
It's had fuel filter cleaned and pipes cleaned and some other bit's,
I don't know if this is correct, but bike starts fine and runs lovely, when I turned it off, and went inside my house I came back out to it later, and their was petrol on the floor, problem was
I left the fuel on reserve and it leaks out of a gap in the air filter pipe going on the carb, is this normal when you
Leave the tap
On ?
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
dungbug
PostPosted: 09:52 - 19 Sep 2012    Post subject: Reply with quote
I don't think so, the float height could be wrong. When I was faffing about with the GN some time ago I'd messed up the float height somehow which (I assumed) was allowing too much fuel into the float bowl which was then dripping from the overflow pipe. I'd say run the bike for a bit, turn it off and get on the floor and see where it's coming from. If it's dripping from the overflow then whoever did the work on the carb might have upset the float height or the float needle may be sticking.
CBT: Pass 25/06/2011 Theory Test: Pass12/06/2012 Mod 1: Fail 08/07/2012
Mod 1 Retest: Pass 15/0702012 Mod 2: Pass 03/08/2012
Suzuki GN125 (Sold) ~ Current bike: Yamaha YZF 600R Thundercat
monkeyman
PostPosted: 10:20 - 19 Sep 2012    Post subject: Reply with quote
if you paid someone to clean the carb for you could take it back and tell them to sort out the carb.
sounds like you may have some crud stuck between your float valve and float valve seat.
Im not the best, but im in the top one
RM 250, Husky TE610, K1 GSXR 750
Matt-
PostPosted: 10:46 - 19 Sep 2012    Post subject: Reply with quote
Thanks for your reply's.
Did what you said
Dungbug
and nothing seemed to happen accept some petrol came from the air filter side ?
If it's any help i did replace a plastic ring thing in the Fuel strainer on the carb, does the strainer have to be a certain way ? it seems to me it's fitted OK but if anyone else has better knowledge please feel free to share Very Happy
Matt
Matt-
PostPosted: 10:59 - 19 Sep 2012    Post subject: Reply with quote
_Iain_ wrote:
Sticky/incorreectly set float.
Carb off, float bowl off and set as per instructions.
OK thanks for that Very Happy
Any instruction's on how to set float height ?
would his also be a cause of erratic rev's ?
Matt-
PostPosted: 11:55 - 19 Sep 2012    Post subject: Reply with quote
_Iain_ wrote:
Could be, if the floats jamming and randomly flooding the engine a smidge.
Got an email adress? I'll mail you over a PDF manual for the YBR125. Belive it to be the one yamaha issues the dealerships with - theres a whole chapter on removal, stripping, cleaning, setup and adjustments to the carb Thumbs Up
Obviously dont set it up like a YBR, but it's got some realy good pics on how to do the job
Yeah it's " [email protected] "
Cheers bud Thumbs Up
DMCpro
PostPosted: 14:00 - 19 Sep 2012    Post subject: Reply with quote
does it still leak whilst the engines running
Honda CB-1, TS125X
VW Golf Estate
Matt-
PostPosted: 14:17 - 19 Sep 2012    Post subject: Reply with quote
No it doesn't pro,
Bike runs lovely after about 20 seconds of running then after 5 minutes it's running even better, also seems like its running a bit rich, as theirs a good amount of smoke on start up.
Matt
PostPosted: 14:42 - 19 Sep 2012    Post subject: Reply with quote
Hmm, I'd worry about where that petrol was going in all honesty...
Matt-
PostPosted: 14:54 - 19 Sep 2012    Post subject: Reply with quote
Oh i am i am just wondering would the smoking be a cause of the float height being altered ?
Matt
The last post was made 14 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 76.76 Kb
